Old 8th October 2008, 08:35   #1
rahulsingh007's Avatar
Thanked: 43 Times
Exclamation How to fix a monogram ??
Hi Bhpians,
Some kid broke 'L' of the Chevrolet Badge of my Aveo I managed to get it back ,
On closer inspection I found out that I was sticked to the car body with some greyish stuff, can anyone thell what is it ?
Also, I used gold seal (rubber based adhesive) but it did not worl fie , so what shall be used now?
Note from Mod : Please take the time to type out your posts in full words as per Team-BHP rules and please take the time to re-read your post for typos before submitting. Thanks
Last edited by Rehaan : 8th October 2008 at 10:48. Reason: Please see note in post.
rahulsingh007 is offline   Reply With Quote
Old 8th October 2008, 12:13   #2
ankitahuja's Avatar
Thanked: 46 Times
Cut out an exact layer of 3M double side tape to put the 'L' back. This will fix it.
You might want to clean the residue on the car with some Diesel first.
Old 8th October 2008, 12:19   #3
Tejas@perioimpl's Avatar
Thanked: 4,932 Times
3M tape is a good idea. do not try any other double sided tape, it'll give way in a day.
Otherwise try araldite. Always works.
make sure the "L" is at the same level (depth-wise) as the other alphabets.
-Tejas
Tejas@perioimpl is offline   Reply With Quote
Old 8th October 2008, 13:43   #4
humm's Avatar
3M tape is the best high quality tape. They are the one used in door-visor's too, so its strong enough the hold the L behind your car.
Use the blade and cut the tape in the right manner and stick it the the L.
Before you stick the tape to L and L to the car metal, clean both of them very well with car wash and remove every stain or dirt and the job is done perfectly. cheers:
humm is offline   Reply With Quote
Old 8th October 2008, 14:26   #5
Thanked: 244 Times
snaronikar is our inhouse 3M guy, ask him, as 3M is also the OEM for some of these monograms and uses special bonding material.
Double sided tape will not last very long and araldite can spoil your paint if someone tries to pick again.
alternate way to fix neons on zen mclaren1885 Modifications & Accessories 11 17th August 2007 12:39
Planning to sell Esteem (help needed to fix selling price) Minardi Shifting gears 3 22nd June 2006 22:52
Fix-A-Flat available in India? panky12345 Technical Stuff 2 6th June 2006 10:29
How to fix General Motors amit The International Automotive Scene 10 21st April 2006 21:19
Quick fix for your Mobile Scroller/joystick 2L8uLoose Gadgets, Computers & Software 17 23rd March 2006 09:44
