Old 10th October 2008, 21:14   #1
Hashim's Avatar
Thanked: 32 Times
Default How to tune M1000 carb?
I have a Maruti 1000 and since few months I don't see water coming out of exhaust. Earlier lots of water used to come from it and mechanic said it means car will give good mileage. Does the carb need adjustment? Can you guys tell me how itís done? What I tried till now is adjusting screws in carb (one metal screw and other with plastic cap) but no success.
Hashim is offline   Reply With Quote
Old 11th October 2008, 02:17   #2
Thanked: 54 Times
go through this A PURRFECT M800 - DOES IT EXIST?! a pretty detailed guide. This should apply to a m1000 too, as they have almost the same carb.Timing and idle rpm might be different - confirm by calling up a MASS or some friendly neighbourhood mechanic
You might want to borrow or buy a dwell tachometer and timing light to get things really correct.
techn0l0gist is offline   Reply With Quote
Old 11th October 2008, 18:36   #3
Hashim's Avatar
Thanked: 32 Times
I didn't found timing light and tachometer from anywhere so went to my trusted mechanic for getting the carb adjusted. He removed the carb, disassembled everything cleaned with petrol and adjusted RPM and timing. Still no water from exhaust. Does it take long for water to travel from catalytic converter and reach muffler?
Old 11th October 2008, 19:06   #4
Jaggu's Avatar
Thanked: 8,670 Times
Water vapor condenses at tail pipe end and doesnt travel from cat to tail pipe, on a cold engine idle the car for 2-3 minutes to see this, also i see that you are running on lpg and might not happen since the exhaust is hotter. Also tuning/mixture adjustment has to be perfect with lpg line, and atmosphere should not be very dry or else it will be just a trace of water.
Old 11th October 2008, 19:41   #5
Hashim's Avatar
Thanked: 32 Times
Ya I have the LPG kit installed but when I take to mechanic I run on Petrol and all adjustment was done in petrol mode only. Actually my mechanic hates LPG :P
Old 11th October 2008, 21:09   #6
Jaggu's Avatar
So start in petrol and idle for few mins in morning watching the tail pipe and see if water condenses.
Old 11th October 2008, 21:40   #7
Thanked: 660 Times
It doesn't matter. The rpm is just slightly kept high in LPG.
Old 12th October 2008, 21:02   #8
Hashim's Avatar
Thanked: 32 Times
Problem solved ! I saw water in exhaust in evening when I returned home. I was so happy that started the car, rev it just to see more water dropping from it
How to tune your carb properly BUSA Motorbikes 90 14th August 2017 10:20
Self starter problem in M1000 Hashim Technical Stuff 0 14th October 2008 11:41
m1000 or zen engine harry2223 Modifications & Accessories 2 24th September 2008 14:37
Which of these Japanese machines would you to choose to extreme tune? Dippy The International Automotive Scene 31 5th November 2005 01:37
M1000 to M1600...?? elf Modifications & Accessories 2 4th January 2005 11:36
