Old 27th September 2008, 01:14   #1
nitroxx's Avatar
Thanked: 26 Times
Default Weird issue! with my TYPE 1 honda D15!
Guys, I need you help regarding this certain issue that has cropped up..
My car runs fine on a regular basis and I drive it around for about 30 -40 kms everyday.
However, I suddenly faced a problem 2 Sundays ago with it in the evening,it had rained prior to taking the car out for a drive.It suddenly stalled and the check light refused to go for about half an hour.
During this period the car would crank but the engine would not kick in at all, thus it couldn't start.
After half an hour it turns out the car started normally and the check light disappeared and didn't give me the same problem until last Sunday again and that too for the same period of time.I haven't had the same issue since then but I'm concerned.
What do you guys reckon it could be?
Apart from the map sensor having issues, and moisture on the ECM due to air conditioning? Please Advise. Thanks.
nitroxx is offline   Reply With Quote
Old 27th September 2008, 01:48   #2
Ford Rocam's Avatar
Thanked: 16 Times
If it happens again try with an another ECU of same spec.
Ford Rocam is offline   Reply With Quote
Swift Type 1 and Type 2 Vajo The Indian Car Scene 19 15th January 2010 18:18
Vibration issue in Honda City - type 1 ralstonraz Technical Stuff 17 20th May 2009 19:19
Difference between Type 1 and Type 2 Honda 1.5 gameonrwind The Indian Car Scene 7 8th August 2008 10:54
Modifiction of Type I M800 to Type II sathyaprakash Modifications & Accessories 17 3rd July 2007 21:56
esteem type 2 instrumentation in type 1 rdkarthik Modifications & Accessories 3 3rd February 2006 14:43
