Thread Tools
Old 31st March 2005, 18:47   #1 (permalink)
Question Clutch Problem - Revs shooting up (Baleno)
I purchased a Baleno in January as some of you might know - While I'm quite happy with the car , there seems to be a problem with the clutch or gearbox - it doesnt happen always - only at times.
If Im in 2nd or 3rd and I clutch, upshift and release the clutch and then floor it at times the revvs shoot upto 5000 or so and I have to let off the accelerator - doesnt happen if I'm shifting and driving smoothly - It's definitely not a case of me pressing the clutch longer than I have to - sometimes it shifts fine , sometimes - zoooooom and the revvs shoot up without any acceleration - as if the clutch is not disengaging properly. (If it was improper driving, it'd happen in the other cars as well)
I checked at Rohan Motors - they said the clutch is adjusted at the first service (at 1K) - the problem sstill occurs at times (done 3k so far)
I took it to Motorcraft - the best MASS/Service Masters IMHO and the supervisor check it - it happened once then it disappeared - so he asked me to get it and said they'd check it out - now tomorrow morning I'll leave the car at Motorcraft but can anyone guess as to what the problem might be.
cheers
zaphod
__________________
Six Hamburgers and Scotch all Night,
A drive in a Mustang just to put me right
zaphod is offline   Reply With Quote
Old 31st March 2005, 18:57   #2 (permalink)
Shan2nu's Avatar
Do you have stock tyres? Coz i dunno how grippy those 165s are. If your clutch is ok then only the tyres can cause this.
What about the ECM? Dom will be able to tell you about that.
Shan2nu
__________________
VTEC flyby - youtube.com/watch?v=1AhWJlVRPqE
Old 31st March 2005, 19:15   #3 (permalink)
nope - tyres are 195/60 R14's - but it doesnt feel like a traction problem...
another thing, it's a bit hard to shift into reverse at times - is it because of a lack of syncro or just being new ?
thanks
zaphod
__________________
Old 31st March 2005, 19:17   #4 (permalink)
Shan2nu's Avatar
I think it's the clutch. Coz the Baleno surely doesn't have enuf power to spin 195s in 3rd.
Shan2nu
__________________
Old 31st March 2005, 19:29   #5 (permalink)
speedsatya's Avatar
Originally Posted by Shan2nu
. If your clutch is ok then only the tyres can .
Shan2nu
shan,
can u explain this?????tires causing the engine to revvv :***: .
engine revvs building up and no increase in speed means only one thing-----ur clutch has cooked up.
Dom,Iceman correct me.
cheers,
satya
speedsatya is offline   Reply With Quote
Old 31st March 2005, 19:32   #6 (permalink)
Shan2nu's Avatar
can u explain this?????tires causing the engine to revvv .
Yup, if the wheels are spinning, there won't be any diff in acceleration but your engine rpm will rise.
Shan2nu
__________________
Old 31st March 2005, 19:34   #7 (permalink)
speedsatya's Avatar
Shan2nu
but if the wheels spin ,u can definitely hear the tires spinning,and i dont think thats the case over here.
get ur clutch checked .
Old 31st March 2005, 19:42   #8 (permalink)
veyron1's Avatar
i think that the pressure plate might not be handling the loads well, along with the clutch.
try pointing the car up an incline, engage first, and start engaging the clutch (releasing the pedal). if the revs are increasing, along with an increase in pedal play, without the car moving, then it's definitely clutch slip.
if what you said is happening only in the 2nd- 3rd gears, then it could be just the pressure plate.
but since you said that shifting is hard even to reverse (are you disengaging the clutch completely?), before opening up the gearbox and stuff, tell your mechanic to check the gear selector mechanism. even this can cause improper shifting, hard shifting, or mis-shifts.
the synchro cones help in smooth shifting only when the vehicle is in motion, i.e, it's function is to smoothen shifts when the output shaft is in motion, to avoid excessive gnashing of gears. therefore, it is not given in some cars for reverse. but correct me if i'm wrong, isn't the baleno's 5-speed all synchro-mesh?
__________________
DAD
veyron1 is offline   Reply With Quote
Old 31st March 2005, 19:44   #9 (permalink)
iceman91's Avatar
hey it could be that the gears are not engaging properly. get that checked. it cannot be the clutch else it should happen always
__________________
...91 is back !!!!
iceman91 is offline   Reply With Quote
Old 31st March 2005, 19:46   #10 (permalink)
iceman91's Avatar
Shan2nu
shan dont know how you do it.
if tires arre spinning clutch is not the problem.
__________________
...91 is back !!!!
Old 31st March 2005, 19:58   #11 (permalink)
Note : The wheels aren't spinning... not a traction problem
veyron, I'll check into your advice in the morning - will try it on a ramp and will ask the chaps at motorcraft to look into other option before taking apart my car....
In that case what would be the remedy ....doesnt sound like good news whatever is causing this..
(/me is reminded of a family friend who's spanking new 800's gearbox literally dropped out of the car in the first week)
thanks
zaphod
__________________
Old 31st March 2005, 20:03   #12 (permalink)
iceman91's Avatar
if gears not engaging properly check synchroniser rings and the alignment
__________________
...91 is back !!!!
Old 31st March 2005, 20:16   #13 (permalink)
veyron1's Avatar
hey zaphod, like i said, if the gears aren't engaging properly, before ringing da-vinci , henry ford ( i don't know the name of suzuki's inventor!!), or jagadish khattar, check out the gear selector mechanism first- operate on the rest later...
and like i said, it might not be the clutch if you checked out the way i told you to-it could also be the pressure plate-the pressure plate takes the load of the pedal, and the load of the engaging/disengaging, so it doesn't matter if your clutch is fine, if your pressure plate's faulty, then nothin's gonna spin anywhere baby!!!
__________________
DAD
Old 31st March 2005, 20:25   #14 (permalink)
veyron1's Avatar
and iceman, zaphod doesn't say anything about noises while shifting, only hard shifting, so it's unlikely that the synchro rings/ mesh cones are at fault here.......
besides, the revs increase after shifting, without any power transmission to the wheels, and that, isn't the synchronisers's fault anyhow!!
__________________
DAD
Old 31st March 2005, 21:10   #15 (permalink)
Shan2nu's Avatar
I never said that. I said either the clutch has a problem or the tyres are spinning.
Shan2nu
__________________
Thread Tools
Clutch Problem in Wagon R snaronikar Technical Stuff 9 10th August 2007 16:38
Clutch problem or what ? abhibh Technical Stuff 2 21st May 2007 14:33
Zen clutch problem simran Technical Stuff 12 23rd September 2006 19:23
2001 Accent Clutch problem Ironmarine Technical Stuff 2 7th August 2006 08:00
Is this a clutch plate Problem???? The Stig Technical Stuff 8 12th January 2005 00:23
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445
