Whenever i shift from first to second, the feeling is horrible. It feels plasticy-clicky type and ruins the driving pleasure and shifting experience.
I have had this problem for 2 years, Mandovi rejected it as Normal. (since then i have stopped going to Mandovi)
After opening the center console so many times, and removing the entire shifter housing and studying the problem, I have finally discovered the problem lies with the shifter cable itself.
There is a slack (play) in the cable (right side-up down cable). The cable isnt entirely a cable. The cable ends are joint with a metal pipe (see pic). This is where the play is (aprox 10 mm play). Now I dont know how to reduce the play, between the cable and the metal pipe joint itself.
The only solution may be to get a new cable. If anyone knows any solution let me know.
I also want to know how to remove the cable from the Transmission on a Swift. They are not coming out. The design is not simpler as a Honda.
Sample pic
anyone?
Also, does anyone know how to pull off he cable out of the Transmission?
It looks like there is come kind of luck nut, not sure.
