Old 6th October 2008, 22:03   #1
Rai
Default Tata Sierra Power Window - Not working
Hello All,
The PoweWindow in my Tata-Sierra is dead Slow. At times I have to push the Glass up by Hand.
I think I need to Get the unit replaced or Serviced. Please advice.
If I have to replace the PowerWindow Motor, then Whether afterMarket PowerWindow Motor is available which Suites Tata-Sierra?
and if I have to Service it, where can I do it in Mangalore (or Bangalore)?
Please advice
Rai is offline   Reply With Quote
Old 6th October 2008, 22:20   #2
Hemanth's Avatar
Approach a competent mechanic and ask him to grase the power window railings (i presume-i am not getting the right word.
Hemanth is offline   Reply With Quote
Old 7th October 2008, 11:57   #3
Thanked: 103,418 Times
Cement mixer! I remember someone coining this term for the Sierra's power window motors. They are damn noisy and,within a short time, get too weak for the job. Why don't you consider putting in newer powerful motors too?
Old 7th October 2008, 17:11   #4
veyron1's Avatar
Thanked: 38 Times
Ah. Yes. The crikey ol' window problem. No solution apart from replacing the winder/motor assy. The problem is that the Sierra's winder is mechanically driven, unlike the current wire-wound winder systems, which stresses the motor real quick...
Get the units from the Safari. A few holes have to be drilled, and a bit of mounting adjustments here and there have to be done, but those units will solve your problems. At 4500+ each, power window winder assemblies are expensive, though....
veyron1 is offline   Reply With Quote
Old 7th October 2008, 23:52   #5
Rai
Default Manual
From the explanation it looks like its better for me to go for Manual operation....like in basic Model Cars
Old 3rd November 2008, 19:03   #6
Rai
Default Problem Solved
Hi All,
Tried all methods but Power Window was dead Slow. Atlast got a new Power Window Motor (Just to test) and tried it and same was the case.
Then my Mechanic told me, let us put a new Wire and try and Voila, that was the problem. So I went back to my Original Units and its working very fine now.
Culprit: Wiring was very old (1994) and hence it was not taking the load.
Speaking of wiring, it looks like its a huge disaster waiting to happen. Am sure this will put me in big trouble in a very near future, in middle of heavy traffic, when it is raining heavily .
So to solve this, my Question is: Do I get Sierra Wiring Kit outside? Either from Tata or others? Please let me know.
Rai
Old 8th November 2008, 12:28   #7
Swifty2008's Avatar
Originally Posted by Rai View Post
Hi All,
Rai
Will be difficult, but you should. But first try with any known diesel mechanic within your city. Replacing the wiring kit a herculian task and time consuming.
Swifty2008 is offline   Reply With Quote
Old 12th December 2009, 12:39   #8
Hi All,
I have the similar problem and am new in bangalore, can you tell me where can I get the problem corrected. If not a issue then tell me the mechanic who solved the issue for you.
Pradeep
usrivpx is offline   Reply With Quote
Old 14th December 2009, 14:46   #9
Pradeep
Try Aleem on JC road. 9901693419
You can give him my reference as Harsha (Advocate) with Silver Hyundai Accent and he will take good care.
harsha.cs1 is offline   Reply With Quote
Old 18th March 2010, 00:07   #10
Advyth's Avatar
Hey Rai, any luck in getting the wiring kit in Bangalore? Looks like I need to get it done as well. Where in Bangalore did you find them? If you found them.
Keep us updated.
Cheers.
Advyth is offline   Reply With Quote
Power Window Failure? How to manually roll your window up lsp Technical Stuff 36 13th April 2014 15:24
Sierra rear window-set on a Gypsy COUGAR Modifications & Accessories 1 26th May 2008 14:22
Power Steering and Over heating Problems In my Sierra sag_kv Technical Stuff 8 9th May 2008 12:42
Power window doesn't come up! Why? Deeps Technical Stuff 3 10th April 2006 17:27
Need Info: Sunfilm/SeatCover/Power Window/Fog Lamp souravbasu Modifications & Accessories 3 3rd April 2006 10:53
