Old 2nd October 2008, 10:50   #1
sumeethaldankar's Avatar
Thanked: 1,158 Times
Default Popping Sound from Exhaust while decelerating
My 800 with a carb engine experiences a popping sound from the exhaust
mostly while decelerating in 2 gear.Any ideas what could be the cause of
the same?
My cars equipped with a Automech exhaust,is this common for Free Flow
Exhaust?
sumeethaldankar is online now   Reply With Quote
Old 2nd October 2008, 11:17   #2
ilangop's Avatar
Thanked: 591 Times
It should be due to some misfire while you suddenly decelerate. It is common in many Premeir 118 NEs too. You can get the timing and the carburettor air and idle screw settings checked. This also happens when the idle speed is too too low.
ilangop is offline   Reply With Quote
Old 2nd October 2008, 11:19   #3
amitpunjani's Avatar
Thanked: 101 Times
hi buddy
Get the ignition timing checked.Noramally the backfiring occurs in case there faulty ignition timing
Amit
amitpunjani is offline   Reply With Quote
Old 2nd October 2008, 19:29   #4
dustDevil's Avatar
Same problem with my automech equipped Carb Zen.
The probem started after a regular service. The mechanic says a tune-up will get rid of it, but I'm still to find time. I'll update once its done.
dustDevil is offline   Reply With Quote
Old 2nd October 2008, 22:00   #5
Hey dustDevil do let me know the outcome of your car's tune up job.
thanks
Old 3rd October 2008, 00:36   #6
Shan2nu's Avatar
Thanked: 89 Times
Popping sound in the exhaust while decelerating is called "afterfire", generally caused due to a rich mixture. Get the AFR tuned by your mech. This should solve the prob.
My VTEC has this as well (running rich due to faulty O2 sensor).
FE has gone down a bit but interestingly the performance of the car is excellent.
Checkout the afterfire on this beast (sounds like diwali fire crackers) -
Shan2nu
Old 3rd October 2008, 00:51   #7
Thanked: 152 Times
It is caused by underfueling. When you suddenly leave the throttle at higher revs, the ECU stops feeding Petrol. Thus it is basically non fueled combustion. Also, It could be due to a leaking intake valve.
Cyrus43 is offline   Reply With Quote
Old 3rd October 2008, 01:34   #8
adi99's Avatar
Exactly! This is how I used to get my problem rectified with my 99 Zen Carb. I have the muffler in my zen which make noise, so you can easily make out the misfire! Not a big issue my friend, few minutes and the problem is solved
adi99 is offline   Reply With Quote
Old 3rd October 2008, 01:35   #9
shrivz's Avatar
Thanked: 92 Times
My baleno's been "afterfiring" after the 100,000km mark when the guys at MASS changed the timing belt. Now, I believe its a timing issue.. could anyone shed some more light on this, whether its due to too retarded igniting timing, or too advanced?
shrivz is offline   Reply With Quote
Old 6th October 2008, 13:11   #10
n_aditya's Avatar
Thanked: 2,780 Times
I remember seeing a Nissan sedan in Blore which had a similar afterfire and loved it. It was a series of purr purr sounds followed with some sparks from the tail pipe when downshifted.
Any ill effects of this state of tuning?
Old 21st October 2008, 21:07   #11
Samir Taheer's Avatar
Thanked: 123 Times
I would get the Timing checked - If the mechnic says its spot on, ask him to retard it (i think) a bit. See if it makes a difference. The exhaust could have altered the amount of back pressure required and so you have the exhaust gas flowing out of the cylinder faster than is required - again i think.
I wouldnt have thought it has any adverse effects. A friends been running his gypsy king like that for years.
Never been to automech - but have they ever proved their exhausts?
Samir Taheer is online now   Reply With Quote
Old 21st October 2008, 21:08   #12
Thanked: 123 Times
Cyrus - its a Carbed 800 - Wouldnt have thought theres an ECU.
Old 22nd October 2008, 08:58   #13
pranavt's Avatar
Thanked: 274 Times
Love this sound, is this normal on all FFE cars or do you need to tune/change something to get it?
Old 22nd October 2008, 10:19   #14
rdkarthik's Avatar
Thanked: 11 Times
Popping through the exhaust is usually a combination of lean (at times rich )mixture and retarded timing.. On some higher end cars features like launch control, anti-lag, etc can cause similar effects.
rdkarthik is offline   Reply With Quote
Old 9th November 2008, 00:57   #15
amit_mechengg's Avatar
Thanked: 1,556 Times
Default Exhaust bursting sound from beneath the car-Help
seems as my alto is nearing 40k kms, so many problems are arising. since yesterday i am hearing strange "Sat" "Sat" bursting sound from beneath my car.
its like the same sound that occurs on bikes when the silencer is blocked with carbon. but i have never heard from anyone that this comes from car too.
what could be the reason? how serious is it?
Santro Engine Dies When Decelerating - NOT ALWAYS vigsom Technical Stuff 11 11th March 2015 15:04
Indigo DICOR 3rd and 5th gears popping into Neutral automatically. wanderernomad Technical Stuff 3 8th April 2011 22:27
Ultima GTR-640! Fastest accelerating and decelerating production car Gordon The International Automotive Scene 3 4th August 2005 19:02
