Old 9th October 2008, 22:55   #16
gpa
gpa's Avatar
Thanked: 273 Times
Hi chetans,
You seem to be stuck with mechanics who don't seem very knowledgeable. It could be a wheel bearing problem, but considering the mileage you've covered (9,000 KMS) its too short a time for that to happen.
My advice would be to get the car checked at another MASS.
Cheers,
gpa
Old 10th October 2008, 11:49   #17
SLK
SLK's Avatar
Thanked: 185 Times
Originally Posted by chetans View Post
i didnt get what to check while "just try rotating the tyres". i have been told by service guy that there is somekind of "out" in both the front wheels. does it mean i need to replace them in this case?
By rotating I meant to put the front tyres at the rear and the rear at the front, that should take care of front tyre noises.
As a matter of fact, My honda City makes some sound from the front left wheel, something like the bearing!!, but Honda service center confirmed that the bearing is Ok, and the noise is b'coz of one bad tyre. [driven 4 months after that, didn't get time to rotate )
SLK is offline   Reply With Quote
Old 15th October 2008, 13:20   #18
Question
Hi SLK,
How much have you clocked on your ODO? Does the NHC need a mandatory bearing change at 40k KM? How much do the Honda guys charge per bearing?
Mine is nearing the 35K service and I already had my RHS front wheel bearing replaced did it outside as the *** guy quoted 4.5k for changing a bearing.
battada is offline   Reply With Quote
Old 15th October 2008, 18:22   #19
SLK
SLK's Avatar
Thanked: 185 Times
Originally Posted by battada View Post
Hi SLK,
Mine's done 35k as of now, but the sound's been there since 25k or 30k (don't remember). I don't know how much bearing change costs because honda had claimed it to be ok!
That sound started right after the 25k or 30k service, so sent it back to honda. They said its because of tyre, since they rotated that.
Or maybe there's a catch, the car was in warranty then and they wanted to avoid it!
Old 26th October 2008, 10:15   #20
Thanked: 143 Times
Gurus, is the thread below related?
http://www.team-bhp.com/forum/indian...en-estilo.html
Please go through the link to livemint news in the above thread.
Old 27th October 2008, 21:12   #21
tush's Avatar
@chetans
See if the following information helps your issue.
Maruti Suzuki replacing part in 28,500 cars - Home - livemint.com
tush is offline   Reply With Quote
Old 28th October 2008, 12:56   #22
chetans's Avatar
Thanked: 73 Times
@tush, @backseatdriver,
thanks for sharing the info.
looks to be the same problem.
i had got my front wheel shaft replaced but was never informed by the service guys that there was problem in the original part.
i would preferred to get this info from the serivce guys in the first place :(
chetans is offline   Reply With Quote
Maruti WagonR over Hyundai Eon? EDIT : Bought WagonR with ABS / Airbags BoneCollector Hatchbacks 35 22nd May 2015 11:49
Only a WagonR can replace a WagonR ! From F10D to K10B.. DCEite Test-Drives & Initial Ownership Reports 27 19th April 2014 23:02
WagonR or Swift?(calling swift and wagonR owners) rajshenoy Hatchbacks 43 29th March 2007 09:54
WagonR problem cooldude1988765 Technical Stuff 7 26th February 2006 03:44
