Thread Tools
Old 1st April 2005, 23:35   #16 (permalink)
amitverma's Avatar
since we are discussing tyres here...strange thing happened with my friend's santro,
we went to the gas station to get some more air for the rubber, i noticed that the pressure was more than the permitted air pressure reqd. how the hell is this possible...?
amitverma is online now   Reply With Quote
Old 2nd April 2005, 00:17   #17 (permalink)
When you run the car,the tires will get hot after sometime due to friction with the road surface.
thats why always check pressure when the tire is cold.
so its a good option to buy a foot pump
__________________
say "aa bail mujhe maar " and then blame the bail ....hahahhah
MKRAFT is offline   Reply With Quote
Old 2nd April 2005, 12:11   #18 (permalink)
Yes You Are Right That There Has To Be A Balance Between The Ride Comfort And Handling While Selecting A Tyre. A Lower Profile Tyre Will Give A Better Handling But Will Reduce The Rode Comfort Due To A Short Side Wall. Thus Friends Before Selecting The Tyre See On What Kind Of Roads You Usually Drive, If Its Paved And Good You Can Go For Low Profile However If Its Not Go For A Higher Profile Tyre. But Remember To See The Rim Size And The Hib Size Of The Original And The Same Should Not Be Disturbed
Carbuff is offline   Reply With Quote
Old 4th April 2005, 20:01   #19 (permalink)
Samurai's Avatar
Originally Posted by speedsatya
the baleno comes with 165/80r13 ,circumference=1866.73mm,OD=594.5mm
so with 185/65r14,cir.=1872.7mm,OD=596.021mm
but with 185/60r14,cir.=1814.58mm,OD=577mm
Interesting. So if I consider
195/55R15, circumference=1870.82mm,OD=595.5mm Even closer. Just .22% error in speedo. Sidewall 81% of original.
195/60R14, circumference=1852.28mm,OD=589.6mm Just 2.3mm lower in height. Very little error in (-0.77%) speedo. Sidewall 88% of original.
However, moving from 165mm width to a 195mm width, would the tyre protrude out of the body? I don't prefer it. Experts please chime in.
Also what happens to the ride comfort by reducing the sidewall to 81% or 88%? I don't think there is a formula to calculate that...
__________________
Samurai
The notchy gearshift of GV has become buttery smooth after I started driving the Jeep.
Old 4th April 2005, 20:51   #20 (permalink)
shravan316's Avatar
Aint no expert here, but, well, if you reduce the sidewall the ride will definitely be a bit more harsh at lower speeds and there is potential of the alloys breaking/cracking. Iceman's Baleno has 205 footwear, and it doesnt protrude outside. 195 shouldnt really create troubles.
Correct me if i am wrong here guys!
__________________
"You can have it in any colour as long as its black..."-Henry Ford
shravan316 is offline   Reply With Quote
Old 4th April 2005, 23:03   #21 (permalink)
Shan2nu's Avatar
Well, pratically speaking, even if you consider all the variables, finally what matters is you suspenssion setup and your tye pressure. I recently realised that my 196/60 R 14s can drastically switch between performance and ride comfort depending o it's pressure.
Iceman's Baleno running on 26 psi felt more comfy on broken surfaces, than Rudras Optra running 30-31 psi. And they both have 205/50 R15s.
So, it really isn't such a big deal. You just gotta use the right tyre pressure at the right time.
Shan2nu
__________________
VTEC flyby - youtube.com/watch?v=1AhWJlVRPqE
Old 4th April 2005, 23:09   #22 (permalink)
speedsatya's Avatar
now with 155/65r13,the handling was pathetic with 5.5j rims.butwith change in rims to 5j ,things have improved .also keeping 28-31psi depending on loads.
i felt teh wider 5.5 j rim made my tire wall look smaller than the 65 profile.
[u]so i feel ,along with air pressure,the rims that u use to fit the tires is also important in deciding teh ride.[/U
if the tires protude out,it will foul with the body when there is load inside the vehicle.also it can put excessive load on the suspension components.
also,the tires protuding out depends a lot on the rims that you use.
the same tires can handle differently oin differnt rims.as i had mentioned in an earlier post .
normally reducing the sidewall ,will slightly worsen your ride but improve ur handling.
but,
changing from 145/80r12 to 155/65r13 should have improved my handling as i had reduced the profile and also widen the tire.but i used to suffer from lot of understeer.also as expected the ride had deteriorated.
but when i changed from 155/65r13 to 165/60r13 potenza GIII,surprisingly my ride has improved as well as the grip levels.
so i feel that unless you really go very low profile tires ,your ride will not be that bad as compared to a higher profile.
so ,taking both ride and 185/65r14 should be the best bet on a baleno
speedsatya is offline   Reply With Quote
Old 4th April 2005, 23:18   #23 (permalink)
Shan2nu's Avatar
Exactly, ride quality depends on a lot of things. If i were to compare the S322s with the GIIIs, i bet a 175/65 R14 GIII will give me better ride quality and handling than a 195/60 R14 S322, just bcoz the GIII is that much more superior to the S322. It's got a softer compound which improves ride and grip.
