Old 31st March 2015, 23:27   #31
zenren's Avatar
Thanked: 1,725 Times
Default Re: Need a salvaged A/C compressor for my Matiz
Originally Posted by sudipt123 View Post
Received quote of 15K from KEETA KAR COOL, Worli- but requires 50% advance as it needs to be sourced from Delhi.
Nowdays you can source through amazon.in as well- but spark compressor not available.
Is 15K an OK price for brand new compressor -or should I go through the retrofittment route?
I got the compressor and evaporator coil changed for 9k along with R12-R134a conversion, but that was 6 years back. I don't remember if the brand was Subros or Sanden in my case - I just remember it was one of the Maruti OEMs.
15k seems a little on the high side, though I'm not sure of the current rates and the specific situation for Spark's model. Also, I'm not sure if Delphi carries a higher tag than Sanden/Subros but considering my 9k was for both parts, the compressor should have been in the range of 6k or so. Again, mine was for a Maruti and hence the dime a dozen scale benefit applies to OEMs and they might be able to price it cheaper.
Do check if any Sanden or Subros unit would suit the Spark.
zenren is offline   Reply With Quote
Old 1st April 2015, 17:21   #32
sudipt123's Avatar
Thanked: 20 Times
Thanks for the update, market price as Informed by the Unicool auto was around 13K, got it for 14.5 K from a source- little pricey but the compressor is genuine and with the hot summers couldn't wait for longer- so went ahead with the purchase. It's Delphi make
Would post pics later. Thanks for the help
sudipt123 is offline   Reply With Quote
astra compressor adilshah Technical Stuff 17 4th July 2012 23:45
planning to go in for a used Matiz .. need help culnanmaga Hatchbacks 5 16th July 2007 12:46
MATIZ AC Compressor Needed sary Technical Stuff 0 22nd August 2006 12:58
AC compressor loading engine excessively Pankaj401 Technical Stuff 7 9th July 2006 19:35
How about w-matiz or e-matiz Gtea Modifications & Accessories 38 3rd February 2006 02:12
