Old 3rd October 2008, 15:37   #1
Default My NHC clutch making a squeaking noise on release
Gurus,
My NHC clutch makes a squeaking noise when released. It becomes quite audible when the windows are rolled up. The service guys say that it is a lubrication issue, but was not able to fix it in the last two services . It is a 2004 model and the current mileage is 32000. Any clue anyone?
battada is offline   Reply With Quote
Old 4th October 2008, 13:12   #2
Monaro's Avatar
Thanked: 48 Times
I've had similar issues with my NHC aswell, the squeaking noise is indeed a lubricating issue and it generally happens during the rainy season.
I even got the pedals replaced under warranty when the lubricating didn't help either... but after 3-4months ..its back again at its squeaking best, but only when it rains!
Monaro is offline   Reply With Quote
Old 4th October 2008, 15:18   #3
Thanked: 103,701 Times
Same here with my OHC! The clutch squeaking noise can get ANNOYING, but nothing that a simple cable lubrication job can't sort out.
Old 4th October 2008, 17:06   #4
Lukeskywalker's Avatar
Thanked: 1,170 Times
Don't know about the OHC, but in my Santro the squeaking noise did not disappear on lubrication but changing the clutch cable did the trick.
Cheers,
Hari.
Lukeskywalker is offline   Reply With Quote
Old 6th October 2008, 11:17   #5
Thanks friends. I will try all options in my next service.
I guess we should put it up in some of our ownership reviews.
Old 6th October 2008, 11:20   #6
I am not sure if this slightly off topic but, I have a squeaking noise also from the door panel when the door is opened and closed. Tried getting it lubricated in various service checks but it seems to reappear every 4-5 months. Thanks for your help guys. TBHP rocks!!
Old 6th October 2008, 12:22   #7
menonrajesh's Avatar
In my Swift's case, no squeaking sound - but there is a distinct 'tak' sound when I release the clutch. Sounds like some metal plate is tapped.It is not there always, but produced most of the times.3 'tries' at Pratham Service with no results. Now I am planning to check it up with Suraksha along with my 25k service.
menonrajesh is offline   Reply With Quote
Old 6th October 2008, 12:53   #8
esteem_lover's Avatar
Thanked: 451 Times
Happens all the time in my esteem too. Lubricating the clutch cable works for a while, replacing the cable totally eliminates the sound.
Old 6th October 2008, 13:15   #9
alpha1's Avatar
Thanked: 1,035 Times
Cleaning and lubrication of cluthc cable.
Very simple job, any roadside mechaninc can do.
No need to go to service center for this.
Old 6th October 2008, 16:46   #10
SLK
SLK's Avatar
Thanked: 192 Times
Yup... In my wagon R too.... not in the NHC though!!
A temporary solution is to spray WD40 on BOTH sides of the clutch cable and on the paddle spring. Why WD40?... b'coz its easier to spray with the nozzle.
Otherwise a few drops of engine oil would solve the issue for a much longer period... but its kinda impossible to get that oil into that place... and direction.
SLK is offline   Reply With Quote
Old 18th December 2008, 23:45   #11
parimal_g's Avatar
Thanked: 174 Times
Unhappy Clutch Noise
My 48000km old Palio D is also also facing same problem while pressing and releasing the clutch two strange sound comes ,one is from inside the car from the clutch lever its sounds like some air is getting released and other is coming from the hood like kirrrr kiirrrrr..some what hissing sound ....ow cars is behaving fine..what could be the problem.........???
parimal_g is offline   Reply With Quote
Old 19th December 2008, 10:03   #12
parimal_g's Avatar
Thanked: 174 Times
Default Clutch noise
But Palio has Hydrolic System for the clutch so Oiling will not help....help required urgently
Old 9th November 2009, 12:24   #13
pragya's Avatar
i am also facing nearly similar problem in my zen estilo. My car has done 10,000 KM, I donot hear any considerable noise rather feel like the clutch gets stuck for just fraction of second.
What can be the issue.
pragya is offline   Reply With Quote
Old 28th November 2009, 22:17   #14
bj96's Avatar
Thanked: 130 Times
Unhappy wagonr clutch squeak
Is there a permanent (or a near permanent) solution to this? It is less than 6 months since I replaced the clutch cable on my 2002, 47k odo wagonr, but the squeak is back after the "fayhan" deluge few weeks ago. A generous dose of wd40 at a nearby workshop did quieten it for a few days but the squeak has returned. I want a solution, preferably a DIY.
Many thanks,
-BJ
bj96 is offline   Reply With Quote
Old 29th November 2009, 02:01   #15
Thanked: 360 Times
I'm not sure, but doesn't the NHC have a hydraulic clutch system? Maybe you need to check that.
Also see that the carpet is not in the way.
wildsdi5530 is offline   Reply With Quote
Squeaking noise - What could it be? namit Technical Stuff 23 21st February 2014 11:42
Belt squeaking noise even after replacement rajivanoj Technical Stuff 24 28th January 2014 06:27
First gear clutch release operation in MPFI cars - clarification needed! gigatech2006 Technical Stuff 57 26th October 2009 13:50
Squeaking sound from the clutch satan_crazy Technical Stuff 39 7th September 2009 15:29
Swift DDIS ABS humming sound during initial release of the clutch. tush Technical Stuff 12 25th August 2009 23:41
