Old 19th October 2008, 20:24   #1
Thanked: 101 Times
Default Ignition Taking Longer Crank
Recently My Accent is taking longer cranck than usual . Earlier car used to start in half cranck, while now I'll say it takes at least twice the longer duration. Everything else is normal, pickup and fuel consumption are both like before. The problem is only at the time of starting the engine. Hot engine or cold engine doesn't matter. Petrol has been refulled twice so the quality is not the concern and it's the same pump from were I've always filled up.
Request you all to kindly help me
saurabhkum is offline   Reply With Quote
Old 19th October 2008, 20:40   #2
Vid6639's Avatar
Thanked: 19,385 Times
Is this just after a service? You may need to clean your spark plugs or get them replaced. The spark plug may have increased and may need to be adjusted or they are dirty.
This could be one possible reason.
Old 19th October 2008, 20:44   #3
Hashim's Avatar
Thanked: 32 Times
Get the spark plugs cleaned and gap adjusted. Battery voltage and acid gravity checked and most important the ignition distributor checked too.
Hashim is offline   Reply With Quote
Old 19th October 2008, 23:23   #4
nitrous's Avatar
Thanked: 282 Times
How old is the battery?
Old 20th October 2008, 09:08   #5
naveen.kk's Avatar
Thanked: 29 Times
if above all are looked in, and if the problem is persisting, then change the fuel filter, and airfilter in order.
Thanks,
Naveen.KK
naveen.kk is offline   Reply With Quote
Old 20th October 2008, 19:36   #6
Thanked: 101 Times
Battery is 2 years old and is perfect condition. I've replaced spark plugs around 3000 kms back to Irridium so een they souldn't be problem, apart from the crank time there is absolutely no difference in car behaviour.
Old 20th October 2008, 20:21   #7
Vid6639's Avatar
Actually the iridium plugs maybe the problem. Please try with stock plugs.
Also try measuring the battery voltage just to make sure it is getting fully charged. It maybe in good condition but you can verify if charging is happening completely.
Old 20th October 2008, 21:04   #8
Thanked: 54 Times
why dont you get the starter motor checked ? the solenoid contacts might have worn out .
Old 9th September 2017, 12:54   #9
sdp1975's Avatar
Thanked: 920 Times
Default Re: Ignition Taking Longer Crank
I have a 8 year old Punto MJD that had done 1.25 lac km. I've seen that the first start in the morning takes a single crank, but subsequent starts take 2-3 cranks.
Does this indicate a weak ignition coil , or any other problem ?
sdp1975 is online now   Reply With Quote
Old 9th September 2017, 13:09   #10
abhishek46's Avatar
Thanked: 1,944 Times
The first thing you should get checked is the Battery. Is your Battery in good condition?
Do you any equipment installed which sap power from the battery when you start off your journey?
abhishek46 is offline   Reply With Quote
Old 9th September 2017, 13:28   #11
sdp1975's Avatar
Thanked: 920 Times
The battery was purchased in July 2015, so it's just above 2 years old. I would expect it to be in decent condition , although I have not got it checked.
The only external fitment that I have is a dashcam and I don't think that's going to drain the battery.
Converting Light Crank to Heavy Crank in Royal Enfield Standard Bullet 350 1996 Model navin_v8 Motorbikes 63 9th October 2013 20:41
santro (Nov 2004) crank shaft failure at 30000km msvilkhoo Technical Stuff 15 11th March 2008 23:02
Forged Baleno Conrods , Crank , performance cam and intake manifold for SALE !!!! mclaren1885 Shifting gears 0 24th April 2007 23:23
What is Crank Scraper finetuning Technical Stuff 6 26th October 2006 18:03
