Old 20th October 2008, 16:25   #16
Shashank.A's Avatar
Originally Posted by abhik View Post
Unless you were serious about Raid De Himalays!?
You never know bhai. I love to take this car for drives. Remember, it does not have rev limiter.
Originally Posted by ashthedivx View Post
Shashank Bhai, nothing to worry.. both are more or less equivalent.. Look at the pocket friendliest one
Do take care from whom you get it installed, as this is a job for which one needs to be very much experienced.
Thats what I was thinking about.
Originally Posted by ankitahuja View Post
My friend also recommends a Korean brand in the market called 'PHC' which is very good too. The all India distributor is in Kashmere Gate.
PHC is a collaboration of Valeo only. In Patel Nagar, its available for Rs.1260. The Ceekay one is available for Rs.1950 approx.
If you ask for Valeo Clutch, they give you PHC only. However its the Blue box. I am wondering whats the difference in the Green Box, Valeo marked clutch.
Shashank.A is offline   Reply With Quote
Old 23rd October 2008, 09:42   #17
Shashank.A's Avatar
I have got the Ceekay Clutch installed. Total cost Rs.2900.
Clutch Assembly = Rs. 1950
Bearing = Rs.450
Labour = Rs.500
Old 23rd October 2008, 14:23   #18
ankitahuja's Avatar
Thanked: 46 Times
Shashank, I'm very sorry for not posting the prices before. It completely skipped my mind.
What you paid for the Clutch Assembly is almost the same, considering the quote I got.
Where did you get this done from?
Old 23rd October 2008, 14:39   #19
Shashank.A's Avatar
I know this. Fortunately I do not live in South Delhi, being a resident of Patel Nagar, Karol Bagh is like a next door neighbor for us. So the rates of parts in Patel Nagar as well are quite decent.
Got it done from our family 'mechanic' , in Patel Nagar only.
Old 23rd October 2008, 23:17   #20
Shashank.A's Avatar
just to let you, the car reached 95 kmph in 2nd gear, and there was still some power left. Is it good enough ?
Old 23rd October 2008, 23:41   #21
abhinav.gupta88's Avatar
Thanked: 310 Times
I Guess that's good enough for a 1.3 Carb engine
Congrats for finally getting the picaso back in shape ( except the body )
Old 24th October 2008, 02:28   #22
adi99's Avatar
May be off topic but how are these compared to Exedy clutch. I have seen many modified cars using this. Is Exedy meant only for modified cars? I have asked similar question in the Swift modification thread but no answer!
adi99 is offline   Reply With Quote
Old 29th October 2008, 08:39   #23
ScarySkulls's Avatar
Thanked: 19 Times
Wise choice. Ceekay is the way to go!
@adi99-> IMHO, every petrol swift needs an upgraded clutch. Exedy Stage1 fits the bill perfectly.
ScarySkulls is offline   Reply With Quote
Old 30th October 2008, 20:03   #24
adi99's Avatar
Thank you, ScarySkulls! So Exedy stage1 will be much better than ceekay and valeo. Correct? How much does it cost in Bangalore, any idea?
Old 18th September 2009, 13:09   #25
Mr_Bean's Avatar
Thanked: 140 Times
Default ceekay or valeo clutch for baleno?
I recently brought my baleno, have given it for servicing. Today I got a call saying that there is a clutch slippage & it is better to change the clutch.
So I am wondering which brand would be better for the baleno, the ceekay or valeo?
MASS recommends valeo, they say it is lighter on the foot. On the other hand ceekay's are hard and tend to last longer.
Other mods:
Pipercross air filter
Quartz semi-synthetic fluid
To be done next week:
Change of tyres to continental (195/60/R-14)
Lenso Samurai series or stamford wheels:
Mr_Bean is offline   Reply With Quote
Old 18th September 2009, 15:23   #26
gigy's Avatar
Thanked: 41 Times
I have bad experience with valeo twice ( its soft but gives up in heavy ghat traffic) so recommend ceekay ( my friend uses it, clutch is harder than mine)
gigy is online now   Reply With Quote
Old 9th September 2010, 15:58   #27
rr_zen's Avatar
Thanked: 268 Times
Bump !
I wanted to go in for either Asco or Daikin for my G13B Esteem but since neither of them were available, had to settle down for Ceekay or Valeo. Got a call from the mechanic that he managed to get Valeo. Not sure how its going to turn out. Keeping my fingers crossed.
P.S: Any sources where one can get Daikin or Asco for the Esteem ?
rr_zen is offline   Reply With Quote
Old 9th September 2010, 20:09   #28
dr.faramroze's Avatar
Thanked: 13 Times
70% of UK cars run on valeo clutch. Valeo is a trusted brand in other countries like Australia too. I had used it in my Rover MkII.
dr.faramroze is offline   Reply With Quote
Old 8th June 2011, 12:41   #29
sanjusahu's Avatar
Default Re: Ceekay VS Valeo, which Clutch
there is clutch bearing sound in my zen, do i need to change entire cluth assembly to change the bearings...
sanjusahu is offline   Reply With Quote
Old 8th June 2011, 16:46   #30
Thanked: 152 Times
It depends on how long you have run your car on your current clutch ?
How is the clutch feel / slippage etc ?
Once you open up to change the clutch bearing see what is the condition of clutch , pressure plate , flywheel too and then you can make a informed decision whether to change or not .
You can just change the clutch bearing too .
Trust_In_Thrust is offline   (1) Thanks Reply With Quote
Valeo Innovation Challenge for Auto Engineering Students. Prize = Ä100,000 GTO Technical Stuff 0 22nd January 2014 11:03
Swift D-Clutch/Gear Problem : Competent Motors unable to solve the clutch shudder Eddy Technical Stuff 48 8th September 2013 23:03
Problem with Clutch - Clutch cylinder replaced! Hats off to Talera Motors! Chevy_lover Technical Stuff 0 24th September 2008 14:13
Which is the right Sequence Clutch-Brake Or Brake-Clutch ankura12 Technical Stuff 2 9th July 2007 10:02
wet clutch vs dry clutch and slippers clutches devsus Motorbikes 7 16th May 2006 10:08
