Old 15th October 2015, 20:19   #871
nareshov's Avatar
Thanked: 165 Times
Default re: Skoda Laura: Problems & solutions thread
Does anybody have a link to a copy of the 2007 Laura 1.9PD's service booklet? The links (mediashare) I came across have expired.
nareshov is offline   Reply With Quote
Old 21st October 2015, 23:27   #872
newtonMeter's Avatar
Thanked: 361 Times
Originally Posted by Desmodromic View Post
Hi all
Need to change my brake pads in 2010 Skoda Laura 2.0tdi MT(75kms). This is my second change. The last time I got it done it was with the ASS when my car was under warranty.
Now am sending it to a Bosch service center for service and repair. The chief mechanic at the Bosch service centre is sugesting ROLLAND brake pads over Bosch or Delphi.
Have any of you used the above brands on your laura? Do any of you know what the OEM brand is on the Laura? Is it PAGID? If so what do these pads normally cost?
default brand is BOSCH. costs around 4k for a pair
newtonMeter is offline   (1) Thanks Reply With Quote
Old 24th October 2015, 16:49   #873
Hi all
I tried the aftermarket brakes from Bosch....and can tell you it was a poor decision. The brakes started giving a screeching sound within the 1st month of installation. Took them to Giriraj - and was told the noise is due to the brake pad compound in the after market one. However, braking does not get impacted. So if you're willing to live with the screeching sound every time you apply the brakes, you can go for the BOSCH ones....else tbh, I wouldn't go for the after market ones again.
Sanju
SanjuInGgn is offline   Reply With Quote
Old 24th October 2015, 16:55   #874
Thanks for the reply.
I got my pads changed 1 week ago. Changed to Delphi pads on the mechanic's reccomendation. It cost me 4k.
I also changed my front rotors along with the pads
Desmodromic is offline   Reply With Quote
Old 24th October 2015, 16:56   #875
Hi All,
Hope everyone has had a good Durga Puja / Dushera celebrations.
On the car front, need your advice on a fault that I've been noticing for the last few weeks. The speedometer needle in the laura has the while backlight glow. Whats been happening intermittently is that it keeps switching off....have tried to see if this happens only when going over a rough surface (indicating a loose connection) but that doesn't seem to be the case. Also, this doesn't happen all the time either.
Has anyone faced this issue with their ride? If yes, what was the resolution that you applied?
I have recently relocated to Blore - and tbh, the service quality at both the ASS has been very poor - so am not very keen to take this issue to them - as am pretty sure they would suggest an instrument cluster replacement.
Appreciate your responses.
Thx,
Sanju
Old 25th October 2015, 21:33   #876
Thanked: 361 Times
Originally Posted by SanjuInGgn View Post
Hi All,
Thx,
Sanju
try to get someone with VCDS cable. Do a diagnostic scan. If there is a loose connection, the fault will definately show up in in the fault logs. Even if the needle is glowing now, the fault is registered when it was not glowing, so i am very sure there would be a log if there is loose connection.
most probably you will see "intermittent" fault on "Instrument Cluster"
newtonMeter is offline   Reply With Quote
Old 2nd November 2015, 00:23   #877
Hi All,
Am curious to understand if there is any adverse impact of running with the "Bulb Out Error" for a long period - without doing anything about it. Trying to explore the possibility of replacing the normal PY21W bulbs of the DRL to the LED versions. Using them without the load resistors will cause the bulb out error. Wondering if leaving it as-is will have any adverse impact on the canbus or other control systems. Not keen on the load resistors due to unwanted heat generation - and hence unwanted load on canbus system.
Appreciate your thoughts pls.
Old 3rd November 2015, 12:17   #878
tarunt's Avatar
Question re: Skoda Laura: Problems & solutions thread
Skoda Laura TDI DSG March 2012: Coolant leak related issues
Hi, I could really use some advice from you folks! I have diesel Laura as mentioned above. It has done 30K kms and has had all 3 services done on time. This August I had the "coolant low" alert come on. Further investigation at Vinayak skoda KR puram revealed that there was a manufacturing defect in the coolant pump and the pump was replaced. The hot coolant also dripped on the timing belt and that was also replaced. Coolant was topped up as well.
