Old 19th August 2012, 17:11   #181
OffDaBeemer's Avatar
Default Re: What will be the effect of 100% coolant?
hello everyone,
i just got my 09 Ritz Vxi serviced at a local garage -
Replaced Engile Oil, Oil Filter and Coolant.
I have checked the manual for engine oil grades and coolant specs but missed to note down the quantities required
so here comes the trouble- the guy at the garage said that Ritz holds 6.5 Lts of coolant so I calculated and said I need 2 Lts of Coolant and 4.5Lts of Distilled water (30 - 70 Mix for petrol engines), came home and revisited manual to find that it only holds 4.4 Lts of coolant (1.3Lts of Coolant plus 3.1Lts of distilled water) Another thing is that while replacing, the service guy added 2 Lts of coolant plus just about 0.75 Lts of distilled water.
So here is my problem - the car now has 1.65Lts of old coolant(that probably didnt get drained) and 2.75Lts or coolant (which is 70% coolant with 30% distilled water), this makes me really worrying, should I drain half the coolant and then add more distilled water or re do the coolant service completely?
Expert advice
OffDaBeemer is offline   Reply With Quote
Old 19th August 2012, 18:10   #182
quattroa4's Avatar
Thanked: 143 Times
Using a 100% coolant also does not affect any parameter of the cooling system or harmful in any way . So my advice will be let it be as it is .
quattroa4 is offline   (1) Thanks Reply With Quote
Old 5th January 2013, 10:02   #183
searchingheaven's Avatar
Thanked: 1,365 Times
Originally Posted by khoj View Post
What could be harmful though is the so called distilled water. I say so as these days most of the battery distilled water is souped up with acid in trace amounts. Just enough so that when you pour it into your inverter battery it allows for quicker chemical reaction. While this is great for the battery water manufacturers sales it is certainly not good for the cooling system.
The water to use is the defrost water from your fridge or the water that your a/c (both heat exchange devices) lets out. The best of course is tap water no hassles at all.
What about aquaguard water?
searchingheaven is offline   Reply With Quote
Old 5th January 2013, 10:11   #184
khoj's Avatar
Thanked: 1,258 Times
Safe for human consumption = Safe for automotive usage.
Old 6th January 2013, 11:10   #185
sgiitk's Avatar
Thanked: 3,885 Times
See the graphs of Coolant Percentage v Freezing Point. The lowest temperature is about 65% coolant. Coolant also has various anti-corrosives, and water pump lube. So some (say 20% plus) is necessary, but unless you live in Ladakh 65% may not be necessary. 100% - well it is your money and your choice.
Some 30 years ago it was recommended to use distilled water in Aluminium blocks but modern anti-freezes have developed to the point where even with tap water you are safe.Just remember to change it as recommended - Honda claim a 10 year, 100,000km life for their coolant, but most have to be replaced every two years.
Old 6th January 2013, 11:52   #186
Thanked: 285 Times
I thought water was the coolant. And you add those green/red/blue liquids to the water to prevent the coolant(water) from freezing, evaporating, corroding etc. Putting 100% coolant seems to be a meaningless thing to do.
carboy is offline   Reply With Quote
Old 6th January 2013, 11:54   #187
mgh
Thanked: 33 Times
Strictly speaking, heat transfer is most efficient with pure water, the coolants are organic and are less efficient for heat transfer.
Having said that, the cooling system will be designed to work with whatever maximum percentage of coolant is specified + engineering safety factor - which would ensure that it would even work with 100 % coolant.
mgh is offline   Reply With Quote
Old 6th January 2013, 12:22   #188
Thad E Ginathom's Avatar
Thanked: 8,380 Times
Yep.
I think we repeat this conversation every few pages, along with it cropping up on other threads too.
I suppose that the combination of fluids is the "coolant." To call the stuff in the bottle "coolant," as opposed to "water" is certainly wrong. It's a "water-cooled" engine. Water plus additives.
Old 6th January 2013, 15:34   #189
Zed
Zed's Avatar
Thanked: 276 Times
Absolutely. From a thermal management perspective pure water is the best medium to dissipate heat from an automotive radiator.
Additives, commonly referred to as coolants or antifreeze, lower the freezing point AND increase the boiling point of water in the radiator at the same time. This effectively reduces the risk of water in the cooling system freezing at sub zero ambient temperatures which could cause irreparable damage to system. Most additives have corrosion inhibiting properties.
Zed is offline   Reply With Quote
Old 6th January 2013, 23:29   #190
Cracked cylinder block. Throw the engine away!
Back in the days before sealed systems I knew people who had suffered this.
Thad E Ginathom is offline   (1) Thanks Reply With Quote
Old 7th January 2013, 10:01   #191
Catalyst_delhi's Avatar
Thanked: 149 Times
I have tried pure coolant and the engine was at 98degrees at idling with the fan at 100% duty cycle (slow speed). The Engine refused to cool down quickly. I did not dare bring it out of the garage. I drained 50% of the coolant ( Ford Red OAT) and filled with distilled water. (5 lit for 60 rupees). The temperature did not exceed 90 degrees in a traffic jam. this is in a ford ikon 1.6. I did the pure coolant part for trial purposes only but did not have the guts to drive around with it.
Catalyst_delhi is offline   Reply With Quote
Old 7th January 2013, 20:19   #192
Zed
Zed's Avatar
Thanked: 276 Times
The fact that the vehicle was stationery made it harder for the cooling system to do its job. If you drove normally your coolant temperatures would have been lower even without the presence of any water in the system as ram air plays a vital part in engine cooling loop.
But you make a valid point that a mixture of pure water and additives, in recommended proportions, is better than 100% additives when it comes to heat dissipation.
Old 8th January 2013, 09:05   #193
Thanked: 149 Times
you are right ram air kicks is at approx 60km/h. But could not risk my HG and frankly speaking by the time i get ram air , getting stuck in a traffic jam is a higher possibility.
Old 8th January 2013, 15:00   #194
Zed
Zed's Avatar
Thanked: 276 Times
Yes and no.
When vehicle speeds are in the 50 - 80 kmph range (for most types of vehicles) the engine fan becomes redundant, more or less (exceptions prove the rule, as always ), as ram air speeds will reach levels of airflow which the fan generates at that operating point.
But Ram air aids engine cooling even at lower speeds.
Zed is offline   (1) Thanks Reply With Quote
Old 27th March 2013, 13:16   #195
gomzi's Avatar
Thanked: 125 Times
I just saw the TR6 episode of Wheeler Dealers yesterday and 1 thing in the show intrigued me. Ed poured a waterless coolant into the radiator. The waterless coolant is supposed to have a much higher boiling point than water and a much lower freezing point too.
I looked it up and found this company that manufactures these coolants http://www.evanscooling.com/products/coolants/
Is this available in India? Has anyone tried it out? Thoughts?
gomzi is offline   Reply With Quote
Coolant level low, but no symptoms? Ravich Technical Stuff 53 13th November 2016 18:14
800 Consuming coolant humyum Technical Stuff 28 5th March 2015 15:45
NANO effect and EURO effect in Small Car market allwheeldrive The Indian Car Scene 8 15th June 2009 22:29
Water or Coolant? Team123 Technical Stuff 21 24th April 2006 08:57
coolant guzzling Esteem chandan Technical Stuff 10 21st July 2005 12:28
