Old 5th July 2009, 04:45   #121
mdesai_1981's Avatar
hi guys i have a small problem i have a NHC and am about to go for the 10000km oil change.
i plan to go for fully synthetic engine oil and am enquiring about the same with my honda dealer they say that as of now honda recommends 10w-30 idemtsui engine oil.
but if i want i can put 5w-40 or sorts but not 5w-50.
here the problem arises in bom 0w-40 mobil is easily available. can i put this in my car? the mobil dealer says it will be perfect for NHC and is the best oil available.
please guys i'm very confused.
nitrous- they said no for 5w-50 as they say the oil pump might malfunction as honda is using 10w-30.
mdesai_1981 is offline   Reply With Quote
Old 22nd July 2009, 20:05   #122
cyclops's Avatar
Thanked: 9 Times
Originally Posted by indivic View Post
Caltex: Cars
The product is Havoline Energy 5W-30 apparently fully synthetic and MRP is Rs.1184/- for 4 L can, distributor price would probably be inline with what Raccoon has posted.
I picked up Chevron Delo 15W-40 (5l+1l) meets/exceeds API CH-4 for Rs.1068/- y'day from a distributor. Chevron representatives are really prompt in replying to queries for information.
Hey guys, did you get the products and tried it? How was the performance noted?
cyclops is offline   Reply With Quote
Old 27th July 2009, 16:00   #123
cyclops's Avatar
Thanked: 9 Times
Caltex: Cars
I had contacted the Chevron guys. As per him, Havoline Energy is not fully synthetic, its semi-synth. But my worry is about its rating, Is 5W-30 suitable for Indian climate and on a smaller engine (Alto)???
Any advice on this? Should I go ahead and try it out? Will it cause any harm to the engine? Also, what is the engine oil capacity of Alto? The can is available only in 4 ltrs.
Old 27th July 2009, 17:59   #124
Raccoon's Avatar
Thanked: 105 Times
Maruti is now recommending 5W30 for SX4 etc... but I don't think its recommended for Alto. Just double check with the chart in your manual. I'd suggest you not use it unless its explicitly recommended... not in Pune kinda climate at any rate!
Old 27th July 2009, 19:40   #125
hillram's Avatar
Thanked: 941 Times
Has any one tried using Mobil 1 Synthetic Engine oil? Please share your experiances on your cars?
hillram is offline   Reply With Quote
Old 27th July 2009, 19:55   #126
mail4ajo's Avatar
Thanked: 222 Times
After reading some reviews, I went for Magnatec. 2.7 litres for Alto. Approx Rs 950. Feel some difference, but not a completely new world feeling. Feels like its reving better and smoother, thats all I could notice.
My query is, can I prolong the drain period to 12000kms as claimed. The drain cycle is normally 10000kms for the Alto.
mail4ajo is offline   Reply With Quote
Old 27th July 2009, 20:00   #127
Raccoon's Avatar
Thanked: 105 Times
12,000 km is claimed by who??
Suggest you stick to your usual drain period.
Old 28th July 2009, 19:23   #128
mail4ajo's Avatar
Thanked: 222 Times
Sorry, the claim was not from the forum. General internet reviews. Ok, will stick to the drain cycle.
So if the drain cycle cant be advanced, what else are the benefits apart from a smoother sounding engine?
Old 28th July 2009, 21:18   #129
R2D2's Avatar
Thanked: 1,134 Times
How about longer engine life & possibly better fuel efficiency? Engine oil is critical to both.
Rgds,
R2D2 is online now   Reply With Quote
Old 29th July 2009, 00:39   #130
Raccoon's Avatar
Thanked: 105 Times
Magnatec is not ment for extended use. Just stick to the recommended drain cycle.
The benifit that Castrol claims is that it protects your engine at start up. There are many reports that claim that this is not true in the sense that it protects about as much as any other oil of the same grade... esp. a semi-synthetic (maybe not even that). Besides this, there is no known benifit. If you are expecting more, you have gotten carried off by Castrol's crafty marketing hype.
IMO, it is overpriced, like most Castrol products.
Old 29th July 2009, 00:52   #131
SLK
SLK's Avatar
Thanked: 185 Times
I think, I already did somewhere. Maybe can update now.
My wagonR has done close to 2.5k with Mobil 1.
you do feel some difference initially, but it tends to get better after some kms, more than 15-20 days in my case i.e. 1200kms or so.
Is it better? YES.
How? free revving, less sound.
Will it be better for everyone/everycar? Can't say, as it depends on how much you notice such "feel good" differences. It's probably like 15-30% more free revving, some might not even notice that. WagonR would not become a swift with this Oil.
SLK is offline   Reply With Quote
Old 29th July 2009, 11:35   #132
sgiitk's Avatar
Thanked: 3,755 Times
In addition to distance take a look at the time interval as well. I work on 1 year / 10,000km (whichever is earlier) on all my mounts. In UK they talk of 10,000 miles so 12,000km may be Ok, but look at the calender as well.
sgiitk is online now   Reply With Quote
Old 29th July 2009, 13:22   #133
nitrous's Avatar
Thanked: 282 Times
The benefit is cold-start protection with these HC (Hydro-cracked) oil aka semi-synthetic.
They'll work at optimum far sooner than mineral oil.
Old 29th July 2009, 16:30   #134
Raccoon's Avatar
Thanked: 105 Times
Hydro-cracked oil is technically not semi-synth though legally it is. As end users, the technical aspect is far more important. Castrol could claim that its semi-synthetic due to the ester content in Magnatec. But how much of it do they add? Nobody knows and Castrol isn't telling. It can even be less than 1%, just to qualify for that tag.
So you can't really say for sure that Magnatec even gives the benifits of a decent semi-synth...
Old 29th July 2009, 21:33   #135
nitrous's Avatar
Thanked: 282 Times
^^ Used it plenty of times in my previous car. Have felt a significant difference.
Magnatec is real VFM compared to "exotic" potions. I'll ask Narayan to post his experience with the magnatec 10W40.
Experience - Castrol Magnatec Vs Total Quartz 7000 abhaybakshi Technical Stuff 22 25th October 2014 08:17
Castrol Bikezone = Castrol Bikepoint? UPDATE: Review of Ace Bikes, Bangalore (pg2) Soumyajit9 Motorbikes 20 21st July 2013 23:48
VW use Castrol Magnatec 5W40 for Polo, Why not EDGE? gaurav_chopra04 Technical Stuff 7 4th March 2011 00:46
OWS 15W40 vs Castrol Magnatec - Which is Better ibm_jennifer Technical Stuff 6 27th August 2008 02:20
Castrol R4 superbike engine oil for Honda Unicorn devsus Motorbikes 4 4th May 2007 10:43
