Old 20th October 2008, 15:16   #1
Srinivas's Avatar
Default Battery problem or starter problem or....??
Hello friends,
I own a 2006 Scorpio SLX CRDE. Of late I am having trouble starting the vehicle. Let me describe the problem:
1. When I turn the ignition to "on" position , all the lights and indications on the display panel glow and respond normally.
Next when I turn further to start, there is only a "click" sound. The engine doesn't start.
I then tried cranking the accelerator (like the way we used to do to the amby before) and then then it started off well.
I am not sure why this is happening.
2. I checked the engine coolant reservoir and it was almost empty. I added some water to top it since I didnt have the coolant with me. After this the vehicle has had no problems starting, I dont need to crank the accelerator etc now. I just checked this today.
3. Does the coolant have anything to do with the starting problem. I have bought a can of puroguard today which I will be using to top off the resevoir can today evening.
4. By the way should I fill the coolant as it is into the reservoir can or should I mix a proportion of water with it?
5. Do diesel vehicles need any special coolant or are coolants the same irrespective of the engine?
6. Or is there some issue with the battery/starter. The headlights are bright and the horn sounds good. Is there any other way to check if the battery is the real issue?
I need some gyan on this Thanks in advance!
Srinivas is offline   Reply With Quote
Old 20th October 2008, 17:49   #2
Rehaan's Avatar
Thanked: 25,037 Times
Originally Posted by Srinivas View Post
...Next when I turn further to start, there is only a "click" sound. The engine doesn't start....
Is it just a single CLICK - or does the engine keep cranking loudly but not start ?
If its just a single click - it could be a starter solenoid / relay problem.
In short - yes.
Please search. We have some recent threads on this issue.
OR - just read the instructions on the bottle of coolant that you buy!
cya
R
Old 20th October 2008, 21:25   #3
DarkEraser's Avatar
1. & 6.
There may be some carbon deposits on battery . Clean it.
You may need to check water level of your battery, if it's NOT maintenance free battery. I am not sure though.
2.
Put some water in radiator also. DON'T OPEN IT, if you have already started your car.
3.
AFAIK, it has nothing to do with car starting problem. Experts, please correct me if I am wrong.
4.
LOL, read this thread (What will be the effect of 100% coolant?)
HTH
DarkEraser is offline   Reply With Quote
Old 20th October 2008, 22:33   #4
Shashank.A's Avatar
I second that. It happened in my car, for first few times it was click and then it would start normally. then the problem aggravated and it almost never started.
The culprit was Solenoid.
Shashank.A is offline   Reply With Quote
Old 20th October 2008, 23:26   #5
Ram
Ram's Avatar
Thanked: 149 Times
Man I've just been there yesterday!! Is this de ja vu or is this de ja vu?
After suspecting everything, getting a new Amaron-Flo battery and disabling the remote central locking system, I figured it was the starter solenoid on my Alto-componented 2002 Maruti 800 12-valve MPFI 5 speed.
The starter and solenoid were a dog to remove because of the cramped space in the engine bay. But finally we got the solenoid replaced and happiness at last !!!
Ram
Ram is offline   Reply With Quote
Old 21st October 2008, 12:24   #6
Srinivas's Avatar
Thank you all for your inputs. It is just a click, no half-whirring sound etc.
I shall go to the garage todat.
And yes, it starts fine sometimes but kind of keeps on "clicking" at other times. So before it dies out completely, I better rush
Thanks again !
Old 21st October 2008, 13:08   #7
Shashank.A's Avatar
Solenoid for sure !! get it changed ASAP..!!
Old 21st October 2008, 17:42   #8
whitemm550's Avatar
Thanked: 68 Times
Hello friends,
hey friend.
i can surely gaurantee that the problem is with your starter, nothing else, but still i suggest that you go to a battery shop, and ask the guy for a service battery, put that on and try cranking again, that will pinpoint your problem in a less tedious way, try calling 18004254848, thats amaron battery, they will gladly help u out.
whitemm550 is offline   Reply With Quote
Old 17th July 2012, 07:44   #9
deehunk's Avatar
Thanked: 1,010 Times
Default Re: Battery problem or starter problem or....??
