Old 5th October 2008, 08:19   #1
vinayvtec's Avatar
Thanked: 9 Times
Question I am facing strange issue with my car AC?
I am having some strange issue with my carís AC. When car is turned on and its stand still with AC on the AC cooling is not much, but when the car is on move the AC cooling is more.
Has anyone faced same kind of issue? What might be causing this issue?
vinayvtec is offline   Reply With Quote
Old 5th October 2008, 08:53   #2
Thanked: 9 Times
Default Engine RPM and A/C cooling
Considering all a/c components are functioning quite ok, all car a/c systems cool better when engine RPM is at optimum level (like 2000+). Which would explain better cooling when car is running.
But to check, is there a need to top up refrigerant - have you done it recently?
hope this helps.
vijuvarghese is offline   Reply With Quote
Old 5th October 2008, 09:03   #3
TrueDreamer's Avatar
Thanked: 7 Times
I suspect a thing with your battery or alternator. When did you last get your battery topped / charged or installed ?
TrueDreamer is offline   Reply With Quote
Old 5th October 2008, 10:11   #4
Thanked: 253 Times
Vinay, the AC system is short on refrigerant. Do get it topped up.
Old 5th October 2008, 10:15   #5
ashthedivx's Avatar
Thanked: 22 Times
Get the Gas topped up.. its short and enjoy the cooling while idling too
Old 5th October 2008, 10:48   #6
merve_extreme's Avatar
Thanked: 12 Times
Check if your radiator fan is working when you switch on the AC.It should come on in 10-20 seconds.If there are 2 radiator fans only the one connected to the AC system will come on.
If the fan is working correctly you might have a minor leak in the AC system,it will need to be rectified and the AC refrigerant replaced.
merve_extreme is offline   Reply With Quote
Old 5th October 2008, 10:49   #7
star_aqua's Avatar
Thanked: 89 Times
check with the fan if its functioning or not. do you have a separate fan for cooling down the refrigerant? other than the radiator's.
star_aqua is offline   Reply With Quote
Old 5th October 2008, 16:52   #8
Rehaan's Avatar
Thanked: 25,043 Times
A few possible causes :
- Low refrigerant (as mentioned above)
- Condensor fan not turning on (as mentioned above)
- Compressor belt slipping
- Low voltage (this would affect the blower speed, but im sure you would notice this in other areas as well / first)
cya
R
Old 5th October 2008, 16:58   #9
viper's Avatar
Thanked: 9 Times
Hi Vinay,
This is a classic symptom of a weak compressor. What is happening is the compressor does not pump whilst idling or at low revs resulting in no cooling. The same ca be repaired temporarily. For the long term am afraid you will have to change your compressor.
Viper
viper is offline   Reply With Quote
Old 7th October 2008, 08:55   #10
vinayvtec's Avatar
Thanked: 9 Times
Thank you guys, I will go to an AC technician and get it checked.
@ Viper: please can you let me know how much does a compressor cost?
I started noticing this issue from past 3 weeks, I will not use the AC on my regular drive, but when driving with family I prefer it to work.
Old 7th October 2008, 09:14   #11
viper's Avatar
Thanked: 9 Times
Vinay,
Will inquire and send you a PM by noon along with options.
Viper
Old 7th October 2008, 09:21   #12
Thanked: 11,082 Times
Battery was replaced in Feb 2005
Refrigerant has never been topped up.
Compressors of Honda Citys usually good for 50000km
There is supposed to be someone in Vasantnagar who is quite good. Some bylane left of Miller 56 - go there rather than Honda
Old 7th October 2008, 10:29   #13
Ford Rocam's Avatar
Thanked: 16 Times
Looks like more of Condenser Fan issue than the compressor, when your car is stationary & if that fan doesn't pull out enough air from condenser the cooling gets effected, but when you are in motion there is enough air coming from front air dam to cool off, its acting just like your radiator fan. Get it checked with a competent A/C guy & also get check the pressure inside the cooling pipes, you might need to top up the refrigerant.
Ford Rocam is offline   Reply With Quote
Old 7th October 2008, 11:13   #14
star_aqua's Avatar
Thanked: 89 Times
If you are somewhere near audugodi then there is one guy who is pretty good in fixing ac problems and his no is 9448060513.
Old 8th October 2008, 14:27   #15
vinayvtec's Avatar
Thanked: 9 Times
Cool
Thanks for the number dude.
Sure, I will get it checked.
Hmm, I think I should have the address and the phone number. You had mentioned it in one of your e-mail, which you had sent me sometime back.
Originally Posted by viper View Post
Vinay,
Viper
It was great speaking to you Viper. If my GF had not come then I could have got more tips from you
Strange Issue with my Autocop XS 8500/8550 johnruben Technical Stuff 5 2nd September 2010 19:43
Strange issue in my car MX6 Technical Stuff 18 16th May 2010 22:37
strange Ac issue in Indica V2 dls... need help PRODENT Technical Stuff 1 20th October 2009 19:08
Ford Ikon 1.3 - Strange Issue ! ford_honcho Technical Stuff 5 31st August 2009 21:19
Front facing Vs Rear facing Vs Side facing seats in MUVs/SUVs ritz830 The Indian Car Scene 20 11th July 2009 16:55
