Old 9th February 2009, 20:11   #91
There are two marks in the coolant tank, hot and cold, so in case you need to top up, you need to do it according to engine temp, just not random, also top up should always be done with 50:50 water and coolant mix and just not water that will dilute the mix and reduce protection.
Gurkha is offline   Reply With Quote
Old 9th February 2009, 20:15   #92
mdesai_1981's Avatar
well everything is kind of sorted out. the cap was a little loose and say 100ml of water dilution will not make any difference . anyways thanx for the advice
mdesai_1981 is offline   Reply With Quote
Old 9th February 2009, 20:25   #93
Raccoon's Avatar
Thanked: 105 Times
Nopes... I mean at least not in my car. The markings are FULL and LOW. And the level is to be checked/topped up ONLY when engine is cool.
Old 9th February 2009, 20:42   #94
Thanked: 253 Times
With the engine cold, the coolant level is to be kept at LOW, not topped up.
Old 9th February 2009, 20:50   #95
In that case, yes, just top it up when engine is totally cold.
Old 9th February 2009, 20:57   #96
Thanked: 253 Times
Ah ah, there's scope for confusion here!
The FULL mark should be about halfway up the bottle. In such a case you might need to fill upto the Full mark with cold engine. If the full mark is more than halfway up, coolant will overflow with the engine at operating temperature.
LOL, what does the owner's manual say?
Old 9th February 2009, 21:09   #97
Raccoon's Avatar
Thanked: 105 Times
^^^I am echoing exactly what the manual says! And that is - maintain coolant between FULL and LOW... and check this when the engine is cold.
And I think the mark is above the halfway mark... but not sure. Will check this soon.
Old 9th February 2009, 22:01   #98
When the coolant expansion tank is filled to the cold mark with the engine cold, it will go up the cold mark when the engine comes to running temperature, however, it won't overflow.
Old 9th February 2009, 23:07   #99
Raccoon's Avatar
Thanked: 105 Times
Sorry, what I said in the last post is a bit incomplete. It should be:
Maintain coolant between FULL and LOW. Check only when engine is cold and top-up to the FULL mark.
Old 7th April 2009, 02:26   #100
Hey,my service guy just filled up fully with Non-Amine collant.Its blue in colour.NO water was added.Is that fine?
binoyjude is offline   Reply With Quote
Old 7th April 2009, 23:44   #101
R2D2's Avatar
Thanked: 2,042 Times
Check the container. If it says 'pre-mix' you dont need to add water. If it is concentrate then you need to dilute it in the ratio recommended by your car's mfrs OR as a second choice the coolant mfr. Normal dilution ratio is 1:2 i.e. 1 part coolant to 2 of water OR 1:1.
If your mechanic added concentrate without diluting it then it was a bad idea. Just add some water to the expansion bottle but never exceed the Max mark (cold engine) . Also, use clean drinking water or better still distilled water for dilution.
Rgds,
Old 8th April 2009, 16:08   #102
Thanked: 245 Times
Highest boiling and lowest freezing point is achieved by using a ratio of 70:30 (coolant: water). If its not premixed one.
Old 8th April 2009, 18:23   #103
Thanked: 253 Times
Not really. 80-20 would give higher boiling point and lower freezing point!
Old 8th April 2009, 18:27   #104
Thanked: 420 Times
Classic clash of titans awaiting links and citations for claims and counter claims.
amitk26 is offline   Reply With Quote
Old 9th April 2009, 17:49   #105
Thanked: 245 Times
There is no clash only a splash
link from a Mfg, read Ans A and Ans I (click ont the chart link)
Just search and you will find many more.
HELP Urgent : White water stains on the windscreen nanu28 Technical Stuff 13 3rd March 2015 09:32
Accidently put water in Brake Fluid - Punto Diesel punto_ Technical Stuff 21 26th August 2011 10:33
Coolant Turns in to Water after 3 Months of Non-Usage johnruben Technical Stuff 7 24th June 2010 19:35
does coolant mix with dist. water evaporate 2fast4u Technical Stuff 32 11th June 2007 00:35
Water or Coolant? Team123 Technical Stuff 21 24th April 2006 08:57