It is very possible that 2 diff tyres (model or make) with the same specifications can behave very differently.
Shan2nu
__________________
Old 4th April 2005, 23:54   #24 (permalink)
Samurai's Avatar
Thanks guys, whatever type I pick I'll make sure it is Protenza GIII. Hey, I learnt a lot about how to pick a tyre now.
as my 155/65r13 handles better in a 5j rim as compared to a 5.5j rim.
According to the wheel bible you showed me, the ideal rim size should be 70% of the type width. (155/25.4)*0.7 = 4.27 approximated to 4.5 inch. You deviated too far towards 5.5, switching it to 5' obviously helped. Moving to 4.5 would have been even better. Then you moved to 165 width, (165/25.4)*0.7 = 4.54 which is even closer to your 5" rim, no wonder ride improved further. Of course, I am sure GIII helped too. However, have you considered 4.5" rim?
__________________
Samurai
Old 5th April 2005, 00:16   #25 (permalink)
speedsatya's Avatar
yeah ur right.the 5.5 j rims were too wide.but i was a novice then,and accepted ahtever the tire guy gave me.
so when i put 155/65r13,still i was never happy with the handling as i have mentioned many times.
but if u see this
http://www.tongseng.com.hk/Page/Product/G3.html,
for 165/60r13,5j rims are advised for my size.
and i am more than happy with my present tires.
they are awesome.gone is the understeer and now my car feels something differnt.cannot comment on the d2,d3 eagle tires ,but these tires are simply awesome.
so have to go to the Nh17 mumbai-goa road to test it.
Old 5th April 2005, 00:29   #26 (permalink)
Shan2nu's Avatar
LOL, i just did NH 63 and NH 17 today. GIIIs are a class apart.
Shan2nu
__________________
Old 5th April 2005, 16:03   #27 (permalink)
The rim offset also matters in that - get something like a 32 and it will protrude - mine are 45 offset 5.5 R14's with 195/60's and no trouble, the tyres don't protrude out and neither do they foul the suspension (thanks Iceman for the advice when i got my rims and tyres)
__________________
Six Hamburgers and Scotch all Night,
A drive in a Mustang just to put me right
zaphod is offline   Reply With Quote
Old 5th April 2005, 16:13   #28 (permalink)
speedsatya's Avatar
Originally Posted by zaphod
The rim offset also matters in that - get something like a 32 and it will protrude - )
can you please explain this.????????
]how do you know what offset your present rim is.
and can the offset be changed?????
Old 5th April 2005, 16:31   #29 (permalink)
I think the tyre bible link has more info on offset - basically it means how far away from the centre of the rim, the hub is mounted - for example, on a baleno, the stock is 38, moving to 32 will move the hub of the rim 6mm inside thus the rims will be more towards the outside and moving to 45 will move the hub 7mm outside and as it will be further away from the centreline the rims will be 7mm closer to the inside.
(I think a diagram would be needed to illustrate exactly how it works - check out that 'tyre bible')
too low an offset = protruding rims which may put more stress on the suspension and axles and too high may make the tyre foul with the suspension.
The rims you buy will also have an offset given in the specs - and the only way to change it is to get new rims - or you could nullify the effect of high offset by using spacers.
I hope i got that right.
zaphod
__________________
Old 6th April 2005, 16:22   #30 (permalink)
I've got 6" 14 inchers with 35 offset on my Baleno. No problems whatsoever with protruding tyres or fouling up the suspension.
~Sonic
sonic is offline   Reply With Quote
Thread Tools
Improving the ride comfort in OPTRA D.V.R Tyre & Alloy wheel Section 10 1st September 2008 14:00
Improve the Ride Comfort & Handling of Omni mithun Modifications & Accessories 14 17th October 2006 06:02
Hatch Back Vs Sedan ( Ride, handling, comfort, Power etc) muni Technical Stuff 8 7th February 2006 16:33
Low Speed Ride Comfort ramkya1 Technical Stuff 1 25th November 2005 11:13
Performance and Ride comfort in one car? Samurai Sedans 84 12th April 2005 18:53
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481
