Old 20th September 2008, 13:04   #1
Default Maruti alto VX front brake problem
hi all,
for the last few days i was getting a feeling that my front left brake is holding on wheel even if i am not applying brake. I opened the wheel myself and saw that pads are holding on to rotor and wheel is very hard to rotate (i understand it will not rotate as free as it does in cycle because of axle but i could feel it is jam). I shown it to mechanic initially he said wheel is all right and there is no problem. But on my insistence he opened the wheel and checked up brakes. He removed the brake caliper and inspected brake pads, they looked worn out to me. but mechanic said to me that once i apply the brake and release they are not going back to original position because brake caliper is not working properly. i could not see this myself because he made me apply the brakes when he was inspecting. i also noticed that rotor has gone black in color and he suggested i get it polished.
I have few questions. how much are new brake pads and brake caliper going to cost if i replace them? how can i determine that my brake rotor needs polishing? does any one has got done such brake repair work recently please guide me? also where can i get genuine maruti brake pads and caliper in south mumbai?( i wish to know shop name i know there are many shops at opera house)
thanks in advance
RP
rammishra is offline   Reply With Quote
Old 20th September 2008, 19:26   #2
arpandiv's Avatar
Thanked: 27 Times
get the brake calliper pin checked.
arpandiv is offline   Reply With Quote
Brake fluid/Parking Brake Indicator light- Is this a problem? santosh.s Technical Stuff 10 7th June 2017 14:02
RE R&D Blunder: Front Brake Problem in Standard 350 UCE models abhishek24x Motorbikes 13 17th January 2013 11:50
Paint for disc brake pads & rear brake drums VC12 Modifications & Accessories 8 25th October 2011 17:18
Only brake OR clutch+brake swiftcrazy Technical Stuff 8 10th July 2007 23:19
Which is the right Sequence Clutch-Brake Or Brake-Clutch ankura12 Technical Stuff 2 9th July 2007 10:02
