Old 20th October 2008, 20:38   #1
Default SX4 - cabin air filter, home made solution
I was reading a newspaper and the news was SPM and RSPM count is too high in my city. So to reduce air pollution in my SX4, I am thinking of fitting in-cabin airfilter.
Look at this tread: SX4 cabin filter 07/08 - SX4 Forums
They discuss a way of making a cabin filter for SX4, I checked my SX4 and it does have a place to put a filter which is behind gloves box and closed by a snap fit cover. Now how to construct such a filter, I can try getting airfilter of different cars and see which one is same/bigger size. Then a can make a aluminium/plastic frame and glue this filter on it. Or I can try an airconditioner filter. What kind of filters are availabe in the market.
Well any suggestion is welcome.
strips007 is offline   Reply With Quote
Old 20th October 2008, 21:11   #2
Thanked: 205 Times
Once you have identified that your SX4 does not have an arrangement similar to the one in the pictures figure out a different approach.I see the possibility of fitting an A/C filter to be the eaziest.Check the blower motor and look for the air intake in the end blower .Try to make a suitable frame and a suitable filter over the frame and get it to stick snugly using any fast curing adhesive.Also check the filter material for the following.
  1. It does not crumble when wet.
  2. it does not get mildews and other possibalities for any organic growth.
  3. It is easily washable and replacable.
  4. It will not compromise the airflow in to your duct from the suction side.
The most suitable material i can see from all the above points is Rayon.Rayon or rayon based fabrics are easily available and can be used perfectly for this application.
Lets see if this can give you some ideas to start working.
Miyer is offline   Reply With Quote
Old 21st October 2008, 02:02   #3
Bosch advanced cabin air filter , check if it's available for your car.
cyneverdie is offline   Reply With Quote
Old 21st October 2008, 13:04   #4
Thanked: 103,675 Times
Superb suggestion. Either that or retrofit one from a car that has one inbuilt from the factory itself. That way, you are assured a ready supply of replacement filters.
Old 22nd October 2008, 05:41   #5
aerohit's Avatar
Thanked: 623 Times
Same can be done for Swift also. As i have checkecd - There is a provision for filter near HVAC motor but the filter itself is missing.
aerohit is offline   Reply With Quote
Old 22nd October 2008, 09:01   #6
hellstar's Avatar
Thanked: 17 Times
Same here for all versions of the Verna ... location is inside the dashborad and behind the glove compartment. Me too looking for a filter there
hellstar is offline   Reply With Quote
Old 15th June 2009, 02:38   #7
maglev's Avatar
Thanked: 90 Times
Does anyone have any idea as to why don't Indian cars come with such filters in the first place??
maglev is offline   Reply With Quote
DIY: Adding a Cabin Air Filter to the Honda Brio / Amaze / Mobilio noelnelly DIY - Do it yourself 42 27th December 2017 13:31
K&N's Cabin Air Filter agbenny Technical Stuff 11 9th November 2017 11:22
Mitsubishi Cedia DIY - Cabin Air Filter Installation Captain Slow DIY - Do it yourself 1 27th May 2013 10:14
Air filter and Air intake sunilvarma Technical Stuff 10 4th November 2010 10:58
