| Technical Stuff Want to know your Vtec, ABS or intercooling better? |
| | Thread Tools |
| | #1 (permalink) |
| Senior - BHPian | I've been thinking about a few things, and I can't figure them out, so I'm putting the questions to you, fellow TBHPians, for some answers... 1. Why doesn't a cold air induction kit start on the hood? Wouldn't it be easier to make a hood scoop and have the filter/pipe rest there, than near the air-dam and run the risk of water? 2. Why should ABS take longer to stop on dusty roads (I don't think it's true)? 3. If 93 or 95 RON makes the engine sound smoother, shouldn't it run that much quicker? Got quite a few of these running around in my head. Will add them as and when they crop up. Cheers Viper
__________________ I've lost my phone. Please PM me your phone number if I'm on your contact list. |
| | #2 (permalink) | |
| Distinguished - BHPian ![]() | Quote:
Ofcourse, there are chances that you might come across a car with ABS, which is beaten by a another non ABS car, in terms of stopping distance. That's bcoz braking depends on many other factors like tyre width, tyer compound, tyre and surface temperature, weight of the vehicle etc, i think weight transfer (under braking) can also be added to the list. ABS, does not necessarily stop your car before you hit the on coming object. It just gives you the freedom to steer your car around it without wheel lockup. Try this page for more info on ABS. Shan2nu
__________________ VTEC flyby - youtube.com/watch?v=1AhWJlVRPqE Last edited by Shan2nu : 27th March 2005 at 15:00. | |
| | #3 (permalink) | |
Between 87 and 91 octane, i do find some improvement but between 91 and 93 octane, there's no diff, which can be pointed out, on my car atleast. Higher the octane, higher the potential energy possesed by the fuel but, tapping that energy requires a higher compression ratio, unless your car has enuf compression to extract every bit of energy from 93 octane, you shouldn't see any diff in performance. Shan2nu
__________________ VTEC flyby - youtube.com/watch?v=1AhWJlVRPqE Last edited by Shan2nu : 27th March 2005 at 15:38. | |
| | #4 (permalink) | |
| Senior - BHPian | Quote:
Drifter
__________________ Slow Everything Down And Feel Like God - Tata Safari | |
| | #5 (permalink) |
| Senior - BHPian | a cold air induction kit is pretty much in the engine bay. it is just that an air box is not used and it is at the air dam. yes it does get dirty faster than a stock unit but prople who use this are more performance oriented and do not mind the extra cleaning/maintenance required.
__________________ ...91 is back !!!! |
| | #6 (permalink) |
| Senior - BHPian | also if something is running smoother does not make it quicker. its just that it is "well fed" ![]() as long as the engine is runing at its optimum putting in higher octane fuel wont make it "faster" but an engine which requires higher octane but was using lower octane and u have recently switched to higher will be quicker and have better overall efficiency.
| | #7 (permalink) |
| Senior - BHPian | Hey guys, Thanks for all the info. @ drifter... you can design a scoop with a leading upper lip or hood which would minimize rain entry and yet be away from the airdam or any road dirt. @iceman...i switched from 91 to 93 in my stock baleno, and while i haven't checked figures, it certainly feels smoother. my point is, if it is smoother, it burns better, and thus energy released must be greater. @shantanu...in another post, some members had mentioned that in some cases, ABS takes longer to stop than normal brakes, these cases being dusty roads etc. I wasn't convinced, and what you said is basically what i've thought all along. thanks for the confirm. iceman, which vtec did you smoke now?!
| | #8 (permalink) | |
Shan2nu
__________________ VTEC flyby - youtube.com/watch?v=1AhWJlVRPqE | |
| | #9 (permalink) |
| Senior - BHPian | I always thought the hoodscoop is a better idea than placing the filter near the airdam. But then also ... either ways...you have to be more careful. By the way iceman....just love your signature. ![]() Drifter
| | #10 (permalink) | ||
| Team-BHP Support ![]() Join Date: Feb 2004 Location: Bombay / New York
| Quote:
It IS true that non-ABS cars brake faster than ABS equipped cars in certain conditions. ie sand/dust/snow. The advantage non-ABS has in these conditions is the fact that when the wheels lock up -
If you ever stand at a stop sign on a snowy day(hehe..yeah..goodluck), you will see cars approaching and slowing down, and just when they are about to reach a standstil the ABS lets off the brake pressure coz the wheels are locked and the car jumps a 6-12" forward, and this happens 2-3times before the car comes to a stop. In the end its very specific to conditions and driving styles, as well as quality and type of ABS system. However, i just wanted to explain this aspect to you, hope you see how it makes sense now? Quote:
According to me, there will be less pre-ignition/detonation; hence = smoother / more power. And the ECU will not retard the ignition timing to prevent pre-ignition; = more power. cya R Last edited by Rehaan : 28th March 2005 at 10:52. | ||
| | #11 (permalink) | |
Shan2nu
| | #15 (permalink) | |
Shan2nu
| Thread Tools | |
Similar Threads | ||||
| High levels of CO emission - any answers? | WhiteAttraction | Technical Stuff | 0 | 3rd August 2006 13:30 |
| How to determine what size Power Cables for ICE? Answers inside... | gunbir | Ask the Gurus | 96 | 8th May 2006 11:34 |
| Stupid questions with the smart answers | 2fast2furious | Shifting gears | 12 | 23rd August 2004 14:33 |
| Get answers to your audio questions | satish_appasani | Ask the Gurus | 1 | 11th August 2004 03:30 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461
