| Technical Stuff Discussions related to the technical side of cars (Vtec, ABS, Intercoolers et al). |
| | Thread Tools |
| | #1 (permalink) |
| BHPian Join Date: Sep 2007 Location: NA
| [Mods, please move this post if it is not in the appropriate place] I have seen quite a good number of posts about the top speeds of different vehicles. Some try to arrive using power, torque, weight of the vehicle blah blah. This is how the top speed of a car can be arrived at without really trying the limit. The factors that influence the top speed of a car:
Test the top speed in first gear in a high way and note down the rpm the car is capable of reving. Let's call that R. Now, note down the speed at 2000 rpm in a given gear, x. Let's call that Sx. Now the top speed Tx in x gear will be: Tx = R * Sx / 2000 (For those unfamiliar with computer language, * denotes multiplication) As we can see, top speed has no relation with the power or torque or load/weight. The catch here is that the engine can pull the vehicle only if it has enough torque to cause an acceleration greater than zero. Even the tiniest of torque can cause an acceleration greater than zero provided there is no opposite force, such as going uphill or wind resistence. In most practical cases, assuming plane surface and negligible wind speed (when car is not moving), any car will have sufficient torque to pull most loads against the wind speed (increasing at higher speed of the vehicle). As we can also see, the top speed will increase if the tyre diameter is increased. Anyone who is expert on gear ratio can add on how to arrive at the top speed from known tyre specs and gear ratios. I did further reading from Gear ratio - Wikipedia, the free encyclopedia It indicates that there is another reduction from the transmission to the actual wheel, they term it as differential ratio. They have also explained how to arrive at the speed ![]() Last edited by opendro : 19th September 2008 at 11:25. Reason: Added another parameter "differential ratio |
| | #2 (permalink) | |
| Distinguished - BHPian ![]() | What you're talking about is mechanical top speed (provided this is achieved before a vehicle hits its aerodynamical top speed). There are many other factors that decide the actual top speed of a vehicle. My car has a mechanical top speed of 250kmph meaning, i can touch 250kmph provided i can redline (7100rpm) 5th gear. But this is not possible coz the power, torque, weight and aerodynamical properties of my car limit it to 185kmph (5237rpm in 5th). Quote:
So please don't confuse mechanical top speed with aerodynamical top speed. Shan2nu | |
| | #3 (permalink) |
| Team-BHP Support ![]() | I have only seen some diesels hit max rpm in 5th gear. AFAIK, no Indian petrol car does. True. But it may increase the max speed of lower gears.
__________________ GTO Work backward from your imagination, not forward from the past!
| | #5 (permalink) | |
| Distinguished - BHPian ![]() | Quote:
Prob the only way you can see a slight increase in actual top speed is if your bigger wheels are way lighter than your stock wheels. So its a combination of size and weight that decides if your top speed will increase or decrease. Shan2nu Last edited by Shan2nu : 19th September 2008 at 12:56. | |
| | #6 (permalink) |
| BHPian | Hi Opendro, like Shan2nu had mentioned just considering drive-line gearing & wheel dimensions would result in top-speeds you can't achieve in real life. You could do it on a chassis dyno though, I guess. The thing that stops you is aerodynamic drag, which is why if you sky-dive you'll not top 196 Kmph (terminal velocity). Plus, you'll have to contend with rolling resistance. Aero Drag is function of your car's drag coefficient (Cd), frontal area, air density & finally the square of your speed. Rolling resistance, on the other hand, is a function of coefficient of rolling resistance & the weight of your car. Cd values are usually included in a car's specifications, frontal area is not... |
| | #7 (permalink) |
