Old 13th October 2008, 12:24   #1
anarchist's Avatar
Question No Rev Limiter on the Getz CRDi????
I recently returned from a trip to Goa. My friend who owns a OHC Type 1 VTEC took the wheel after I finished my driving quota started off revving hard and I had my wary eye on the speedo and the RPM, and he was doing more than 5000 rpm on first second and third gears. The problem is the RPM shows a redline at ~ 4200/4500 rpm and he was going way over it touching 5500 rpm at times but there was no rev limiter in action. I am used to my Swift and I can feel the rev limiter coming into action close to ~6800 rpm and you can feel that the engine cannot take any further rev's, but there is a total absence of this on the Getz CRDi. I got my friend to control himself to less than 4000 rpm there on, but I checked again once I got back to Bangalore and I still found the car in the same position no REV LIMITER!!!!.
Any of you CRDi people out there faced the same situation or have you encountered the rev limiter coming on at the peak RPM??
I hope I dont end up damaging my engine...
anarchist is offline   Reply With Quote
Old 13th October 2008, 12:27   #2
Akshay1234's Avatar
Thanked: 7,242 Times
what speed was it doing in those gears at those rpms?
Old 13th October 2008, 12:34   #3
anarchist's Avatar
well I think the speeds were approx -> 1st 40+, 2nd 80+, 3rd 120+ probably more
Old 13th October 2008, 12:34   #4
kpzen's Avatar
Thanked: 1,655 Times
Why do u want to cross the redline when u have all the power and torque @ <4000 RPM..??
Its a D I E S E L with VGT but still it ain't a VTEC.
Old 13th October 2008, 13:21   #5
anarchist's Avatar
KP I don't want to cross the redline, and I am aware that there is more than enough power n torque <4k rpm, I wanted to check if the rev limiter does exist or its missing on the Getz CRDi
Old 13th October 2008, 13:52   #6
ssjr0498's Avatar
Thanked: 120 Times
get your car checked! IMO it should have a revv limiter.
Cheers,
Shrey
ssjr0498 is offline   Reply With Quote
Old 13th October 2008, 14:10   #7
Vivek.Martin's Avatar
Whether there's a Rev Limiter or not, I don't know. Haven't driven my CRDi like that yet.
But always advisable to stay at 4000rpm to avoid any damage to the engine. I cannot imagine taking my car to 5500rpm in 3rd gear! Even though its a good engine, it has its limits.
I hope your engine has run-in already.
Vivek.Martin is offline   Reply With Quote
Old 13th October 2008, 16:19   #8
nitrous's Avatar
Thanked: 285 Times
I've driven a Verna CRDI. And I remember the power tapers down 500rpm prior to the redline.
Understandably, your friend seems to have hard revved it since he's used to the OHC VTEC.
About your problem,don't mull over it since its not affecting anything as long as you have a mental rev-limiter. Although, just ask the service guys at the next service . Just don't go along fixing what ain't broken.
Old 13th October 2008, 19:13   #9
Thanked: 103,634 Times
Come to think of it, I haven't hit the limiter in my Jeep or the C220. The Jeep, well, understandable for such a basic oldschool engine. But the C revvs beyond 4500 rpm (easily)...a little more than you can feel the engine getting strained. I don't take it over, but the rare times that I have, it is the engine that has been stretched. No cutoff.
Agreed with kpzen : No point revving diesels too high, it's just a waste as you have left your torque behind.
I am curious to know if any others have hit revv-limiters in Indian diesels.
P.S. Hahaha, that sounds like a typical high-revving Vtec guy.
Old 13th October 2008, 22:27   #10
noidaboy's Avatar
Thanked: 260 Times
IMO the diesel dont hit limiters like petrol cars.. ding ding ding style,They simply go and stop at a point.
noidaboy is offline   Reply With Quote
Old 13th October 2008, 22:31   #11
greenhorn's Avatar
Thanked: 1,519 Times
Beyond a point, I've actually felt like going backwards (especially on inclines) after i spun past the peak torque/power band, Besides, like kpzen said , there is nothing interesting beyond 4k anyway, and you would have noticed it, unless you were going flat out on level ground
Over revving MPFI Zen Engine( revv limiter doesnt cut at 6000 rpm!!) speedsatya Technical Stuff 4 30th October 2010 15:21
NHC engine revv limiter not working? drsnt Technical Stuff 8 23rd May 2010 21:31
Satellite speed-limiter system starts trials anjan_c2007 The International Automotive Scene 11 11th January 2010 01:44
Verna Crdi Vs GetZ Crdi. EDIT : Finalising on Getz! aks_karthik Hatchbacks 74 17th May 2009 10:22
