Old 22nd September 2008, 19:36   #1
greenhorn's Avatar
Thanked: 1,519 Times
Default power steering lighter in Indica Xeta than in Turbo
Drove a friend's xeta, and got noticed how light the controls feel. The lighter clutch I can understand, same of the much better feel of the gearbox, but the power steering was substantially lighter. how can the feel of a power steering change with the engine type?
Is it because of the 14" wheels i have ( xeta has 13")
is it because of the weight of the diesel engine ?
or do i need to get my steering checked ?
Old 22nd September 2008, 19:43   #2
trrk's Avatar
Thanked: 13 Times
Hi greenhorn,
Could be!
Why don't you try another model similar to yours?
I don't feel the power steering in my Marina is heavy!
trrk is offline   Reply With Quote
Old 22nd September 2008, 19:46   #3
greenhorn's Avatar
I didnt feel my steering heavy in an absolute sense, but this one felt lighter. Have my third service coming up this week, will ask them to check anyway
Old 22nd September 2008, 20:01   #4
The petrol's steering does feel lighter - no cause for worry unless you find your car's steering heavier than another turbo's.
hrag is offline   Reply With Quote
Old 22nd September 2008, 21:30   #5
bottle's Avatar
Thanked: 138 Times
probably because of the tiny engine. xeta is a nice enough car to drive though
bottle is offline   Reply With Quote
Old 23rd September 2008, 09:20   #6
itwasntme's Avatar
Thanked: 1,735 Times
Probably the same PS unit serves both the Xeta and the Diesels. With the Xeta's lighter engine (especially the 1.2 GLE, GLS and GLG) and smaller 13" wheels, there will certainly be a perceptible difference.
itwasntme is online now   Reply With Quote
Old 26th September 2008, 20:58   #7
greenhorn's Avatar
Problem solved. seems there was something wrong with the Power steering after all. Was detected and fixed when i took it to the TASS!
Old 16th January 2009, 21:16   #8
sugam's Avatar
Thanked: 46 Times
Hi All
I have an Indica Xeta 1.2L GLS.
Recently I noticed that when I turn the steering towards the extreme right or left sides, I hear a motorised sound and the engine RPM dips down to about 400 to 500 RPMs. This thing happens till the time I hold the steering in one of the extreme directions (completely left or right).
I don't think there's anything wrong with my power steering. Was just wondering if someone well versed with the wonderful Tata Motors engineering could explain the phenomenon to me??
Sugam.
sugam is offline   Reply With Quote
Old 21st January 2009, 14:12   #9
ilangop's Avatar
Thanked: 591 Times
Hi Sugam,
You are right. You can hear this phenomenon on any Hydraulic assisted power steering vehicle. When the steering system reaches the extremes, the hydraulic valves are at full open condition during which the assisting system let oil at its maximum flow rate. Since the steering system has reached its limits and cant move further, the pressure built by the Hydrauic pump reaches the maximum to crack open the pressure relief valve inside the pump.
This means that the pump operates at the maximum pressure condition and zero output flow. All the pumped oil is returned back to the reservoir. Engine feels as an over load due to the overload on the pump.
Finally this sound and fall in engine RPM is no harm either to the pump or to the engine. The ECU controlled engines immediately stabile to the idle RPM as soon as the RPM falls down due to the pump over loading.
Nothing to worry about this and enjoy your ride.
-Ilango
ilangop is offline   Reply With Quote
Old 30th December 2009, 12:41   #10
A noteworthy point.. The hydraulic steering does feel a lot lighter at high speeds and I must add that this kinda scared me during my drive back to Pune from Baroda on NH8..
Anything wrong or its just the high speed?
BTW: I was clocking only around 120Kmph
xandercage is offline   Reply With Quote
2007 Indica Xeta: Engine losing power all of a sudden and regaining power after mins mohandas Technical Stuff 17 3rd May 2016 07:37
Indica Xeta LPG or Indica Turbo Diesel?? nobreaks Hatchbacks 12 1st September 2006 23:29
Indica Turbo or Indica Xeta BNB Hatchbacks 6 23rd April 2006 11:19