I am unable to start my vehicle, when I turn the key to ignition position all lights dim and there is a very feeble crank sound, the vehicle was running fine till yesterday morning and there were no signs of battery problem till yesterday. But when I went to take out the car in the evening it did not start. My Accent has run on stock battery for 44.5k km and is 5 years old. Shall i try to jump start or replace battery.
deehunk is offline   Reply With Quote
Old 17th July 2012, 08:05   #10
NetfreakBombay's Avatar
Thanked: 402 Times
Battery is gone, jump start and replace battery.
NetfreakBombay is offline   (1) Thanks Reply With Quote
Old 17th July 2012, 23:05   #11
deehunk's Avatar
I found a new website www.batterybhai.com where you can place an order for battery online, delivery will be within 24 hours to your place plus free installation. I placed an order for Amaron AAM-PR-0055B24LS, 45Ah battery for my Accent in the morning and the technician came to my place and installed the battery by evening, my old battery was exchanged for Rs.700 and I paid Rs.4700 for the new battery. The technician Mr.Ashok offers service at your door step and his contact number is 7483266179. His service center is located in Mahadevapura.
deehunk is offline   (2) Thanks Reply With Quote
Old 19th July 2012, 13:08   #12
RSR
RSR's Avatar
Thanked: 4,549 Times
Thanks a lot for sharing that link, deehunk!
That is an excellent resource for those looking to buy an automobile or inverter battery or just comparing different brands and their prices (even if one does not actually buy a battery from them). When our i10's OEM battery was nearing the end of its life, I searched the websites of most battery manufacturers (very tedious and some don't have all the required information like approximate price) before choosing Amaron. A website like this solves the problem. Someone posted a similar, very useful site for tyres in another thread.
Delighted to see e-commerce steadily coming of age in the automobile aftermarket scenario in India.
Edit: The inverter section is still under construction. I wish they add two-wheeler batteries in the future as well!
RSR is offline   Reply With Quote
Old 29th November 2012, 07:30   #13
Thanked: 245 Times
Default Buzzing behind dash, Civic won't start
I have a Honda Civic 2006. From yesterday, the car won't
start. When I turned the ignition, the
engine wouldn't crank and there is a buzzing sound behind the dash. The buzz is located in the dashboard on the right side. the entire dash
(warning lights, speedometer dial, fuel, CD
player, etc do switch on but flicker when I crank the engine.
Any help? Can anyone help me pinpoint the problem?
coolkurt is offline   Reply With Quote
Old 29th November 2012, 11:39   #14
1self's Avatar
Thanked: 270 Times
Default Re: Buzzing behind dash, civic wont start
I think your battery is drained. Get it charged or get a new one if this fails charging.
1self is offline   Reply With Quote
Old 29th November 2012, 12:24   #15
Thanked: 44 Times
I had similar issue with my swift. All the light flickers and was not cranking. Called helpline they came and checked the battery. it was Stock and 4.5 yrs old. they said battery is gone bad and needs replacement. problem solved with new battery.
Get your battery replaced if its old one. you will be good to go.
Endofdayz is offline   Reply With Quote
Replacing Existing Battery with a Cummins Shakti Truck Battery? condor Technical Stuff 14 30th June 2018 18:32
Battery dealer installs 3-wheeler battery in my car!! Now what? Soumyajit9 Technical Stuff 29 19th December 2016 11:06
PICS: SF Sonic Battery Factory. Detailed report on the making of a Car Battery S2!!! Technical Stuff 29 16th April 2016 11:39
Battery question - Can I use Indica Spec Battery in Scorpio, or other such swaps? shekharlele Technical Stuff 18 7th September 2010 09:05
Using a battery tender to revive discharged battery xxaarraa Technical Stuff 2 14th May 2008 19:56
