Old 14th August 2014, 13:47   #721
VeyronSuperSprt's Avatar
Thanked: 1,664 Times
Default re: Skoda Laura: Problems & solutions thread
Originally Posted by anandpadhye View Post
Why only Skodas? It happens with my Tucson as well and I got from SA that it's a pure mechanical thing that can happen in any vehicle which has front disc brakes.
Mechanical / Electrical problems are not restricted to make of car although in some cars a particular problem may appear more frequently. The earlier Octavia had this brake disc induced wobble more often but it is far less in the Laura.
VeyronSuperSprt is offline   Reply With Quote
Old 14th August 2014, 14:26   #722
Many thanks guys, ajaypjayaraj, veyronsupersprt, anandpadhye and V 2rahjo. Just realized that at 50K plus KMs my brake pads are probably crying out to be changed... will revert if this works. Thanks again.
Inder7 is offline   Reply With Quote
Old 21st August 2014, 13:02   #723
maheshramaling's Avatar
Thanked: 151 Times
Originally Posted by v_2rahjo View Post
Does this sound come when you take a turn? Is it more pronounced when you turn the steering while reversing?
Not really. It happens at slow speeds including reversing. Especially this is when clutch is engaged half in first or reverse gear. I am suspecting this to be related to clutch. Will take it again to ASC but if anyone else has any thoughts before that -it would be great.
maheshramaling is offline   Reply With Quote
Old 22nd August 2014, 11:01   #724
Santoshbhat's Avatar
Thanked: 3,889 Times
I did a VCDS diagnostic scan on a 2010 Laura TSI that a friend was looking to purchase. It threw up the following fault code.
1 Fault Found:
001089 - EVAP Emission Control Sys
P0441 - 000 - Incorrect Flow - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 0
Fault Frequency: 3
Reset counter: 255
Mileage: 19955 km
Time Indication: 0
Date: 2044.14.04
Time: 14:16:25
Freeze Frame:
RPM: 849 /min
Load: 18.8 %
Speed: 0.0 km/h
Temperature: 96.0C
Temperature: 48.0C
Absolute Pres.: 900.0 mbar
Voltage: 13.462 V
The Ross-tech site has a ready reckoner of fault codes and this is what it says about it.
"16825/P0441/001089 - EVAP Emission Control Sys: Incorrect Flow
Possible Symptoms
Malfunction Indicator Light (MIL) active
Possible Causes
Evaporative Emission (EVAP) Canister Purge Regulator Valve (N80) faulty/jammed
Evaporative Emission (EVAP) Canister Purge Solenoid Valve (N115) faulty/jammed
Evaporative Emission (EVAP) Canister Sealing faulty
Pipes between Tank Breathing and Throttle Body leaky/blocked
Possible Solutions
Check Evaporative Emission (EVAP) Canister Purge Regulator Valve (N80)
Perform Output Test
Check Evaporative Emission (EVAP) Canister Purge Solenoid Valve (N115)
Perform Basic Setting
Check Pipes between Tank Breathing and Throttle Body
Special Notes
When found in the NAR 1.8T Audi A4 1.8T check TSB 24-08-78 or 2010268/3 or Pass-Thru equivalent TSB
When found in the NAR 1.8T VW Passat 1.8T check TSB 01-09-09 or 2005554 or Pass-Thru equivalent TSB
Note: The Passat 26E5 or "R5" recall includes the same software update
Make sure the quick release lines for the N80 valve and vacuum line to LDP are not crossed.
This can also make the engine hard to start after filling up the fuel tank."
There is no check engine light on the dash as of now. What do you guys make of it? Should my friend be worried? He hasn't approached Skoda yet. I've advised him to take the report to them and see what they suggest.
Santoshbhat is online now   (1) Thanks Reply With Quote
Old 22nd August 2014, 15:22   #725
rohitm's Avatar
Thanked: 43 Times
Originally Posted by Santoshbhat View Post
My Laura TSI completed 3 years in May this year. I am still running on the original Varta battery. Is it a good idea to replace the battery as a preventive measure, just so that I am not left stranded with a dead battery or complications due to a weak battery?
I use the car quite quite often for out of city drives. I don't want to face a situation where I am stranded somewhere with a dead battery.
How long do these Varta batteries usually last?
Hi Santosh,
The OE Varta battery on my Laura TDI died in 3 years and a few months. Luckily this happened when i was at home and was able to order a Amaron replacement. Trust this helps you take a decision.
Cheers,
Rohit
rohitm is offline   (1) Thanks Reply With Quote
Old 23rd August 2014, 10:37   #726
Thanked: 21 Times
I had been wondering about the following options available in my Laura, can anyone help me in deciphering their function? Photos inline
So what do the options stand for-
1> AF?
