Old 9th November 2008, 01:03   #16
arpandiv's Avatar
Thanked: 27 Times
does this occur when you step off the accelerator ?
arpandiv is offline   Reply With Quote
Old 9th November 2008, 01:07   #17
amit_mechengg's Avatar
Thanked: 1,541 Times
yes when in city i accelerate and then when i put my feet off the accelerator then i hear this sound. i dont hear this while accelerating.
Old 9th November 2008, 01:16   #18
bigdad's Avatar
Post Deleted by the Team-BHP Support : SMS / Slang is STRICTLY prohibited on this community. We would much appreciate your using full & proper english in posts, for the benefit of other forum users.
Please view our board rules carefully before proceeding any further.
bigdad is offline   Reply With Quote
Old 9th November 2008, 01:16   #19
Blue Thunder's Avatar
Thanked: 330 Times
looks like engine tune-up needs to be done : this is probably the sound of the engine backfiring.
Blue Thunder is offline   Reply With Quote
Old 9th November 2008, 01:18   #20
do u mean to say misfiring? mine is alto 800 cc MPFI engine, i doubt there is much scope of tuning in this!!
Old 9th November 2008, 10:40   #21
arpandiv's Avatar
Thanked: 27 Times
have you got engine de-carb ?
I hope its not a leaky exhaust valve.
Old 9th November 2008, 19:04   #22
alpha1's Avatar
Thanked: 967 Times
Leak in exhaust pipe.
Old 9th November 2008, 19:39   #23
gd1418's Avatar
Thanked: 656 Times
get the injectors cleaned buddy..
Old 9th November 2008, 23:14   #24
is it that my exhaust is blocked, because the same thing had happened with my bike and the silencer had got clogged. do i need exhaust cleaning?
Old 10th November 2008, 11:05   #25
Thanked: 244 Times
Most probably a ruptured joint in the exhaust, put it on a ramp and check.
Old 10th November 2008, 11:11   #26
adman77's Avatar
The same thing happened with my car after I got a FFE. Changed the FFE thrice after that, but the sound remains.
adman77 is offline   Reply With Quote
Old 10th November 2008, 22:50   #27
Thanked: 330 Times
Exclamation
There is the possibility of misfiring even in the case of MPFI engines with ECU : as long as it is spark ignited, this possibility exists. There could be something wrong in the ECU, which could be sending the charge at the wrong time to the sparkplugs.
I am giving this as a likely cause, since you have mentioned it happens only while decelerating , and not all the time.
Anyway, time to get it examined at a good garage, since continued running in this condition will deteriorate the engine in the long run.
Old 10th November 2008, 23:48   #28
veyron1's Avatar
Thanked: 37 Times
Shan2nu's right. That "misfire" is technically due to an overtly rich/lean mixture/AFR at zero throttle.
@Cyrus43: Technically, the engine is never "zero-fuelled". Even at zero-throttle, the engine receives enough fuel to idle. Although the TB is at zero degrees, IACV supplies minimal air and the injectors (or in this case, carb), fuel. When that fuel does not receive enough air to supplement it's combustion, unusual combustion such as this "popping" happens.
This phenomenon is far more apparent in carbs, giving the impression of "tuned FI's".
@sumeet: Check your idle solenoid.. get your carb serviced, and replace the primary jet & primary & secondary needles, if necessary.
veyron1 is offline   Reply With Quote
Old 11th November 2008, 00:17   #29
ya my idle solenoid is having problems currently as the throttle body is clogged due to K&N filter passing on dirt in it. while idling the rpm fluctuates.
so it is due to this i am facing the exhaust problem?
Old 11th November 2008, 10:20   #30
rdkarthik's Avatar
Thanked: 11 Times
No. Conditions at zero throttle and RPMs above a certain limit (~2000) will enable a fuel-cut operation to cut emissions and increase FE. All modern day cars have this feature.
rdkarthik is offline   Reply With Quote
Santro Engine Dies When Decelerating - NOT ALWAYS vigsom Technical Stuff 11 11th March 2015 15:04
Indigo DICOR 3rd and 5th gears popping into Neutral automatically. wanderernomad Technical Stuff 3 8th April 2011 22:27
Ultima GTR-640! Fastest accelerating and decelerating production car Gordon The International Automotive Scene 3 4th August 2005 19:02
