Old 21st November 2005, 04:16   #16
v1p3r's Avatar
Thanked: 27 Times
Since you're in Bangalore, go for Shell, eyes closed. I know quite a few BHPians who swear by it!
Old 10th January 2006, 19:50   #17
Ketan's Avatar
Thanked: 180 Times
Default Fuel for 1.9D
Do we have many Shell outlets here in Bangalore!!
is that the better choice for Palio 1.9D??
Thanks.
Ketan is offline   Reply With Quote
Old 24th April 2006, 01:26   #18
Ketan's Avatar
Thanked: 180 Times
Hey Guys,
there are about 6 outlets of Shell in Bangalore and I have heard that the new one is opening at Old Madras Raod soon.
Have a look at the following link for existing 6 outlets in Bangalore; I have been to the one at Vittal Malaya Road today and it feels good.
let me see if I feel any noticiable diff compared to HP Turbojet.
I'm not sure about the sulpher content or the cetane value for this diesel but they told me that this is high speed diesel.
There is one on Hosur Road as well and that is 10KMs from silk board junction.
You can have a look at the following location for all six locations.
http://www.shell.com/home/Framework?...ator_0504.html
Old 24th April 2006, 09:06   #19
DRC
DRC's Avatar
Thanked: 48 Times
Fiats idle at 800rpm with out AC and 860 rpm with AC, after warm up. This is set by ECU not by a screw!
If you drive at very low rpms, any engine is bound to knock..there isn't ecu can do about it, as the air available will be very less, (closing the throttle)
While driving slow, raise the engine a bit, say 1500 and use clutch judiciously
DRC is offline   Reply With Quote
Front facing Vs Rear facing Vs Side facing seats in MUVs/SUVs ritz830 The Indian Car Scene 20 11th July 2009 16:55
Facing problem with Getz ignition wmax Technical Stuff 6 13th February 2008 12:58
Help!! Alto facing a weird vibration problem wanderluster The Indian Car Scene 0 8th September 2007 01:15
facing problem in my accord. prateek Technical Stuff 39 17th June 2007 12:34
facing problem with my turbo setup. prateek Technical Stuff 6 2nd June 2007 00:46
