Closed Thread
Old 25th March 2005, 20:43   #1
Default K&N filter
hey guys ,
have any of you fitted filters on your 1.6 palios???
i could use some help with installation and what type conical or stock replacement etc... in bangalore.
thanks
jayanth_997 is offline
Old 26th March 2005, 02:22   #2
hey jayanth..well i have installed K&N filter's in 2 palio's well the 3570 universal conical filter does the trick for me..its perfect doesn'y need too much alteration..you just disconnect the air box and unistall it..well the palio comes with this flexi pipe which leads to the throttle body..what you can do is once the box is dismounted...make a 3 inch pipe with powder coating from the inside...an connect one end of it to the flexi pipe and on the other end you hav the K&N filter..its a perfect simple setup..will try n post some pictures..cheers..>!!
dragger is offline
Old 26th March 2005, 08:35   #3
Rudra Sen's Avatar
Thanked: 4,294 Times
http://www.team-bhp.com/forum/showthread.php?t=4042 (K&N Filter fitment!!) For similar discussion.
This thread is closed.
Rudra Sen is offline
Closed Thread
Ikon Fuel Filter : OEM is cheaper than After-Market filter RM2488 Technical Stuff 13 28th June 2012 11:39
Is Oil filter and Fuel filter different? finneyp Technical Stuff 10 25th July 2008 11:45
15" alloys & tyres, K&N conical filter, Iridium plugs and Splitfire cables for sale. karthik247 Shifting gears 9 24th January 2007 20:33
K&N Filter and Free flow exhaust gbharani Modifications & Accessories 2 19th April 2004 23:46