2> Phone? Connecting a phone? but how?
3> BT-Audio? Bluetooth Audio but my phone would not find it
This is my first time attaching photos on this forum so kindly excuse in case I make some error
v_2rahjo is offline   Reply With Quote
Old 23rd August 2014, 11:15   #727
Gannu_1's Avatar
Thanked: 10,515 Times
1> AF?
AF - Alternative Frequency
The function alternative frequency (AF) ensures that the best receivable frequency of the selected station is automatically and precisely set. The replay of the broadcast can be muted briefly during the search process according to the best receivable frequency. If no alternative frequency of the set station can be found and the station no longer offers a satisfactory quality, then please select another station.
Refer the Swing Owner's Manual here - link
Gannu_1 is offline   (1) Thanks Reply With Quote
Old 26th August 2014, 18:34   #728
Steering Wobble at High Speed
Hi guys,
The wobble continues. I have so far done the following :
a) Allignment
b) Balancing
c) Changed the brake pads (all four)
d) Had the brake discs grinded
e) Had the suspension checked
Am a bit lost now and planning to write to Skoda for help....
Old 26th August 2014, 20:27   #729
Behemoth's Avatar
Thanked: 1,691 Times
Hi guys,
a) Allignment
b) Balancing
Have you tried swapping the front and rear tyres? There is a possibility that one of your front tyres has developed a bubble and that may be causing this. A bubble is due to an internal break in the steel wire reinforcing the tyre.
Behemoth is online now   Reply With Quote
Old 26th August 2014, 21:37   #730
Thanked: 919 Times
Guys I am a bit confused. My laura went in for the 60k service a couple of weeks back. This was at nawab auto in noida. Despite my requesting they did not change the gearbox oil. The manual says change the oil at 60k for cars equipped with automatic transmission, which is the case with my car.
The SA and the GM showed me the service schedule board and there it was indicated that they inspect the oil and change only if required. In my case it wasn't required hence they didn't do it.
Now should i go ahead and change it from another dealership or have faith in what nawab has told me. The car has always been serviced by them and I have had no issues except the quality of wash.
Any input would be of great help
Thanks!
Rohan
Sent from my iPhone using Team-BHP
RohanDheman is offline   Reply With Quote
Old 26th August 2014, 21:58   #731
Hi guys,
a) Allignment
b) Balancing
You mentioned earlier that you have changed to 17" Alloys and wheels. Are these alloys OE skoda alloys or after market? If they are after market are they 98 PCD alloys? Secondly is the alloy bore a perfect fit on the hub? If its not, then there's a possibility of vibration at high speeds. The remedy for this is hub centric rings.
Santoshbhat is online now   Reply With Quote
Old 27th August 2014, 09:47   #732
Are these alloys OE skoda alloys or after market? If they are after market are they 98 PCD alloys? Secondly is the alloy bore a perfect fit on the hub? If its not, then there's a possibility of vibration at high speeds. The remedy for this is hub centric rings.[/quote]
Hi Santosh,
these are not skoda OE alloys and i'm not certain about the 98 PCD, will check today. Yes, the hub rings were used for the front wheels. Please remember i also mentioned that the wobble had started before i changed the alloys/tyres. In fact that was the principal reason for doing so... that's why am skeptical about alloys having anything to do with it.
Old 27th August 2014, 16:15   #733
cedricsg's Avatar
Thanked: 24 Times
I am using stock tires on my TSI. Whats the best size upgrade, 16 or 17 and tire size?
cedricsg is offline   Reply With Quote
Old 27th August 2014, 16:21   #734
ishlinea7260's Avatar
Thanked: 262 Times
Get it changed ASAP.
Its not uncommon to find service centres not adhering to "whichever is earlier" rule , be it kms or years.
Chances are he might have "felt" the gear oil need not be changed and could be delayed till the next service or 5 years interval.
But why take chances , if it is in the manual it is supposed to be changed.
ishlinea7260 is offline   (1) Thanks Reply With Quote
Old 27th August 2014, 17:01   #735
17" is a very popular upgrade choice for the TSI which comes with 15s. Tyre size would be 225/45/17. The other option is 16". The tyre choices are 205/55/16 (same as Elegance and LnK models) or 225/50/16. I've gone for 225/50/16 Michelin PS3 on matt black Borbet alloys and very happy with this combination.
Be careful while buying alloys if you are not going for Skoda ones. There are things like PCD, offset, hub diameter, rim width etc... that you'll have to check. Also the Skoda OE alloys are of a high quality. If you are going for aftermarket ones, go for good brands only as I am sure you wouldn't want to compromise on safety.
