Old 8th February 2009, 14:40   #76
Thanked: 253 Times
Originally Posted by Gurkha View Post
Mixing different coolant brands is not at all a good idea. MB, Porsche, Lexus specify their own brands and thats for a reason. Today's vehicle engine blocks use exotic alloy cocktails and the wrong coolant can put holes in them literally.
That is a rather definitive and extreme statement, Gurkha!
There is no evidence to support this.
Old 8th February 2009, 15:07   #77
greenhorn's Avatar
Thanked: 1,518 Times
that may probably be true about the MB and porsche engines. but for the cars that most people run here , like an m800 or an alto or my indica, I wonder if that's true
Old 8th February 2009, 15:17   #78
I standy by my contention or am I to assume the otherwise............that manufactuers are talking marketing. Its all about metallurgy here and the plain green ethylene glycol just doesn't cut it, different formulations with different amount of silica comes to play for alloys. If you are using cast iron block and head, then there is nothing to worry about. Some vehicles specify HOAT and they will void warranty if its not used. Honda and BMW use Nikasil, a silicon impgrenated alloy, silicon mixed with wrong coolant chemistry can lead to impending disaster.
Wrong coolant causes problems? - Automotive Message Forums
Wrong Coolant in 2002 Chevy Tahoe 4x4
Coolant Issues
Some reading on how using wrong coolant can ruin engine, headgaskets etc.
Gurkha is offline   Reply With Quote
Old 8th February 2009, 15:19   #79
Just read the links I posted, long term effects can be bad, also M800 and Indica both have aluminum heads. Why take the risk?
Old 8th February 2009, 15:22   #80
greenhorn's Avatar
all the above links lead to cases where different coolant types ( besides the regular green stuff) were recommended. In most cars here , the regular green stuff works just fine. the question here is , does using different brands of the green stuff cause a problem?
Old 8th February 2009, 15:34   #81
If its green stuff and the formulations are same, I wouldn't think so, however bear in mind, Toyota doesnt use green stuff, neither does Honda, Opel and many others. So its not as simple as it was earlier.
Old 8th February 2009, 18:45   #82
Thanked: 253 Times
Gurkha, with SPECIALLY formulated coolants/anti freezes maybe damage can result. The only varieties being sold here are the green and you can occasionally see the blue. I do not believe there is any evidence to show severe incompatibility issues with these, even in engines with aluminium heads.
In cars where coolant is a major issue, I expect there is a warning sticker advising the owner about the fact.
Old 8th February 2009, 20:43   #83
Toyota uses red, so does Honda, Opel, Skoda, MB use their own which is blue in color.
Old 8th February 2009, 20:54   #84
Thanked: 253 Times
Strangely, my Gypsy in 1994 and my Scorpio in 2006 came with blue coolant at delivery!
I have mixed green into my Scorpio already. Any reason to worry?
Old 8th February 2009, 21:11   #85
greenhorn's Avatar
maybe this info can be of help
Originally Posted by rkbharat View Post
Sunstar-Golden Cruiser comes in blue color for Service Center(with tags like for Tata/Maruti etc) and comes in green color in open market
Old 8th February 2009, 21:32   #86
Thanked: 253 Times
Thanks, Greenhorn. My question was more rhetorical than anything else!
I'm quite confidently going to keep mixing 'coolants' if occasion demands. Been doing it for many many moons!
Old 8th February 2009, 21:53   #87
R2D2's Avatar
Thanked: 2,043 Times
Actually Toyota now uses pink coloured premixed coolant which they call the SLLC 'super long life coolant'. Its drain interval is 160,000 kms. The red version had a drain interval of 80-100K kms.
My 2000 model MPFI Esteem's coolant was blue in colour
Rgds,
Old 8th February 2009, 22:20   #88
rranjith_kum's Avatar
Thanked: 17 Times
i gather from the previous posts that there is no issue, but some affirmation would be appreciated
all this time I was trying to make out reading the posts but I couldn't come down to a single point, however when I see one more person just like me I couldn't resist posting this !!
rranjith_kum is offline   Reply With Quote
Old 8th February 2009, 23:41   #89
mdesai_1981's Avatar
hi guys,
i have e small issue i have just purchased a NHC 2 months back and have also got it serviced (first service) exactly a month back.
all was well actually my mechanic cum driver (really trusted one) put in some normal water in the coolant reservoir before the first service as we were going out on a out station trip. after a couple of days i checked the coolant level (when the car was cold) it was a little above the maximum mark. i just ignored it as it was say 100 ml more than the max mark.
now today i was just checking my oil level when i noticed that there was a little spillage around the cap of the reservoir tank . i checked the entire car and discovered that the coolant had overflowed from the cap of the reservoir and that still the coolant was a little say 50 ml above the max mark. i checked the cap it was tight as usual and everything else seemed normal
i just want to know if this a sign to worry or just ignore it?
should i get a little collant drained to get it to exact maximum level?
mdesai_1981 is offline   Reply With Quote
Old 9th February 2009, 20:02   #90
Raccoon's Avatar
Thanked: 105 Times
Don't let anybody fill ANYTHING above the max. mark!! Its there for a reason!
HELP Urgent : White water stains on the windscreen nanu28 Technical Stuff 13 3rd March 2015 09:32
Accidently put water in Brake Fluid - Punto Diesel punto_ Technical Stuff 21 26th August 2011 10:33
Coolant Turns in to Water after 3 Months of Non-Usage johnruben Technical Stuff 7 24th June 2010 19:35
does coolant mix with dist. water evaporate 2fast4u Technical Stuff 32 11th June 2007 00:35
Water or Coolant? Team123 Technical Stuff 21 24th April 2006 08:57
