Old 31st October 2008, 14:28   #31
johnda's Avatar
Thanked: 11 Times
Originally Posted by Shashank.A View Post
what do you mean by 'locally' ? Authorized service station guys will not do some Abra Ka dabra. They will put in a bottle of coolant and top it up with water itself.
Its surprising that you are aware that there is no coolant there and still you want to think about it. Just go ahead brother, purchase a bottle Golden Cruiser, empty that into your radiator and after that keep fiiling the radiator with normal water, till it starts to overflow.
PS : By the way, try and go with your car to see what the Authorized service centers do to your cars in name of service, you will stop going there after that.
My nearest Honda service center is 3hrs drive away!! 'Golden Cruiser' that's what i needed a name. also this is the first time that this has happened, usually they have all aspects covered when I go in for service.
johnda is offline   Reply With Quote
Old 31st October 2008, 15:04   #32
iceman7's Avatar
Thanked: 259 Times
its kind of a weird coincidence. I have been thinking of topping up the coolant in my car for 2-3 days now, just wasn't finding the time. Today i come across this thread completly by chance.
Cleared a lot of doubts that i had regarding coolants and their concentrated use.
iceman7 is offline   Reply With Quote
Old 31st October 2008, 17:44   #33
Shashank.A's Avatar
In your case, you should have minimal reliance on the service station. For stuff like, coolant, oils, battery checkup, filters etc, you can very well rely on your local mechanic, as long as things are done infront of you.
Shashank.A is offline   Reply With Quote
Old 31st October 2008, 18:19   #34
johnda's Avatar
Thanked: 11 Times
Ya, i guess you are right, and especially the 'In front of you' part so often these smaller places can get work done, but you need to be around to see if it's done right.
Old 31st October 2008, 20:13   #35
vinit.merchant's Avatar
Thanked: 939 Times
Originally Posted by DarkEraser View Post
I read on the coolent bottle that we need to add 2 parts of water. A quick question came into my mind - What if I didn't added water or added less water say, 25% water and 75% coolent?
What will be the effect of no water or less water added to coolent?
Thanks in advance
My 2 Cents
All Coolant wouldnt allow the engine to heat up to the desired and recommended levels, or maybe take much more time to reach the desired temperatures. As discussed on another thread on T-Bhp 'How to get more mileage/average', if the engine is cooler than the desired temperature, then it consumes more fuel.
So this would have a straight impact on the fuel economy of the vehicle, Though unsure of the amount of impact.
Hope this helps.
vinit.merchant is offline   Reply With Quote
Old 31st October 2008, 21:10   #36
Thanked: 253 Times
Originally Posted by vinit.merchant View Post
My 2 Cents
Hope this helps.
No it does not help, Vinit! What you are saying is the exact opposite of what would happen in real life!
It's the water that does the cooling, not the 'coolant'!
Old 31st October 2008, 22:08   #37
Thanked: 939 Times
Oops. Am not so sound technically! I went by the term 'Coolant' and understood it as its function.
Old 1st November 2008, 07:56   #38
Thanked: 253 Times
Which is why Thad has been saying it ought not to be called 'coolant'. 'Anti-freeze' or 'additive' are the better terms!
The Englishman has a point!
Old 1st November 2008, 13:33   #39
Thad E Ginathom's Avatar
Thanked: 8,375 Times
Somebody was posting elsewhere as to whether he should worry that his coolant reservoir is nearly empty --- he's the one who truly is running on less than 100% coolant
It had better be 'additive' here down South: people would fell they were being ripped off, being sold anti-freeze!
Thad E Ginathom is online now   Reply With Quote
Old 2nd November 2008, 00:05   #40
johnda's Avatar
Thanked: 11 Times
didnt get the bands of coolant i was looking for, the Lubes shop guy told me that it was best that i didnt put anything that was sold in his shop, esp if mine is a OHC (dunno why he said that?). So i called Honda and I'm heading that way tomorrow anyways, The guy on the other side asked me to fill my radiator with Plain Water. do the 130Km journey and they'll help me with the rest.
1. I did the filling water part.
2. Am I doing the right thing by waiting and taking it to the service enter.
3. should I just go ahead and fill the Local stuff inspite of the guy himself asking me to go to Honda?
4. why is a silly issue like Coolant making me loose my cool (jus quoting Thad!)
Old 2nd November 2008, 01:36   #41
johnda... sorry for calling you "somebody". I should have looked back to the post
I think you are ok with water for a limited time. The problem is that stuff (well, iron, specifically) starts to rust, and the question is how quickly does it do that?
Hopefuly somebody knows...
Old 2nd November 2008, 07:57   #42
johnda's Avatar
Thanked: 11 Times
Thanks Thad, I'm heading to Tvm this evening and will sort the issue out pronto. I got a bit when the Lubes shop guy said "if it's a honda city then i dont have the brand you use, pls go to your service center". first time that was happening too.
And - I got myself some coolant too - cheers!!
Old 7th April 2009, 08:16   #43
I have 100% coolant.The (non amine) blue coolant,i got it filled fully this time.I dont think it would be bad idea this summer to have 100% coolant?
binoyjude is offline   Reply With Quote
Old 7th April 2009, 08:30   #44
Any idea whats the difference in the blue and green coolants?Can anyone tell me which one is best??
Old 7th April 2009, 12:55   #45
You should chose carefully according to which suits the colour of your car
Coolant level low, but no symptoms? Ravich Technical Stuff 53 13th November 2016 18:14
800 Consuming coolant humyum Technical Stuff 28 5th March 2015 15:45
NANO effect and EURO effect in Small Car market allwheeldrive The Indian Car Scene 8 15th June 2009 22:29
Water or Coolant? Team123 Technical Stuff 21 24th April 2006 08:57
coolant guzzling Esteem chandan Technical Stuff 10 21st July 2005 12:28
