Old 21st October 2008, 16:10   #1
Default Cedia Post 10000 KM issues.
Hi All...I just got my Cedia serviced at 10000KM. While overall its been running smoother than before the service, I have noticed that more noise from outside is filtering in. I am referring to bike horns, autorikshaws and mopeds etc...whereas it definitely used to be more muted earlier. Any thoughts on what can be causing this? Its been driving me up the wall!
parichay is offline   Reply With Quote
Old 21st October 2008, 16:55   #2
hrsraghav's Avatar
Thanked: 24 Times
Check the rubber gaskets/beadings on the door and main frame of body, where doors closed.
Also as the engine may have been become more smoother, so the engine noise may have reduced resulting in hearing other noises.
Other wise the outside noises are reduced by soundproofing, and those parts are not touched in routine services. To be on safer side, reconfirm from the Service ceter, what all job have they done on your car, and whether any body work was carried out? Like opening of any panels. Some soundproofing material is used in parts like doors, floor, plastic trims, dashboard.
hrsraghav is offline   Reply With Quote
Old 21st October 2008, 17:04   #3
reignofchaos's Avatar
Thanked: 1,175 Times
Some rubber beading would probably have been dislodged. The other explanation might be that your ears got tuned to the noise level and now you can hear it all the time .
Old 21st October 2008, 17:10   #4
I was almost accepting the theory of getting tuned to the noise level when my wife also mentioned that more noise is coming in...so I am not so sure anymore. I think its to do with something that happened during the service. The problem is that I got it serviced when I was on my holiday in Kerala and now I am back in Bangalore so no easy way of taking it back there to check.
Thanks for the suggestion. I am taking it to the Bangalore dealer to get it checked completely.
Old 6th November 2008, 11:10   #5
Default An update to the issue...
Got it checked...apparently some of the beading in the doors had come loose...back to silence now
Old 6th November 2008, 15:45   #6
Path_Finder's Avatar
Good to hear it was only a minor issue.
Cheers.
Path_Finder is offline   Reply With Quote
Old 6th November 2008, 16:00   #7
abhi1309's Avatar
Thanked: 25 Times
Wow this is good, you already got rid of it. I thought it'll go on for a while with you trying to persuade the dealer and he resisting that this means nothing. Seems like you got lucky to get a smart technician there.
abhi1309 is offline   Reply With Quote
Old 6th November 2008, 16:55   #8
mobike008's Avatar
Thanked: 7,963 Times
My My, just a loose rubber beading and so much sound was creeping in? But, all's well that ends well.
Btw, i am not too concerned about the sound creeping in while driving as my ICE is always on. Do keep this in mind next time any sound creeps in!
Cedia Spirit relaunched as cedia sports basic at Rs. 9,30,000 sidindica The Indian Car Scene 42 4th August 2010 00:16
Cedia Sports - report and photos EDIT - Now updated till 10000 Kms VMG Test-Drives & Initial Ownership Reports 30 17th April 2010 18:43
Need help - Cedia, SX4, Optra or ANHC ? EDIT : The Cedia it is! kartho Sedans 59 23rd November 2009 13:59
Chevrolet Aveo 1.4: 10000 kms report and some niggling issues Raj'sGlory Long-Term Ownership Reviews 11 16th November 2009 12:34
10000 Posts hondaman81 Shifting gears 14 5th May 2004 04:32
