Old 11th September 2008, 14:18   #1
ankit.jhamb's Avatar
Default Swift DZire-problems
guys
My 1 month old DZire has the following problems
1.strange noise from backside(left) when ever the car passes through a pot hole.i am not sure whether this is a common sound as I have not observed this from right side.the sound is like ""khatak""/bouncing sound
since i am driving it always,i m not sure whether this will also happen when the car is fully loaded?
2.i have observed that the speedo takes time to reach 0,and also rise from 0.
what can be done for the above problems,my first service is due and maybe this weekend i ll be getting it done.
please advise for the above problems
thanks in advance
ankit jhamb
ankit.jhamb is offline   Reply With Quote
Old 11th September 2008, 14:22   #2
Eddy's Avatar
Thanked: 5,078 Times
Have you checked your rear seat belt ? The sound can be the buckle hitting the body.
Eddy is offline   Reply With Quote
Old 11th September 2008, 14:28   #3
lohithrao's Avatar
Thanked: 163 Times
Originally Posted by ankit.jhamb View Post
guys
thanks in advance
ankit jhamb
On the noise does the sound come only when the car is fully loaded? noise might be from the back seat also...
ABout the speedo are you talking about the cold start? if yes this is very normal..
lohithrao is offline   Reply With Quote
Old 11th September 2008, 14:32   #4
the noise comes only when there is single person driving.i m not sure about the noise if the car is fully loaded.
the speedo is behaving like this from day 1.takes time to reach 0 even if i have stopped 2 secs before.
@eddy::i ll check the seat belts i dont think it is from seat belt .it is a hard bouncing sound
Old 11th September 2008, 16:14   #5
Firebird's Avatar
Thanked: 61 Times
Well it's a remote possibility but tell them to check the rear suspension.
One test is load the boot with some weight...say 30 to 40 kg ....or take 4 people with you for a ride on a road with speedbreakers. If its not present then the suspension should be culprit and may need some adjustments.
The bouncing back happens in case when the rear suspension do not absorb the complete bounce.
Other way is try to push the car sideway, see if you still get 'khat khat' or squeaking sound.
The belt thing can be checked by buckling the seat belts so they dont hit anywhere.
Firebird is offline   Reply With Quote
Old 11th September 2008, 17:10   #6
lohithrao's Avatar
Thanked: 163 Times
ankit check if the spare wheel/tool kit is not loose...
Old 11th September 2008, 18:47   #7
ok i ll check for the suspension part.
what about the speedometer taking time to reach 0/rise from 0.(like it used to happen in astra,the starting speed was however 20km/hr in astra )
Old 11th September 2008, 19:19   #8
Thanked: 34 Times
Just check whether your spare tire is not fitted properly. Also check whether your tool box is not fitted properly.
deepakhon is offline   Reply With Quote
Old 11th September 2008, 19:56   #9
have checked the tyre and tool kit,everything is fine,not sure whether i should change the tyre pressure here.
guys plz advise about the rear tyre pressure if it is driven with one person only.
Old 11th September 2008, 20:23   #10
anjan_c2007's Avatar
Thanked: 5,274 Times
Maintain tyre pressures as recommended even if there is driver only drives. With less or no load the rear suspension may be throwing tantrums. try to get some two persons seated on your backseat and observe if the same sound is emitted.
anjan_c2007 is online now   Reply With Quote
Old 11th September 2008, 20:34   #11
Awaiting Email Confirmation
i have a dzire vdi and i have been experiencing the same problem. whenever i drive over a pot hole it gives a really loud sound. had the showroom guys check it and they say nothing is wrong with the suspension.
ajitknight is offline   Reply With Quote
Old 11th September 2008, 20:51   #12
Check Spare Wheel, hope its not loose
passion4cars is offline   Reply With Quote
Old 11th September 2008, 21:33   #13
Jaggu's Avatar
Thanked: 8,693 Times
Also does the spare wheel cover (dont know dezire has cardboard ones) if so are they secured properly?
Old 12th September 2008, 06:13   #14
do hear the sound from the back (left side only),or is it from both the sides.
spare wheel part has been checked already.
Old 12th September 2008, 15:47   #15
Thanked: 103,661 Times
The sound seems to be a suspension component gotten loose. I hear the monsoons have played havoc on Delhi's roads.
Standard feature of some other cars too, including some Mercs.
Suspension upgrade for Dzire (Maruti Swift Dzire) Murugan Modifications & Accessories 26 23rd January 2018 19:43
Virus problems/spyware problems! post here! SirAlec Gadgets, Computers & Software 10 16th July 2014 00:05
Swift DZire VDi - 20000 Kms Update - Few Problems SumitBahl Test-Drives & Initial Ownership Reports 40 27th March 2011 18:35
Swift Dzire Petrol Vs. Swift Dzire Diesel reveal_da_zeal The Indian Car Scene 2 4th April 2008 21:52
