Old 26th September 2008, 15:11   #1
ralstonraz's Avatar
Default Vibration issue in Honda City - type 1
I am facing a lot of vibration in my car when the car is at Idle and with the AC on.
The vibration disappears/ reduces when the AC is switched off.
I have got the throttle body cleant recently thinking it was a throttle issue but it is not.
The car works on both Petrol and LPG and the issue is the same on both fuels.
The mechanic mentioned the engine mounts were intact too.
Please assist.
ralstonraz is offline   Reply With Quote
Old 26th September 2008, 17:38   #2
flipsyde's Avatar
Thanked: 62 Times
Either your RPM is set too low (Could be an ECU based issue) or your engine mounts could have worn out.
flipsyde is offline   Reply With Quote
Old 26th September 2008, 18:48   #3
ankitahuja's Avatar
Thanked: 46 Times
Where exactly do you experience the vibrations? What is the condition of the suspension?
You should get the engine mounts checked properly. Also, check for the gear mounts and suspension mounts, since all these can result in the car vibrating.
Old 26th September 2008, 20:21   #4
Ford Rocam's Avatar
Thanked: 16 Times
RPM increases slightly when you switch on the A.C to tackle additional load on engine. does that happen? i think that's the problem, issues could be related to idle/IAC valve.get that checked.
Ford Rocam is offline   Reply With Quote
Old 16th October 2008, 18:01   #5
ralstonraz's Avatar
This is issue is still not solved!
My mechanic says that he will let me know when another car of the same model comes in, he will then replace the throttle body and check the issue.
I believe that it is because the ECU voltage directed is incorrect due to which the excess air does not by pass the throttle body, which increases the RPM.
I have done a lot of reading on this, and I think I can do my PHD on this. lol...
Will keep you posted on this issue.
Old 30th March 2009, 17:09   #6
ralstonraz's Avatar
Senior BHPians!!!!!!
Help me please.
Can anyone suggest a good mechanic for this??
The RPM drops to 150 & 200 when at idle and engine is warm..
Old 30th March 2009, 17:52   #7
iraghava's Avatar
Thanked: 156 Times
Get the throttle body removed and cleaned properly. Also get the Idle Controller valve checked, that might be busted.
Old 30th March 2009, 18:23   #8
anurag_p80's Avatar
Thanked: 7 Times
I had/ have (it is still there, though intermittent) issue in my Palio 1.6. Check the air temp sensor/ lambda sensor. you might also want to check the TDC/ Crank sensor.
anurag_p80 is offline   Reply With Quote
Old 30th March 2009, 19:14   #9
Atlblkz06's Avatar
Can you give us more information?
* Car details - how old etc.
* Does this happen right after a cold start as well?
* Is it more pronounced when the engine is warm?
* At what RPM range does your engine idle when warm?
* Does the RPM drop when you turn on the A/C when the engine is warm and cold? (and what does it drop to)
Atlblkz06 is offline   Reply With Quote
Old 31st March 2009, 00:28   #10
iraghava's Avatar
Thanked: 156 Times
This also used to happen on my car for a while but that was done a front end shunt and broken mounting(s). Once I had that fixed, it never came back. Are you sure your car has had no shunts and the mountings are in good condition?
Old 31st March 2009, 01:22   #11
Sprucegoose's Avatar
Thanked: 40 Times
happens to mine too.
got an OHC type 1
i think its a compressor issue.
My car performance decreases drastically with the AC on and vibrates alot more with the AC on.
@ iraghava : what are shunts??
Sprucegoose is offline   Reply With Quote
Old 31st March 2009, 10:54   #12
ImmortalZ's Avatar
Thanked: 312 Times
Accidents. Crashes. Things that screw up the chassis.
Old 31st March 2009, 11:45   #13
Thanked: 40 Times
ahhh....
been there done that.
but vibration has started recently
Old 9th May 2009, 16:44   #14
ralstonraz's Avatar
Vibrations reduced drastically after the change of engine mounts. Getting my compressor changed. Lets see if it makes any difference.
Have got a quote of 9.5 k for a Sanden compressor. Anyone can get me a better deal?
Old 10th May 2009, 13:35   #15
ankitahuja's Avatar
Thanked: 46 Times
9.5 k is a fantastic deal. Hope the price is including the dryer bottle?
I will find out the current prices and post later.
Suzuki Kizashi: Common Steering Vibration Issue when Braking rockporiom Technical Stuff 64 15th January 2014 21:56
Weird issue! with my TYPE 1 honda D15! nitroxx Technical Stuff 1 27th September 2008 01:48
Difference between Type 1 and Type 2 Honda 1.5 gameonrwind The Indian Car Scene 7 8th August 2008 10:54
Modifiction of Type I M800 to Type II sathyaprakash Modifications & Accessories 17 3rd July 2007 21:56
esteem type 2 instrumentation in type 1 rdkarthik Modifications & Accessories 3 3rd February 2006 14:43
