Old 9th April 2009, 17:54   #106
Thanked: 252 Times
Originally Posted by dadu View Post
There is no clash only a splash
link from a Mfg, read Ans A.
Just search and you will find many more.
LOL, that was a jibe! Since ONLY boiling point and freezing point were mentioned in your post, I pointed out that both would be improved with an 80-20 mix! That is a fact. It is, of course, not the recommended way to use since other properties suffer.
HELP Urgent : White water stains on the windscreen nanu28 Technical Stuff 13 3rd March 2015 09:32
Accidently put water in Brake Fluid - Punto Diesel punto_ Technical Stuff 21 26th August 2011 10:33
Coolant Turns in to Water after 3 Months of Non-Usage johnruben Technical Stuff 7 24th June 2010 19:35
does coolant mix with dist. water evaporate 2fast4u Technical Stuff 32 11th June 2007 00:35
Water or Coolant? Team123 Technical Stuff 21 24th April 2006 08:57
