Old 25th October 2008, 18:43   #31
SLK
SLK's Avatar
Thanked: 185 Times
Originally Posted by Shan2nu View Post
What i need to know is, Honda says the stock oil should be changed every 5000kms (only for the OHC i guess). But since il be using semy synth oil hence forth, should i increase the oil change interval to say every 8000-10,000 kms?
I have used Magnetec on my WagonR, time and again. Though you can feel the difference in driving when you start using it, by the time its nearing 10k kms it doesn't quite feel good.
If you recall Maruti's as it is ask for an oil change at 10k kms and by that time the car feels awful , I'd say magnetac is only marginally better than that at 9-10k kms.
And whats your take on adding Bardahl with engine oil..............does it really make a big diff?
Used it in the 800Dx, wrong car to test it! but Maybe it was slightly quiter [but can't say - might have been the service effect]
PS : Speaking of oil price, i recently saw a 4L Magnatec can, priced at 984 bucks or so.
Everything is getting too expensive! It used to be 650 etc.!!
SLK is offline   Reply With Quote
Old 25th October 2008, 21:52   #32
nitrous's Avatar
Thanked: 282 Times
If you're planning to keep the VTEC for a long time, I would suggest fully synthetic for you,Shan2nu.
Old 25th October 2008, 22:02   #33
Shan2nu's Avatar
Thanked: 86 Times
The VTEC is here to stay. No plans of selling it anytime soon but the prices for pure synth is insane. Moreover, i don't take part in drags and god knows when il be able to get my car for a track day so considering the kind of driving i do, i feel semi syth should be good enough for now.
My doubt was regarding oil change interval for magnatec. Any idea about that?
Shan2nu
Old 25th October 2008, 22:04   #34
nitrous's Avatar
Thanked: 282 Times
Stick to 5k or max push to 7.5-8.
Not more than that.
PS: Petronas Syntium 5W40 fully synthetic is about 550-600 per litre.
Old 25th October 2008, 22:21   #35
Shan2nu's Avatar
Thanked: 86 Times
Ok one thing could work out. If im paying twice the price for pure synth but am able to use it for twice the duration (say 12-15K), in the long run, i end up spending the same with the added benefits of pure synth.
Whats the recomended oil change interval for pure syth?
Shan2nu
Old 25th October 2008, 22:34   #36
nitrous's Avatar
Thanked: 282 Times
10,000 kms OCI with pure synth.
Old 25th October 2008, 23:17   #37
iraghava's Avatar
Thanked: 153 Times
My VTEC engine has lasted 180k+ on mineral oil with changes every 5k.
Old 25th October 2008, 23:31   #38
Eddy's Avatar
Thanked: 4,667 Times
No engine work for 180k ?
Eddy is offline   Reply With Quote
Old 25th October 2008, 23:57   #39
iraghava's Avatar
Thanked: 153 Times
Nope, nothing till now apart from a Timing Belt change. *Touchwood*
Old 26th October 2008, 00:22   #40
Eddy's Avatar
Good. And yes, touchwood.
Any additives used ? Flushing how often ? Which oil ?
And how does the engine behave now after 180k ?
Old 26th October 2008, 09:40   #41
toiingg's Avatar
Thanked: 70 Times
I too have been using Magnatec since the last 2 fills. Cars done 99k. I normally change oil every 5k kms. Honestly, i have found no difference in the performance at all. I'll be going back to stock Honda Oil during my next change.
Or maybe go fully synth... *scratches head*
Damn !!
toiingg is offline   Reply With Quote
Old 26th October 2008, 10:02   #42
akshay4587's Avatar
Thanked: 1,552 Times
I am planning to go fully synthetic in my accent at next oil change.
what are the negative effects,if i change back to mineral from synthetic after some time.
Old 26th October 2008, 10:39   #43
Shan2nu's Avatar
Thanked: 86 Times
I just remembered watching a vid on you tube where the technical advisor of Spoon Sports Mr. Ichishima was asked what oil should be used on a stock car thats taken for track days once in a while.
Interestingly, he said that OEM oil is infact good enough for a car that hasn't had it's engine modified.
Here it is -
Shan2nu
Old 24th January 2009, 20:58   #44
Shashank.A's Avatar
Bought 3.5L Magnatec for Rs.1050. Got a sweatshirt free , which was grabbed by my Mechanic.
The GTX was for Rs.725, so its better to go for Magnatec, as its value for money and lasts for 10k km compared to 5 on other oils.
Shashank.A is offline   Reply With Quote
Old 24th January 2009, 21:54   #45
nitrous's Avatar
Thanked: 282 Times
Stick to 8,000 kms for semi synth.
Experience - Castrol Magnatec Vs Total Quartz 7000 abhaybakshi Technical Stuff 22 25th October 2014 08:17
Castrol Bikezone = Castrol Bikepoint? UPDATE: Review of Ace Bikes, Bangalore (pg2) Soumyajit9 Motorbikes 20 21st July 2013 23:48
VW use Castrol Magnatec 5W40 for Polo, Why not EDGE? gaurav_chopra04 Technical Stuff 7 4th March 2011 00:46
OWS 15W40 vs Castrol Magnatec - Which is Better ibm_jennifer Technical Stuff 6 27th August 2008 02:20
Castrol R4 superbike engine oil for Honda Unicorn devsus Motorbikes 4 4th May 2007 10:43
