Old 28th September 2008, 19:27   #1
DCEite's Avatar
Thanked: 607 Times
Unhappy 04' WagonR - Poor FE, Hard clutch and judder
My 2004 WagonR is begining to give really pathetic fuel efficiency. I calculated tankful to tankful and its 10.5 kmpl in city driving with 90% AC.
Some points i would like to share.
1. My office is about 4 kms from my home. Usually drive in 2nd/3rd gear, but while coming back, i take the highway for about 1 kms where i drive in 5th. Total distance traveled per day is around 8.5 kms ( the highway route is a bit longer).
2. My clutch has gotten so heavy that I even find Diesel cars like Swift D and Vista easier on left leg.
3. There is occasional judder while releasing clutch from 1st gear, and sometimes in reverse.
4. My car as run 43k and still runs on factory tires, barring one, which was replaced 5k kms ago.
Is my poor FE related entirely to these factors? If not, what else should i keep in mind while giving my car for next service.
DCEite is offline   Reply With Quote
Old 28th September 2008, 20:34   #2
nkapoor777's Avatar
Thanked: 91 Times
I am in the exactly same position DCEite. My Wagon R is Oct 2004 registered and the tank to tank FE is 10.3-11.0 km/l (90% AC). The clutch isn't that bad but definitely stiffer than before but no extraordinary judders. It has run 52K and has had a tyre replacement. It now runs on Michelin XM1's (155/65/R13). Another similar twist of fate: Its driven in pretty heavy city traffic for approx 15 kms a day.
However, I have other factors that could be influencing the FE. the car is now driven exclusively by wifey. Although I am pretty confident she is a decent driver. I wrote the last line as insurance for the time my wife reads this post.
Experts, please suggest potential causes of trouble.
nkapoor777 is offline   Reply With Quote
Old 28th September 2008, 21:09   #3
nitrous's Avatar
Thanked: 285 Times
All the three symptoms say just one word. Clutch!
Old 29th September 2008, 12:05   #4
DCEite's Avatar
Thanked: 607 Times
You mean the clutch plate?
Old 29th September 2008, 12:11   #5
snaronikar's Avatar
Thanked: 23 Times
IMO, its time to think for a newer vehicle. What Say? OR replace the clutch.
snaronikar is offline   Reply With Quote
Old 29th September 2008, 12:22   #6
amit_mechengg's Avatar
Thanked: 1,556 Times
my alto has a similar problem but there is no clutch slippage, its just that the pressure plates have become hard.
43k kms is the deadline or maruti clutch on alto and wagaon R , please get the clutch overhauled. will cost you around 4k
Old 29th September 2008, 12:29   #7
Jaggu's Avatar
Thanked: 8,671 Times
Have you done the full job that MUL recommends at 40k kms?
Old 29th September 2008, 12:56   #8
DCEite's Avatar
Thanked: 607 Times
Whats that full job? Could you shed more light on this please.
Old 29th September 2008, 13:30   #9
Technocrat's Avatar
Thanked: 2,589 Times
I dont know the traffic conditions in your city but most of the Wagon R owners I know of get only slightly better mileage (around 12) besides you drive in lower gears.
Also clutch judder is a known thing for which A.S.S. would have a solution.
What Jaggu means is the major service at 40k you can get the details from your manual.
Old 29th September 2008, 18:00   #10
Thanked: 103,359 Times
I'd throw a party if all my cars start giving 10.5 consistently
On a serious note, this:
may have something to do with it. Short distances = Low FE. Generally, the engine would have covered a lower distance @ optimum temperature. Plus, the averaged speed and stops (traffic lights etc.) would be more.
You also need to have your pressure plates looked at.
Old 29th September 2008, 19:08   #11
bblost's Avatar
Thanked: 6,972 Times
I generally get an avg of 13+ in my Wagon R.
But this month being Ramzan I drive about 1 km one way to the mosque with my f-i-l.
This is an over crowded road and can take me close to 5 mins to cross it..
Milage this month is down to 12.5.
This is the only thing that has changed in my car over last months driving pattern.
btw my office is 13kms from home.
Old 30th September 2008, 10:11   #12
DCEite's Avatar
Thanked: 607 Times
Thanks for the inputs.
I too suspect my low running and clutch as the main culprits. The idle rpm is high during most of the time, which suggests the engine hasn't warmed up adequately during the day.
@bblost Thats a very good FE you are getting. I guess you mostly drive on ring road with 4th/5th most of the time? I too used to get around 14 when i used to drive the car to my college which was 30 kms away and mostly signal free ring roads of Delhi.
Old 30th September 2008, 10:17   #13
bblost's Avatar
I once got 19 in my wagon R.
Highway non stop drive for about 300 kms.
and you are right in the city my drive is generally traffic free on decent roads.
In the wagon if you want good milage don't cross 80.
After that the absence of aero dynamics brings down the milage real bad.
Helps if you wax the car before hitting the highways.
Clutch judder & vibrations scuderiaferrari Technical Stuff 122 7th June 2018 12:27
Ford Fusion Clutch Judder sridhar-v Technical Stuff 10 31st March 2012 09:48
Swift Diesel Clutch Judder! humyum Technical Stuff 11 29th June 2011 12:33
State of plastic fitments on cars : Poor quality or poor maintenance? libranof1987 Technical Stuff 10 15th January 2011 21:14