| I DID mention that the car should have enough torque to cause an acceleration greater than zero against all opposite forces (read as resistence). I believe most cars today will have enough torque to cause a positive acceleration (on plane surface, with no wind speed at vehicle idle). But the acceleration may be so small that you will take very LONG TIME to actually reach the top speed. Good torque ones will manage to reach the top speed much easily as it would cause enough acceleration against resistances. As GTO mentioned, some petrol vehicles may not be able to red line at all in fifth gear as the resultant torque on the wheel will be less than the opposite resistance at higher speed. Or even if the torque is greater, it would have taken very long time if it is marginally greater than the resistances (all put together). Shan2nu, how do you say that trucks will do 500-600? Engine torques are converted to wheels rotating torque by various gear reductions. Trucks are obviously designed to result in a huge torque on the final axle, not to do very high rpm on the wheels. I suggest you read Gear ratio - Wikipedia, the free encyclopedia about how the wheels speed is related to engine speed. And I also suggest that you read HowStuffWorks "How Gears Work" to understand how different torque results are produced on the wheel from the engines. |
| | #8 (permalink) |
| BHPian Join Date: Jan 2008 Location: Hyderabad
| At high speeds the equation becomes a bit more complex since there will be a change in the downforce acting on the car. Also the top speed will be different at different periods of time due to factors such as altitude, humidity and temperature. |
| | #9 (permalink) | |
Coz you said that top speed can be increased with bigger wheels which doesn't always work. I can't really increase the top speed of my car by using 25" wheels can i? How can you possibly say that top speed has no relation with power, torque, weight etc It just is. Shan2nu | |
| | #10 (permalink) | |
| Quote:
Assume that engine is tweaked to produce 800Nm of engine torque at 6000 rpm. It will obviously boost the power at 6000rpm to four times. Now, this increase in torque and power (four times for both) is not going to result higher top speed. That was my point. And let me remind you again that I mentioned that there is a minimum torque that is required to counter the resistance at increasing speed before it reaches the top. GTO said that the car may not red line (reason being the minimum torque not being met, as I would understand) and I'm fine with that. You are talking as if top speed is directly related with torque, power, load, etc. etc. which I don't agree and I'm giving the reason also. Last edited by opendro : 19th September 2008 at 15:06. | |
| | #12 (permalink) | |
Shan2nu | |
| | #13 (permalink) | |
| Quote:
Suppose, when you pedal your cycle in a given gear at 40 rpm, assume the wheel will rotate at 100 rpm, let's say equivalent to 20 Kmph speed. Now you pedal at 80 rpm, the wheel will now rotate at 200 rpm causing the speed to double at 40Kmph. To generalize, rpm of your pedal, the cycle's speed will be: speed = rpm * 20 / 40 Assuming you can pedal at max 100 rpm even without any friction with the wheel rotating in the air, your top speed will be 100 * 20 / 40 = 50Kmph. Again my assumption that you have much more strength than the resistance that will come at 50Kmph ![]() | |
| | #14 (permalink) |
| I agree with Shan2nu. At low speeds the limiting factor would probably be the transmission and gear ratio. But at medium to high speeds (> 120 kmph) the air drag will be the most significant factor for determining the top speed. So torque would play a significant part here. Last edited by watashi75 : 19th September 2008 at 15:23. Reason: Edited. |
| | #15 (permalink) |
| Final drivingshaft (wheel) speed can be increased with a different gear ratio as I mentioned. If the Bugati had a fifth gear ratio of 6000:1 and differential ratio (from transmission to final drive shaft) of 1:1, the maximum speed it can do is to rotate its tyres only once per minute. What will be the use of that torque now? |
| Thread Tools | |
Similar Threads | ||||
| Query: Do new cars have a speed limit initially | Peets | Technical Stuff | 1 | 26th July 2008 04:34 |
| Speed limit increased to promote safety !!! | Steeroid | Street Experiences | 17 | 12th June 2007 21:17 |
| Andhra pradesh Getting Speed Limit 60kmph | Vulken Auto | The Indian Car Scene | 24 | 2nd May 2005 13:59 |
| Germans to put a speed limit on the autobahns | _Crazi4Speed_ | The International Automotive Scene | 0 | 28th September 2004 06:59 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607
