| Technical Stuff Want to know your Vtec, ABS or intercooling better? |
| | Thread Tools |
| | #1 (permalink) |
| BHPian Join Date: Nov 2004 Location: New Delhi
| it seems that i cant get out of trouble this week... at a traffic light, when i switched off the engine and tried to turn it back on again...surprise...no self... :( well it had happened a few dozen times before and each time the culprit came out to be the Nippon Car security system installed in the car... it somehow disabled the self and nothing seemed to happen on tryiong to start my palio. what actually happened was that after turning on the battery when i went on to start the engine the battery lights on the dashboard went out and nothing and the self refused to strike. the security system was replaced + wire was replaced. problem solved! yesterday same thing happened but with a little difference.... this time around when i tried to start the engine the battery lights didn't go out and there was a slight whistle from the engine like it wanted to start but couldn't...after 2-3 repeated attempts it did start but the thing is quite horrifying... can you technical ppl out there, tell me what the hell is wrong with the car? the nippon engineer told me that there is some carbon stuck on the self, and that is causing this problem. but the car is just 7-8 months and 3400 km old. i am quite scared...please help!!! PS: there is an immobiliser in the engine of the palio if i am correct, and the security lock also has one...is it clashing? |
| | #2 (permalink) |
| Senior - BHPian | hi amit, the engine immobilizers from the security on the will not clash with the one on the engine, as the security is probably wired to the existing one along with the ignition cut off that the system comes with. as for the starting trouble, tell the service guys to check the starter motor solenoid, and the relay; any fault in either fo these will result in erratic starter behaviour. also, the "whistling" sound that you are referring to might be that of the coil rotating without actuating the bendix- so get that chcked too. and also, the carbon getting accumulated in the self seems unlikely as your car is just 3400 kms run, but even then, these are not the symptoms: the excess carbon would result in a "barking" noise, i.e, the starter will rotate, but it will take load, and will crank slower than usual. anyways, since your car is under warranty, get the starter motor serviced, while checking the above mentioned points. and if all else fail, even after repeated checks and afore mentioned ponters, get the starter motor replaced under warranty. (that is, if the fiat dudes will replace it... )
__________________ DAD |
| | #6 (permalink) |
| Senior - BHPian | the whistling sound you mention is of a failed starter motor (self assembly). It is a kind of slippage where the coil is turning but is not being able to transfer the power forward. Did your car start normally after a couple of tries? did it start fine the next time u tried after driving? It could be a one off case, sometimes mechanicals seem to be moody! hehe. Just incase it happens again i guess you could get it replaced under warranty since your car is almost brand new.
__________________ "I drive a Mitsubishi 3000GT, and I live a 1/4 tank at a time... For those 50kms or less, I'm free." |
| | #7 (permalink) | |
| BHPian Join Date: Feb 2005 Location: Thane
| Quote:
. I absolutely hate it when people use words like 'self' for the starter and 'shockups' for the shock absorbers.
__________________ Power without control is useless, bur a lot more exciting. Real bikes dont have cams. | |
| | #8 (permalink) | |
| Senior - BHPian | Quote:
__________________ DAD | |
| | #9 (permalink) |
| hey im back...net was down in my area... the starter motor was the culprit. but as usual the fiat guys didn't have the part available. their excuse: its last quarter and its closing time for the account books and no dealer is ready for a counter sale. so i gotta wait longer... lets see what happens? btw, topend_hooligan, i dont have a habit of saying starter each time i refer to my car's ignition switch. "self" is just fine for me and for 99.9% of indians. |
| | #10 (permalink) | |
| Super-Admin | Quote:
__________________ GTO Change the way you think, and watch the world change around you.
| | #12 (permalink) | |
| Team-BHP Moderator ![]() | Quote:
By the way, your messsage box is full. Clear it it up. | |
| | #13 (permalink) |
| Senior - BHPian | hey amit, remember me saying...."if the fiat dudes will replace it.... well, anyways, like i said, it will take time if youre going in for a warranty replacement. but, if at all those dudes at fiat ask for money citing some reason, go buy a brand new motor from a reputed O.E. spare part shop, and get the work done from your own trusted mechanic!!! p.s-at least that's what i'd do if i had to put up with this sort of crap from fiat dealers!! and autopsyche, well, it seems we think alike man!! you practically just offered the same explanation as i did!!
| | #14 (permalink) |
| Newbie Join Date: Mar 2005 Location: Chennai
| How old is the car and how many miles have you clocked. Also check the battery condition with the terminals. Is it sticky always or sometimes. If sometimes the problem may be with the solenoid only and not the motor. |
| | #15 (permalink) |
| @GTO: who is ready to pay for it? the car's under warranty and they would have to fix it at any costs! @iceman91: well its kinda not that. the car is the best in class. and after driving all the santros and zens and wagonRs around folks, it feels good to own a palio...::touchwood:: btw, from what i know you own a baleno which also doesnt carry a brilliant resale value...but still when it came down to giving ur hard-earned penny, u chose what was the best...right? @Rudra: if u know a trustable place in delhi, i would be very glad to know. i have just finished school here, dont know many places around...btw the inbox is all cleared up...waiting for ur reply. thanks. @autopsyche: you are absolutely correct on the situation. it gets started after a couple of tries...but still it is annoying...btw since u are in new delhi, do you happen to know any good workshops/tuners around? @veyron: ofcourse, i wont be buying anything from them. there is a guy at the dealer (supposed to be head), whose gonna get a yelling and thrashing of a lifetime if he refuses to replace it under warranty. any ways. there is still one last "brahmastra", the consumer court warning. hope it works @carbuff: as i said above the car's done only abt 3400, well now 3600... thanks i will get that checked too...may be theres no need for a change of the whole unit. btw the started motor is of the brand : LUCAS. i can definately get it through their head branch at Karol bagh, but is there a kind soul on this forums, who has the information abt the brands of the various "important spare parts" tha palio has. thanks all. |
| Thread Tools | |
Similar Threads | ||||
| Starter-Stop Motor for Palio | Seeler_Rebeiro | Technical Stuff | 12 | 16th July 2008 13:44 |
| Fiat working on Palio successor for 2010 | ashutoshb | The Indian Car Scene!! | 42 | 12th April 2008 19:22 |
| replaced palio starter mechanism | bottle | Technical Stuff | 27 | 27th June 2007 20:59 |
| Help: Palio AC not working | satish_appasani | Technical Stuff | 3 | 15th October 2006 22:55 |
| 98 ZEN starter not working | raghuram.cg | Technical Stuff | 7 | 3rd August 2006 14:15 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447
??? please elaborate- i didn't quite follow you..
