Old 16th October 2008, 11:35   #1
zuch's Avatar
Default Ikon Engine Overheating and Damage
I am posting a query on behalf of my friend. He is having problems with his ikon. Here's his query
I have a 2001 model ford ikon 1.6.
Recently it's getting overheated and stops when its driven continuously for around 15 kms. I had got it checked at one of the ford authorized service centers. They told me that the engine-head has melted a bit and a replacement would cost around 35 K.
I have also heard that some of workshops have this facility where they machine the melted region to created a new face on the engine-head,at much lesser cost.
Can anyone tell me if this can be done at a workshop in Delhi?
Should he get this done from Ford or from another workshop? Also can this kind of damage be repaired completely or will this cause recurring problems?
zuch is offline   Reply With Quote
Old 16th October 2008, 13:41   #2
Thanked: 103,332 Times
Your friend is still driving it? I am pretty sure that a malfunctioning fan caused the overheating.
Well, his car is 7 years old now and thus, market value would probably be a lac odd. I'd say choose a competent aftermarket workshop, get the repairs done and save some $$$. Ford authorised are generally very expensive.
Of course it can be repaired completely. How many kms on the meter?
Old 16th October 2008, 13:53   #3
esteem_lover's Avatar
Thanked: 451 Times
I cant believe this 'engine head melting a bit' story. First make sure your radiator is fine, coolant is topped up, the fan is working properly & ensure the thermostat functions too.
Old 16th October 2008, 14:00   #4
Eddy's Avatar
Thanked: 5,065 Times
Do not trust Ford, and especially if it is Harpreet Ford. Take him to a good local garage and get it worked upon. The engine melting thing might be all hogwash.
Eddy is offline   Reply With Quote
Old 16th October 2008, 14:41   #5
as the others said, find a competent non company mechanic and find out. look for bosch car service centers in delhi as well.
do all the checks mentioned by the others and have the water pump checked as well. it may require a change. costs around 2k.
i find the engine head theory hard to believe. it's more likely a blown head gasket which is causing loss of compression. you will certainly need to get it changed based on what you wrote. head gasket costs around 1600 + another 900 or so for head bolts.
dont wait - get it done ASAP. if needed get it towed to the service center you decide on taking it to.
silver_shadow is offline   Reply With Quote
Old 16th October 2008, 14:44   #6
suman's Avatar
Thanked: 257 Times
Which workshop was it Zuch, it sounds very much like that one that used to be on Mathura Road? All their diagnosis ends up with the head being replaced!
It sounds like a malfunctioning fan to me but if he's been driving it around continuously, God knows what other damage it may have caused (including damage to the head).
Ask him to get a second opinion. Maybe he should take it to the cluster of mechanics in that market on the opposite side of Hyatt (Ring Road), what's it called? They fix pretty much all kinds of problems there.
Old 16th October 2008, 20:01   #7
gd1418's Avatar
Thanked: 656 Times
It is called the Paalika Palace.
Old 17th October 2008, 12:59   #8
ssjr0498's Avatar
Thanked: 120 Times
@ Zuch,
I have personally experienced something similar and by that experience let me share some info.
The "head melting" that they are talking about is better known as "head warp". As you have menitoned that you friend was driving the car even when he was aware that the car was overheating, there is a very great possibility that the head might have warped due to excessive heat.
What the mechs generally do in this case is that they shave off .25, .5 mm depending upon the damage caused to the head.
Once this is done the head is almost like new, however the compression will increase.
You need not necessarily get it done from the factory, however, when approching a local mech please make sure you have the head checked. If there is warpage and you go ahead and replace the head gasket, I can assure you the head gasket will blow again.
Cheers,
Shrey
ssjr0498 is offline   Reply With Quote
Old 18th October 2008, 15:29   #9
abhik's Avatar
Its actually Palika Bhawan, that place is damn expensive, atleast for most things, till my Dad was there as a magistrate it was inexpensive for me but unfortunately he has got transferred to lajpat nagar.
Try EOK, opposite storm, Jamrudpur Market.
abhik is offline   Reply With Quote
Old 18th October 2008, 15:30   #10
abhik's Avatar
Originally Posted by ssjr0498 View Post
@ Zuch,
Cheers,
Shrey
This is almost like getting a porting and polishing job done, but how does one lower the compression.
Old 18th October 2008, 19:13   #11
shaving off a bit of the head reduces the volume pf the space in the cylinder where the air/fuel mixture gets compressed, thus increasing the compression ratio. porting and polishing is a bit different.
Old 18th October 2008, 19:47   #12
abhik's Avatar
I am a little confused about porting and polishing though but i know for sure that CR needs to be lower for best performance after porting and polishing.
But after shaving the head to get rid of the warped bit, CR is increased, how does one lower it down without changing pistons.
Old 19th October 2008, 00:25   #13
zuch's Avatar
Thank you everyone for the replies. I had forwarded the thread to my friend and he is very thankful. I'll speak to him tomorrow and get an update from his side.
He bought it second hand and we suspect the meter was tampered with. So we can't tell the exact reading but I think it would be around a lac.
Absolutely spot on! He got it checked at South City Ford!
@ Zuch,
Cheers,
Shrey
Thanks but I have a few questions
  1. You've said that the compression will increase. So how will that affect the engine?
  2. Are you saying that even after repairs the problem will recur (assuming there is a head warp)?
Old 19th October 2008, 00:41   #14
Thanked: 660 Times
This is a small thing that most head grinder ignore, atleast most that I met here in Guj and Raj. They just mill the head and resurface it. Big Mistake!!
First the wrapping should be straightened and corrected before machining it for a good surface.
So your query...
1. Compression will increase as the chamber will be smaller resulting in predetonation (matlab misfire karega)
Also cam timming (valve opening closing) will be disturbed (again as a result will misfire)
2. Ofcourse, read No.1 again
Old 19th October 2008, 15:19   #15
abhik's Avatar
So your query...
Which means unless a good job of it is done he should go ahead and buy a second-hand or a new head to get the car in proper running condition.
@Zuch i bet your friend must be wishing he had bought a Honda City, then he probably would have loved to get the head replaced with a B16A or something.
A little while back i had asked Harpreet Ford Vasant Kunj about the monetary damage i would have to incurr if my Ikon's head get damaged and they gave me an approx. quote of Rs.50000.
So i thought if incase (God Forbid) this happens to me, rather than paying Ford 50K i could head to a tuner get the head warp sorted out, get it ported and polished and maybe save some for an aftermarket high lift cam aswell.
BTW: Can someone please tell me if CR can be reduced without changing the pistons.
Indica V2 DLS - Engine overheating/AC issues ajaysurfs Technical Stuff 8 18th June 2012 20:54
Ikon 1.8 Diesel Overheating - Help required stable rock Technical Stuff 6 8th October 2010 18:01
Engine Overheating... Siena 1.6 urdudesamy Technical Stuff 17 13th December 2008 10:34
Esteem - engine overheating - TECH2 gives normal reading ad75 Technical Stuff 22 10th March 2008 12:01
Engine Overheating: Urgent Help Needed! Su-47 Technical Stuff 14 3rd March 2007 10:38
