Closed Thread
Old 14th October 2008, 13:41   #1
lohithrao's Avatar
Thanked: 163 Times
Default Palio- Temprature Gauge
Folks did notice that the engine temperature needle goes above the half mark when driving in slow moving traffic and while driving on ghat(bad roads so had to drive slowly, lower gears)
So is this normal?
Car: Palio Adventure
lohithrao is offline
Old 14th October 2008, 13:47   #2
DueLLeR's Avatar
Thanked: 61 Times
Ideally, the temp gauge should remain static once the car has warmed up fully, regardless of the driving conditions. You might want to check the coolant level in your car. Also, check your radiator for any rusting/leakage. Hope that helps.
Cheers!
DueLLeR
DueLLeR is offline
Old 14th October 2008, 13:51   #3
moralfibre's Avatar
Thanked: 6,533 Times
Hi Lohit, this thread (Palio 1.6 Sport Temperature doubt) might have some useful info.
moralfibre is offline
Old 14th October 2008, 14:49   #4
Technocrat's Avatar
Thanked: 2,589 Times
Thanks MF, lohithrao please continue the discussions on the thread MF gave.
Thread Closed
Technocrat is offline
Closed Thread
Tyre pressure gauge and portable inflator pump / foot pump adityapd Modifications & Accessories 731 19th July 2018 12:33
Scan Gauge Kaizer Sozay Modifications & Accessories 160 23rd September 2013 10:31
Fuel Gauge Problem - Contessa & Esteem falcon Technical Stuff 14 12th October 2008 10:54
Temperature Gauge links to Fuel Efficieny 2fast4u Technical Stuff 12 21st June 2006 15:39
Problem with fuel gauge in Esteem frankmehta Technical Stuff 3 14th April 2006 18:05
