Thread Tools
Old 26th March 2005, 22:48   #1 (permalink)
amitverma's Avatar
Question Facing a problem in Palio 1.2 engine
hey guys i own a palio 1.2 sport abt 8 months old. i have been facing a lil problem with it. actually the engine rpm falls below 1000 at idle. is it bad news for the engine?
i think it should be a constant 1000.
secondly, if i rev the engine a bit (in neutral) the rpm needle goes up comes down below the 1k mark (say abt 800) and comes back up to settle to something abt 900 or so rpm at idle. what is wrong with it.
am i experiencing knocking with the engine. is the engine in trouble?
amitverma is offline   Reply With Quote
Old 26th March 2005, 23:01   #2 (permalink)
SLK
SLK's Avatar
idle rpm is.. 800-900... for most cars.
my Alto which has a rpm meter, behaves the same as described by you.
engine knocking is something.. not directly related to this.
so when does your engine.. knock?... high gear low rpm?... or at high rpm?
my wagonR knocks at high rpm.... but continuous use of 91-93 octane fuel has made a lot of difference... now it knocks... only if I cross 5000rpm.
__________________
Č╠╣€€Я$
$£Қ
SLK is online now   Reply With Quote
Old 26th March 2005, 23:04   #3 (permalink)
Shan2nu's Avatar
What time of the day does this happen? It's common for the engine rpm to fall below 1000 after the engine gets warmed up. The Vtec for example idles at 800 rpm.
Depends on how the car has been tuned.
Shan2nu
__________________
VTEC flyby - youtube.com/watch?v=1AhWJlVRPqE
Old 26th March 2005, 23:16   #4 (permalink)
amitverma's Avatar
the car hasn't been tuned...its totally stock.
someone told me that mpfi units do not knock at all.
actually in the evening today, when i was reversing the car to get out from my house, i sensed a bit knocking. what is wrong?
Old 26th March 2005, 23:22   #5 (permalink)
Shan2nu's Avatar
They won't knock only if you have knock sensors on your car. Some mpfis don't come with knock sensors.
Are you sure it was a knocking sound? Coz sometimes, when the engine gets bogged down (when the revvs drop too low), the engine does give out a knocking sound.
Shan2nu
__________________
Old 26th March 2005, 23:50   #6 (permalink)
amitverma's Avatar
actually the rpm did drop too low but the question is why did it?
while reversing when i had to press the accel pedal i had to do it bit harder than i did usually. i wanted to know why.
actually my place where i have to park the car is a bit cramped. so often i have to ride the car in to the parking place with clutch so as to not to touch the bumper to the wall.
do u think that caused the problem.
as my 12th boards are getting over on monday i was thinking abt sprucing up the performance with a k&n filter and a sports exhaust. but with this problem over my head i am confused.
do you think i should take it to the dealership? is it serious. especially since the car is only 8 months old.
Old 27th March 2005, 00:52   #7 (permalink)
SLK
SLK's Avatar
well.. I don't see any problem with your car!..
drive it a bit after your exams..... it'll be good again.
I have in past managed to use 1 tank of fuel for 3 months..... my car knocked!!
and now-a-days.. I do 80-100km.. per day (OMG I need diesel!!)... and its much better.
so if your car is being driven very rarely ..drive your car a lot.. it'll feel much better.
__________________
Č╠╣€€Я$
$£Қ
Old 27th March 2005, 01:05   #8 (permalink)
drifter's Avatar
Like others have mentioned...
its perfectly normal for an engine to behave like that.
As far as the knocking is concerned...try refuelling from a different outlet, bad quality fuel can result in engine knocking.
Drifter
__________________
Slow Everything Down And Feel Like God - Tata Safari
drifter is offline   Reply With Quote
Old 27th March 2005, 01:30   #9 (permalink)
amitverma's Avatar
thank you guys...
so glad i joined in here.
actually yes the car was driven a lot less than usual due to my exams. will take care in future. c ya all around.
Old 27th March 2005, 01:59   #10 (permalink)
Shan2nu's Avatar
Usually while reversing or crawling in 1st, it's very important that you use the right amount of clutch pressure. Too much pressure will reduce the amount of engine power getting transfered to the wheel and using very little pressure can put load on the engine, which requires you to increase throttle input in order to keep the engine running.
Shan2nu
__________________
Old 1st April 2005, 19:53   #11 (permalink)
Default Nothing Wrong
fiat vehicles have got very good ECU I mean finely tuned 16/32 bit microprocessors. For that matter my siena 1.6 which is equipped with 32 bit processor idles at 600 rpm. When the engine is started from cold the rpm raised to about 1200 and settles down after a minute or two to 600.
dsnreddy is offline   Reply With Quote
Old 20th November 2005, 15:09   #12 (permalink)
Ketan's Avatar
Default Should be okay
I agree,
I have recently bought a Palio 1.9D and the engine idles between 900-1000 RPM.
Initially I thought its too much rev settings; but the guy at the showroom told me that this is a torqy engine and it will be like that only. Everything is controlled by ECU and is been set by manufacturere only; that probably cannot be considered as a minute settings and cannot be altered easily.
but yes, engine idle RPM is 900-1000 and if i switch on AC it goes a lil high and drops back to the same position immediately.
Guys, can you please let me know where should I fuel it regulary?
I have two options,, IOC extra mile or HP turbojet,, which one is high octane and good for Palio 1.9D?
However, I have seen very few IOC outlets here in the area I'm residing at. but I dont mind to find a good IOC if thats the preferred one as I alway fond of choosing good food so as my car.
Ketan is online now   Reply With Quote
Old 20th November 2005, 16:36   #13 (permalink)
ananthkamath's Avatar
Diesels dont need high octane fuel; the rating used for diesel is cetane not octane; even so I dont think the fuels you mentioned have differences in cetane. They only probably have lower sulphur and some additives supposed to smoothen out running.
__________________
Miata Turbo Is GO!!
ananthkamath is offline   Reply With Quote
Old 20th November 2005, 20:49   #14 (permalink)
lamborghini's Avatar
They aren't exactly high octane but low sulphur fuel.
Technically, they both are the same thing b ut we use turbojet on the merc.
__________________
¢нєєяѕ
ℓαмвσ
lamborghinirules@gmail.com
lamborghini is offline   Reply With Quote
Old 21st November 2005, 02:24   #15 (permalink)
nitrous's Avatar
Yeah, Turbojet is a good bet. I've never tried IOC xtramile. So, can't say .
__________________
youtube.com/watch?v=FiVicNOA3bY
nitrous is online now   Reply With Quote
Thread Tools
Facing problem with Getz ignition wmax Technical Stuff 6 13th February 2008 11:58
Help!! Alto facing a weird vibration problem wanderluster The Indian Car Scene!! 0 8th September 2007 01:15
facing problem in my accord. prateek Technical Stuff 39 17th June 2007 12:34
facing problem with my turbo setup. prateek Technical Stuff 6 2nd June 2007 00:46
Problem With The Engine Rpm In Palio 1.6 After Lpg Conversion HAFI Technical Stuff 2 9th April 2007 11:43
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461
