Old 22nd October 2008, 18:08   #1
alias's Avatar
Default 2002 Zen - Engine light on!!!
Hi all,
I need the your advice
Today while driving to work suddenly a light in the Speedo console lit up
I think itís the engine light how ever I am not sure and following this the Speedo meter stopped functioning.
I am not sure that could have caused it and follow the Speedo the steering started feeling very hard as if it was normal steering (though my cars supposed to have power steering)
I stopped the car for a while but as soon as I start the car the light comes back on,.
Attaching a picture of the light thatís come on.
Kindly advice
Asif
Ps I plan to take it to Suzuki *** however due to my busy schedule I will be able to take it only on Saturday till then I need the car to drive me to work every day.
BTW itís a 2002 Zen lxi.
alias is offline   Reply With Quote
Old 22nd October 2008, 18:18   #2
vikram_d's Avatar
Thanked: 940 Times
Yes that is the check engine light. You will have to take it to a MASS and have the ECU scanned for trouble codes using the Tech 2 scanner. That will tell what the problem with the car is.
Old 22nd October 2008, 18:29   #3
ankitahuja's Avatar
Thanked: 46 Times
@alias - http://www.team-bhp.com/forum/techni...ml#post1009045 (Engine Malfunction Light ON in OHC. pls advise!)
Check out this link, I had the EXACT same problem, though the sensor has not been replaced till now.
Do post what you find in the scan on Saturday.
Old 22nd October 2008, 18:33   #4
DueLLeR's Avatar
Thanked: 61 Times
Looks like the EPS has failed. I don't understand what would make the speedo to go kaput. Take it to MASS and have them check it. If I were you, I'd avoid using the car when the light is ON. Good luck!
Cheers!
DueLLeR
DueLLeR is offline   Reply With Quote
Old 22nd October 2008, 18:44   #5
alias's Avatar
Cheers!
DueLLeR
[SIZE=3][FONT=Times New Roman]Thanks for the info guys,[/FONT][/SIZE]
[SIZE=3][FONT=Times New Roman]Really appreciate it [/FONT][/SIZE]
[FONT=Times New Roman][/FONT]
[SIZE=3][FONT=Times New Roman]How ever is there a difference between power steering and eps[/FONT][/SIZE]
[FONT=Times New Roman][SIZE=3]and is there a connection between power steering and Speedo meter.[/SIZE][/FONT]
Old 22nd October 2008, 19:09   #6
vikram_d's Avatar
Thanked: 940 Times
EPS stands for Electronic Power Steering. So they are both the same. Don't know about link between speedo and power steering.
Old 22nd October 2008, 19:44   #7
rohan_fonseca's Avatar
Speed sensor malfunction. Get that checked.
rohan_fonseca is offline   Reply With Quote
Old 22nd October 2008, 19:57   #8
alias's Avatar
thanks for the reply
however does that have nay thing to do with the power steering
are they interconnected???
Old 22nd October 2008, 21:21   #9
Ford Rocam's Avatar
Thanked: 16 Times
Could be, After specific Vehicle speed the the power steering gets deactivated. just like in hydraulic. here its electronic, looks like some sensor issue & like vikram said, getting a high scan done should give you the root cause of problem.
Ford Rocam is offline   Reply With Quote
Old 22nd October 2008, 22:11   #10
ankitahuja's Avatar
Thanked: 46 Times
Is that possible to throw up the EML in an OHC?
Old 23rd October 2008, 01:01   #11
autopsyche's Avatar
Thanked: 15 Times
Im pretty sure its the VSS (Vehicle Speed Sensor) on the gearbox which has died. It will result in a non functional speedo and a check engine light.
autopsyche is offline   Reply With Quote
Old 23rd October 2008, 01:07   #12
alias's Avatar
thanks for the info sir
could you tell me how much would that sensor cost??
and
Thanks for the guidance all
I did do a bit of research on the issue and found the manual online on maruti site
And attaching what I found
It says that it’s the some things wrong with the emission control system
Well now the question is what this emission control system is
And what does it have to do with the eps of the car
Old 23rd October 2008, 01:43   #13
alias's Avatar
and sir can i drive the car with the light on?
please advice
Old 23rd October 2008, 09:55   #14
Alias,
1. Check the fuse of the EPS
2. Get your car scanned
3. Check (and if possible replace) the relay of Radiator Fan.
Khandelwal is offline   Reply With Quote
Old 23rd October 2008, 09:58   #15
im_srini's Avatar
Thanked: 399 Times
Smile
Hi, I think Arush is right - your Vehicle Speed Sensor (VSS) has gone kaput, leading to the MIL turning on, your speedo not working, & your EPS shutting off.
Even if you don't have a Tech-2, there's a coupler in the engine-bay which can be used to diagnose the issue. In fact, the image you've posted shows how it's done...
A particular terminal in the coupler is called the diagnostics-switch-terminal & when grounded, flashes the error code using the MIL ! The VSS is one of the sensors that can turn on the MIL, others include MAP, ECT, & TPS...
im_srini is offline   Reply With Quote
Vista Tdi - Engine oil and the Check engine light turns ON skartik2 Technical Stuff 4 27th August 2009 14:50
Need one good ICE setup for my zen 2002 ~~VinZ~~ Shifting gears 1 27th September 2007 02:13
Zen 2002 model 12" rim available (5 numbers) ~~VinZ~~ Shifting gears 1 25th September 2007 20:36
Jan 2002 Maruti Zen Lxi for sale the real Big B Shifting gears 2 7th September 2007 23:04
Upgrading my 2002 Zen LXi Zensible Modifications & Accessories 12 28th October 2005 08:49