This morning I got the "coolant low" alert again. Checked the coolant tank and it was almost empty. Filled in 1.5 liters of water and called the service advisor. He advised that I run the car till I get the next warning as he believes that it could be normal consumption as well and not a leak. I find that hard to believe. Any guidance or similar issues faced by anyone? Any thought's advice will help.
tarunt is offline   Reply With Quote
Old 4th November 2015, 09:24   #879
ricky_1605's Avatar
Thanked: 44 Times
Even with normal consumption the coolant tank is never empty. Only thing that could have happened is last time they didn't fill up sufficient volume of coolant. Take it to the ASS at the earliest and get it checked.
ricky_1605 is offline   Reply With Quote
Old 4th November 2015, 10:05   #880
.anshuman's Avatar
Thanked: 9,046 Times
My 2010 CR TDI DSG had a coolant leak. Initially it was a slow leak, got the warning on MID, i topped up. Few days later i spotted coolant below the car, it was a small leak in Radiator. The radiator was replaced. Link:http://www.team-bhp.com/forum/long-t...ml#post3590759 (Skoda Laura DSG CR 140 - Ownership Experience.)
Old 20th November 2015, 18:45   #881
Thanked: 27 Times
I have a Laura Elegance TDI 2.0CR DSG 2011 which is coming up for a 60,000 KM service. From what i have read, there is a need of Transmission fluid change required at this interval. What other things are needed at this time?
Secondly i feel my suspensions are making some noises, probably dampers or bad mounts, how much more expensive will this be at the ASS compared to somewhere outside and what is most likely cause of this which I should pre-emptively change?
Lastly does anyone know any contact in Autobahn Skoda Kurla, Mumbai whom i can trust with? Thats the most convenient place for me.
Zubin21 is offline   Reply With Quote
Old 23rd November 2015, 11:41   #882
Thanked: 21 Times
Lastly does anyone know any contact in Autobahn Skoda Kurla, Mumbai whom i can trust with? Thats the most convenient place for me.[/quote]
Hi Zubin,
few things to note:
1. Check Brake pads
2. Brake discs may need skimming if ridged.
3. Transmission oil- I did not change because it appeared Ok, sufficient
oiliness. I don't trust the ASS. I have read too many posts which said that proper venting /procedure was not followed leading to problems later with the auto box. Too scared to let anyone touch it.
4. Trust you have changed the tyres.
5. Engine oil change and check all other oils for colour and oiliness. if too
dark/black then change it. Smell the engine oil on your hands . if you get the smell of fuel then you need to service your fuel injectors but this is not likely to happen. Just a cautionary.
My car just completed 62000 km. 2010 TDi AT, Normally You must change the suspension bushes. I suggest get it done by a local mechanic. Thee bushes cost about Rs4500/- per bush(original) from any good parts dealer. Your total cost will be much lower than the ASS. The problem with the ASS is that the moment you give it to them, they will start creating more more and thus you land up paying a lot more. I have experienced this quite often now.
At Autobhan Kurla - Best person to catch is Jitu.
Hope this helps.
Rgds,
Seacat is offline   (1) Thanks Reply With Quote
Old 23rd November 2015, 11:44   #883
Akshay1234's Avatar
Thanked: 6,727 Times
Speak to Vinod or Nitin, both are SAs. If you have any issues speak to Stanford,the manager. You may give my reference as Akshay with the white vRS.
Damn Skoda service, have to know the full staff of the service centre to get any work done.
Akshay1234 is offline   (1) Thanks Reply With Quote
Old 23rd November 2015, 20:12   #884
Thanked: 27 Times
Originally Posted by Seacat View Post
Hi Zubin,
few things to note:
1. Check Brake pads
Hope this helps.
Rgds,
[/quote]
Thanks Seacat; i have my pads changed at 55K plus disc skimmed. Oil too was topped up that time plus I had new rubber that time. I just wanted things which are mandatory and technical handled by ASS but you have got me scared on this one. So I am thinking more of changing the oils + filters and the likes. But its the suspension that probably needs some work, it feels stiff and not at all plush. Compared to Jetta it just doesn't stand a chance. I understand that Jetta's setup is different but this time its too still compared to earlier hence i want that back. Perhaps I should try somewhere else for Suspension?
Thanks Akshay; I did contact Vinod and he knows you.. Taking it to ASS this week. Lets see what happens!!
Old 24th November 2015, 12:15   #885
Akshay1234's Avatar
I would have hoped that he knew me, considering he still has a car of mine
But he seems good, and should take care of your car.
