Old 24th February 2009, 07:33   #16
Vivek.Martin's Avatar
I don't think its the tyres. What are the specs of your tyre? And are you on alloys?
Actually, even my CRDi has started vibrating at exactly 110kmph.
Getz annoying at times (pun intended).
Anyways, I guess we are yet to find a reason/cure for this...
Vivek.Martin is offline   Reply With Quote
Old 24th February 2009, 10:21   #17
It is a Michelin BF Goodrich 195/60 R14. Actually i am saying tyre only because the vibrations seem to be fading away slowly.
ShyamSCrdi is offline   Reply With Quote
Old 26th February 2009, 10:35   #18
Seems there is a cure to the steering vibrations. Refer KPZEN's ownership thread (post by Naman)
Old 17th March 2009, 12:21   #19
It is not just steering vibrations. There is a weird brrr sound too which comes bundled along with this. It also happens at low rev ranges :(
Old 29th August 2009, 17:23   #20
I had this wierd brrr.... noise which appeared to come from the dash in my Getz CRDi at about 1,400 rpm on the tacho. At first free service, this was traced to a loose spring in the rear view mirror.
cnaren is offline   Reply With Quote
Old 30th August 2009, 12:50   #21
Was this the rvm outside or the one inside?
Shyam
Verna Crdi Vs GetZ Crdi. EDIT : Finalising on Getz! aks_karthik Hatchbacks 74 17th May 2009 10:22
Does selling 06 Getz GLE and buying a Getz CRDI or GLX with ABS make any sense? rm_arjuna Hatchbacks 16 26th April 2009 21:30
vibrations in getz crdi Suresh_vin Technical Stuff 1 15th February 2009 14:55
Esteem steering - vibrations and heaviness gaurav.28ch Technical Stuff 1 14th January 2009 15:00
Optra - steering vibrations over 80 km/h Boom Shiva Technical Stuff 10 23rd May 2006 11:58
