Closed Thread
Old 20th October 2008, 00:54   #31
amit_mechengg's Avatar
Thanked: 1,556 Times
AutoPundit : Indian automobile news and reviews Maruti’s 1 Lakh car : Suzuki Cervo
check this out guys. is there any hint for turbos landing in india? our authorised service centres will be able to do the job then?
amit_mechengg is offline
Old 20th October 2008, 01:00   #32
Thanked: 660 Times
@ thread starter
Is your car 5 speed??
please PM me the details of your tuner. I need to ask some finer points. So next time I avoid blowing things up and save money.
These overzealous car blogs (which is now in tons) are crazy.
No car service station does the turbo installation, nor will they in the future. Its the tuners or specialized divisons jpb.
BMW has M, Merc has AMG, Fiat have Abarth, Will suzuki have similar, that too in India, hell no!!
SirAlec is offline
Old 20th October 2008, 17:11   #33
im_srini's Avatar
Thanked: 398 Times
Talking
Originally Posted by racerdabba View Post
i recentely turboed my Maruti 800....
Plus some more engine mods like increased he compression ratio, and used higher heat rated Spark Plugs..
together, they propel the car to almost 170!!!
but the engine oil becomes very hot...
i installed an oil cooler too, but dint help.
ny ideas u guys??
OMG This is serious stuff ! Could we please have some build & engine-bay pics ?
Are you seeing 150 degrees C after the oil-cooler install ?
By how much has the oil cooler reduced temps, if at all ?
Are your oil pressure values within range ?
You could try running a bigger sump with more oil, or you could try fabricating cooling fins on your existing sump - but I don't think these would help much. You might want to see if you could upgrade your oil pump too (but I think this could be a tad difficult with some machining of the block involved). You might also want to site your oil-cooler better &, for now, run with lower boost.
P.S. - Could we also have some details regarding the Esteem brake upgrade on your M800 ? Did you change the disks & calipers to those of the Esteem ? Any modifications that you had to do to the knuckle to accommodate the bigger calipers ?
im_srini is offline
Old 20th October 2008, 17:58   #34
What have you done for safety ? Do put a roll cage, nice work waiting for the pictures
Kinetik is offline
Old 20th October 2008, 20:00   #35
now everyone is eagerly waiting for the pics under the hood. please post it ASAP. also give the technical details of your setup.
mainly who did the setup for u? did u go to any maruti service station or do you have any specialized workshops in kolkata
Old 30th October 2008, 11:40   #36
SLK
SLK's Avatar
Thanked: 192 Times
Please post some real serious pictures. . .
As for the speedo, My friend's car beats/competes your's without any mods.
How many kms/h would you count this as? - BTW this is 93 model
SLK is offline
Old 30th October 2008, 17:36   #37
Mpower's Avatar
Thanked: 1,687 Times
MOD NOTE: This thread is locked until the author comes back with underhood pictures of the car
Mpower is offline
Closed Thread
Absence of Oil Cooler in New Swift - How important is it? Sankar Technical Stuff 37 9th October 2014 20:40
My Turbocharged Maruti 800 MPFi swiftboost Modifications & Accessories 64 7th July 2014 03:09
The Unusual Oil Cooler - How Effective? dhanushs 4x4 Technical 17 11th April 2014 16:45
Oil cooler for 350 mankamble Motorbikes 9 8th February 2010 13:55
