Old 29th May 2007, 10:31   #76
mail4ajo's Avatar
Thanked: 261 Times
Originally Posted by vid6639 View Post
I'd like to know how difficult it is to sown shift to 1st at really slow speeds.
Usually there are a few speedbreakers that one needs to negotiate in 1st gear. While approaching the hump at a really slow speed, many a times the car refuses to slot into 1st.
Vid, I push to neutral for a moment and then shift to first when the car is almost dead slow. This helps the plate and flyweel to arrive at almost similar speed.
Of course you cant shift like in a WRC car.....
mail4ajo is offline   Reply With Quote
Old 30th May 2007, 00:09   #77
spetnaz's Avatar
May be off-topic, and may have been answered somewhere else: Is it ok not to use first gear at all - except when really needed, like a start up a ramp or something?
I used to skip the first gear in the scooter and the Yamaha YD125 I used to drive, and carried on the habit to cars. I rarely use first gear - except may be a start up the ramp or when the car is loaded. This gives me a slower start, but there's one less gear shift to do. Is this ok for the car/gear box/FE in the long run?
spetnaz is offline   Reply With Quote
Old 30th May 2007, 16:19   #78
DieselFan's Avatar
Thanked: 234 Times
Skipping gear 1 is not at all advisable as it puts heavy load (Due to inertia) on the engine. Gear 1 is to overcome inertia of the car, and once the car is in motion switch to gear 2.
DieselFan is offline   Reply With Quote
Old 30th May 2007, 17:50   #79
mail4ajo's Avatar
Thanked: 261 Times
I used to skip the first gear in the scooter and the Yamaha YD125 I used to drive, and carried on the habit to cars. Is this ok for the car/gear box/FE in the long run?
This is what bus drivers do. They start with 2nd gear. You are likely to wear your clutch faster than normal.
Old 30th May 2007, 22:15   #80
revvedup's Avatar
Slightly ot but when trying to derieve maximum perfomance from my car for eg. those 0-100 runs I usually shift at rpm at which the car develops maximum power output but some also say that we should shift gears at the rpm at which your car produces max torque.Out of the above which is more appropiate.
revvedup is offline   Reply With Quote
Old 30th May 2007, 23:46   #81
sarath's Avatar
I think its more appropriate to shift at the rpm at which the car produces the maximum torque.
sarath is offline   Reply With Quote
Old 31st May 2007, 16:33   #82
Shan2nu's Avatar
Thanked: 89 Times
It's the rpm band between max torque and max power that gives you best performance. Shifting at max torque rpm will not give you any gains.
Shan2nu
Old 31st May 2007, 19:41   #83
revvedup's Avatar
How can one do this like if the car produces max power at say 6000 rpm and max torque at say 4500 rpm so where should one shift or one should just shift once the car refuses to accerlate more in that gear.
Old 31st May 2007, 19:48   #84
sarath's Avatar
Shan2nu
You are right Shantanu. I've put it in a wrong way in my post.
Old 31st May 2007, 21:56   #85
kpzen's Avatar
Thanked: 1,655 Times
Shift when u reach 6000 rpm..
Old 16th October 2008, 20:58   #86
Nitronium's Avatar
Thanked: 19 Times
Default Ideal Gear Shifts
I'm not sure whether this topic has already been discussed, so mods, delete if so and point me towards the right thread
The query is simple. How do you determine the ideal gear shift pattern on the car you're driving. Of course, i refer to performance driving, where economy is NOT the prime consideration.
I assume it is foolish to assume red lining is not the best rpm level to shift up?
Note from Team-BHP Support : Thread MERGED. Please use the search feature before creating a new thread on a topic that might already exist. Please continue your discussion in an existing thread. This will keep all the relevant information in one place and make it easier for readers in the future.
Nitronium is offline   Reply With Quote
Old 16th October 2008, 23:04   #87
Hashim's Avatar
Thanked: 32 Times
When I am driving alone on good road in my M1000 and not in mood to rev high, I just shift from 2nd gear (25-30kmph) to 5th gear (call me lazy) and car go smooth without any knocking! I can even turn in 5th gear if I maintain speed while turning. However this is just for good with not much traffic (inside my campus roads).
Hashim is offline   Reply With Quote
Old 17th October 2008, 00:53   #88
Thanked: 660 Times
@ hashim
dude your car sure has the carb set for higher rpm than normal!!
Old 17th October 2008, 09:25   #89
DieselFan's Avatar
Thanked: 234 Times
By doing this you are consuming more fuel. Try shifting the gears at 2500-3000 rpm band and see the difference. Also get your carb tuned to a lesser idle RPM level (If it is high).
In addition to low FE driving in higher gears means lesser control over the car. So you need to be careful in that aspect.
Old 17th October 2008, 13:51   #90
Thanked: 103,727 Times
Actually, you can shift lower (say <2000 rpms) in a petrol if FE is what you are looking for.
Hard gear shifts in RTR rdna Motorbikes 41 7th April 2011 00:06
A little help with Pulsar gear shifts FanaticOnWheels Motorbikes 6 7th March 2010 05:31
Ideal Gear Shifts for a Lancer Neonfish Technical Stuff 2 22nd June 2009 07:13
Santro gear shifts suddenly into neutral nura Technical Stuff 18 11th August 2008 14:21
Toyota launch of compact hatchback shifts up a gear navdeep The Indian Car Scene 9 13th April 2007 11:44
