Technical Stuff Discussions related to the technical side of cars (Vtec, ABS, Intercoolers et al).
Thread Tools
Old 30th September 2008, 11:57   #1 (permalink)
Default Oil patch below Ignition Coil
Hi Fellow BHPians,
This morning while getting CNG filled in my car (WagonR - 2003, 83K on ODO), I observed a small oil patch below one of the ignition coils. I checked whether the cap from where the engine oil is filled is loose and it was intact. I am pretty sure that the oil spill was not from there.
I haven't observed this behaviour ever before.
My query is:
Is this something which I can live with or is this the signal of something big coming .
If I visit M.A.S.S. for a check, what exactly should I ask them to do/look for ?
Khandelwal is offline   Reply With Quote
Old 30th September 2008, 22:23   #2 (permalink)
gd1418's Avatar
Does WagonR have more than one ignition coils? AFAIK, it is fitted with DDLI and that is one single integrated unit.
Originally Posted by Khandelwal View Post
Hi Fellow BHPians,
__________________
Royal Enfield Bullet 1962
All Black 1998 Safari 4x4
All Black 2004 Scorpio GLx
Old 1st October 2008, 10:47   #3 (permalink)
Yes, there are two ignition coils - each attached to a couple of spark plugs.
I am sure as I have recently got one of the ignition coils replaced. The patch is visible below the other coil quite near to oil filler cap.
Old 13th March 2009, 22:14   #4 (permalink)
Exclamation Ignition Coil on Fusion Replaced...
Ignition coil is not such a part that has some oil or replaceable parts. If it becomes useless then its completely replaced. If there is some slight problem then the car will vibrate as my car used to do from 2 yrs. And when one of the chambers stoped proper current flow then engine started missing in one of the cylinders. Its not repairable, it doesnt consist of many small parts and it is to be changed when shorted. what you can do is clean the oil. And mostly coils get destroyed due to water splashes when hot.
HNarula is offline   Reply With Quote
Old 13th March 2009, 22:54   #5 (permalink)
nitrous's Avatar
You might need an O-ring/oil seal at the coil replaced.
__________________
Han:The Red Evo's yours
Sean:What do u mean?
H:U're representing me now...What did U think, I'm gonna let you roll in a hyundai?
Thread Tools
Looking for a 12v Twin output ignition coil aruncheloor Motorbikes 0 5th August 2009 22:46
W124 Mercedes benz E220 ignition coil msaudf Technical Stuff 2 18th May 2009 21:43
ikon ignition coil bought from ebay - better quality? silver_shadow Technical Stuff 9 22nd November 2008 11:47
Anybody Using aftermarket ignition coil & plug wires? finetuning Modifications & Accessories 0 27th March 2006 22:41
MSD Spark Plug Wires & Ignition coil Kaizer Sozay Modifications & Accessories 11 16th December 2005 09:12
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599
