Old 8th June 2011, 17:06   #31
sanjusahu's Avatar
Default Re: Ceekay VS Valeo, which Clutch
Originally Posted by Trust_In_Thrust View Post
It depends on how long you have run your car on your current clutch ?
How is the clutch feel / slippage etc ?
Once you open up to change the clutch bearing see what is the condition of clutch , pressure plate , flywheel too and then you can make a informed decision whether to change or not .
You can just change the clutch bearing too .
well i bought this used zen then that is the only way to check i can here enough nagging sound from the engine..not able to verify its coming clutch is one..i can hear
sanjusahu is offline   Reply With Quote
Old 8th June 2011, 22:07   #32
Thanked: 152 Times
Infractions: 0/1 (5)
You need to check the hardness of your clutch , how much the clutch cable has been tightened etc.All these are good indicators of health of clutch.
Also when you start from idling if there are any judders then flywheel, pressure plate can be culprit .
I believe Zen's clutch plate can easily last 1,00,000kms if driven properly .
Another one is hit the rev limiter on first and immediately shift to second and see if you can get the wheel spinning (on a mpfi zen though) .If yes you have a great clutch and a great healthy engine .
Trust_In_Thrust is offline   Reply With Quote
Old 9th June 2011, 05:27   #33
1self's Avatar
Thanked: 266 Times
Guys,
Valeo is OEM for Hyundai cars, as well as suppliers for Exedy. So, Valeo wins hands down.
1self is offline   Reply With Quote
Valeo Innovation Challenge for Auto Engineering Students. Prize = Ä100,000 GTO Technical Stuff 0 22nd January 2014 11:03
Swift D-Clutch/Gear Problem : Competent Motors unable to solve the clutch shudder Eddy Technical Stuff 48 8th September 2013 23:03
Problem with Clutch - Clutch cylinder replaced! Hats off to Talera Motors! Chevy_lover Technical Stuff 0 24th September 2008 14:13
Which is the right Sequence Clutch-Brake Or Brake-Clutch ankura12 Technical Stuff 2 9th July 2007 10:02
wet clutch vs dry clutch and slippers clutches devsus Motorbikes 7 16th May 2006 10:08
