Old 14th October 2008, 14:38   #16
Thanked: 15 Times
Going to take car tommorow to MASS and ask them to do as you guys suggested.I also noticed that the jerks are now uneven meaning, sometimes they are there and sometimes they are'nt. Could it point to that things are getting back to normal ? Just not sure so hitting out in all directions !
delhi2009 is offline   Reply With Quote
Old 14th October 2008, 20:39   #17
yasw_anth's Avatar
Default get the throttle body cleaned
visited my mechanic today. and got the throttle body cleaned and the ecm resetted, had a test drive for about 5km . was better than before.
though i had got the throttle body cleaned there was lot of carbon deposits, the mechanic suspected of poor quality petrol and excess dirt from the knN filter. he adviced me to change to a stock filter!! hope this solves the problem for now.. thank you all
yasw_anth is offline   Reply With Quote
Old 15th October 2008, 12:54   #18
ron_9191's Avatar
Thanked: 98 Times
I think it can be the spark plugs, but not always. Clogged fuel injectors can also give you the same problem. I remember driving one of my relatives Astra 1.6 with an unclean injector, the car was misfiring and jerking at around 2000RPM. I guess cleaning the injectors would help you solve the issue mate.
ron_9191 is offline   Reply With Quote
Old 16th October 2008, 00:24   #19
Thanked: 15 Times
Unhappy
Took car to MASS and they checked everything inside out and claim all is fine Iam not sure what my options are at this point for there were no defects reported by their systems even !
Old 28th October 2008, 11:48   #20
Thanked: 15 Times
Average for the past 1000 KM ever since this ordeal is 13.5 KM (City driving with 1/2 of the time AC ON) but jerks are still there . This makes me wonder...what could it be ?
Old 28th October 2008, 16:18   #21
Thanked: 44 Times
That's a good FE.
I still think it's water in your plug cables or somewhere along the ignition system. Cab you not reproduce it when the MASS are in the car?
filcord is offline   Reply With Quote
Old 1st November 2008, 09:08   #22
Thanked: 15 Times
Thumbs up solution finally !
MASS finally put 2 new coils alongwith the previously replaced cable and the problem is resolved ! They wanted to try out to detect which of the 2 was at fault but not taking any chances, i got both replaced. Lucas-TVS ones costed 1400 a piece. Thanks to all of you who responded on this thread to help ! cheers:
Old 1st November 2008, 13:23   #23
shrivz's Avatar
Thanked: 92 Times
Originally Posted by delhi2009 View Post
I've yesterday got the injectors cleaned, the 2 spark plug coils and the fuel filter changed but its all in vain. The car has gained superb pickup ever since these 3 things were done but i still have those jerks and they are more felt when the car has a cold start.
I thought you'd already changed your ignition coils! That was the first suspect..
shrivz is offline   Reply With Quote
Strange noise from Baleno at 100+ kinmist Technical Stuff 15 29th June 2010 03:45
Siena1.6 - Strange problem nitinbhag Technical Stuff 28 26th October 2007 08:32
strange fluttering sound in my baleno abhishek_rait Technical Stuff 15 29th June 2007 19:01
Strange Problem with VIVA CRDI mobike008 Technical Stuff 4 14th October 2006 11:51
