| Technical Stuff Want to know your Vtec, ABS or intercooling better? |
| | Thread Tools |
| | #1 (permalink) |
| BHPian | Guyz, It seems like the worse had happened to our Accent CRDi. Its 2004 end model and has run just 60K, but developed a minor sound from the engine since past 1K. The car was regularly serviced with MGF-Hyundai who sold the car to us. From the initial inspection, MGF mechanics suspects a Minor engine overhaul is required and would cost 50K approx (Can be confirmed only after opening). We are in real dilema as the car was expected to run atleast 150K without major trouble. As per MGF, one in 100 cars can approach engine work in early 70Ks and we fall in the unfortunate list. However I decided to take a second opinion from another authorized workshop in Kochi. When I have examined the car, there is no temperature abnormalities or performance dip. Oil level is also not dropping. The only issue seen is the new noise of the engine. My uncles UNO D covered 300K without any major trouble and I cannopt accept CRDi engine(which boasted so much of advantages and long life) requires a premature overhaul. Please pour your experience if any, I wish noone should have it ![]()
__________________ Cheers....Jacs I am passionate about FIATs. Last edited by jacs : 15th September 2008 at 10:21. |
| | #3 (permalink) |
| Team-BHP Support ![]() | Hi Jacs, I think a second opinion is in order. If the mechanic hasn't explained the exact cause of that sound, how can he make a blanket statement pointing toward an overhaul? Especially when you find the performance to be the same. Take it to another expert shop and have them run her through some checks. If you have maintained it as per the manufacturers schedule, I don't see why you require an overhaul. Have heard of the common-rails with damaged fuel pumps @ 70K, but not too many engines of the same vintage requiring an overhaul.
__________________ GTO Change the way you think, and watch the world change around you.
| | #5 (permalink) |
| BHPian Join Date: Mar 2005 Location: bangalore
| I dont understand whats with these Hyundai dealers always scaring the CRDI accent customers with weird statements. They always charge a bomb and they never disclose what exactly is the inherit problem with the engine that it really needs a shot at 60-80k kms. While a few say it can last over 1L happily. Does this mean, the others are ignorant of the problems, or there is some real vodoo with a chosen few engines. This is either due to some bad components used in the engine(mostly heard of this in the pre 2005 models) or an engine design issue or a trick pulled by dealers to make some quick money. After investing 50k and more on a small check-up, the actual parts replaced will be hardly anything. Piston, liners, etc will all remain the same. The customer is charged a bomb and hardly anything is actually done. This has to be taken up to a consumer court and Hyundai should be made to answer to the actual problem. They cant promise reliabilty and then make customers land up like this. Joel
__________________ There is more to life than incresing its speed! |
| | #6 (permalink) | |
| Senior - BHPian | Quote:
If you do the 50k "overhaul", all the cash saved in fuel will be spent on the so called "rebuild". I suggest you check cylinder compression level in all cylinders to confirm engine condition.
__________________ Speed thrills. But kills. If you ain't got skills! | |
| | #8 (permalink) |
| Newbie Join Date: Sep 2008 Location: Bangalore
| You can perhaps do a prelim check and follow the process listed below. Start the engine and allow the engine to warm up..preferably run it a small round to get it to temperature. If you have another CRDI car as a standard try to get it and do the same procedure simultaneously. Place the screwdriver- the driving end on all important rotating parts like water pump..fuel pump..vacuum pump..alternator...OHC end bearings..ect to listen for peripheral noise.I am suggesting this since you said there is nothing wrong with the engine.If you can listen to any abnormalities in the noise from any of these parts you have what you are looking for. But is I have come across such cases in the past and the overhaul at such low milages is not very uncommon for this engine. Worst case you will have the crankshaft bearings replaced and a set of rings and valve grinding done and will cost you under 20k.In case there has been any serious damage in the liners or piston you will already habe back compression and will show up as smoke in the valve door on a hot engine. check for these indications and return. |
| | #10 (permalink) | |
| Senior - BHPian | I ditto all that. A few of my friends who own (ed) Accent Crdi had their engine overhauls done between 80-85K. On the contrary my '98 TCIC Safari has done 70K and still going strong. ![]() Quote:
__________________ Royal Enfield Bullet 1962 All Black 1998 Safari 4x4 All Black 2004 Scorpio GLx | |
| | #12 (permalink) |
| BHPian | Thanks everyone for the warm response. Tomorrow we are taking the car to another hyundai service in Kochi. Since I am here in Bangalore, instructed the driver(he is also en experienced guy) to enquire in detail what is the issue and the remedy proposed. Lets see whether the solution from both dealers match ![]()
__________________ Cheers....Jacs I am passionate about FIATs. |
| | #13 (permalink) | ||
| BHPian Join Date: Aug 2005 Location: Cochin
| Quote:
A second opinion is always good. Quote:
| | #15 (permalink) | |
| Senior - BHPian Join Date: Sep 2007 Location: New Delhi
| Quote:
Just because of a MINOR new sound from the engine, please do not presume that a so-called minor overhaul of the engine is required as suggested by the asses. Do seek more opinions as to the source of that minor sound. If nothing seems to materialize, try to get used to it and live with it. TILL the time you have more serious pointers to something being amiss with the engine! | |
| Thread Tools | |
Similar Threads | ||||
| Sluggish Accent CRDI after engine rebuild. | clipto333 | Technical Stuff | 30 | 11th March 2008 00:44 |
| engine and trasmission oil for Accent CRDi viva! | rider60 | Technical Stuff | 2 | 26th February 2008 04:34 |
| accent crdi engine prob at 80k? | rajivanoj | Technical Stuff | 11 | 6th February 2008 22:29 |
| hyundai accent crdi engine failure. | clipto333 | Modifications & Accessories | 92 | 13th November 2007 11:12 |
| Accent crdi and engine failures | RJK | The Indian Car Scene!! | 3 | 3rd October 2004 19:30 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481
