| Technical Stuff Want to know your Vtec, ABS or intercooling better? |
| | Thread Tools |
| | #1 (permalink) |
| BHPian | well as the title suggests, i myself have no idea whats wrong. when the car is running & i hit the clutch to change my gear, the odo backlight goes dimmer & the blower/fan goes down. sometimes, even the handbrake/battery light appear & the engine stops. same happens when i raise/drop my windows (power windows). the problem occurs even when the car is not in motion. another serious problem: while driving, if one applies the brake, it is understood one is going to hit the brake/clutch together. during this process, the handbrake/battery light appear, the engine stops & the brakes fail out. its a bad thing in heavy traffic. this does not happen when i just hit the brakes & not the clutch. before giving it to a mechanic, i would like some suggestions from you guys. by any chance, is this related to the alternator? i got a new battery 2 months ago, so thats out of question. ~cheers
__________________ - INFECTED 8 months! |
| | #3 (permalink) |
| BHPian | yes shan thats right. i have discussed this with some friends & they are like, what the hell are you talking about? it really scares the hell out of me when i see a speed braker a few metres ahead, want to shift down from third to second or first & the brakes absolutely give up. very very wierd! ![]()
| | #5 (permalink) |
| Team-BHP Support ![]() | It may be one of a few things. 1. Alternator problem 2. Carburator needs to be cleaned/tuned as it may be running too low an idle speed 3. Carb is taking in air from somewhere
__________________ He who makes the loudest noise usually has the least to say. Unfortunately they don't realise that and keep at it! ____ |
| | #7 (permalink) | |
| Distinguished - BHPian ![]() | Quote:
Also look at the wiring harness behind the dirvers side door panel, it can also be shorting there when you lower or raise the window. Most probably it might be above the clutch pedal itself on the wiring harness. The most uncommon place you can look is on the ignition key assembly a loose connection also could be there. Get it done asap before you blow the electricals out.
__________________ Learning is a continuos job that keeps me busy. | |
| | #9 (permalink) |
| Senior - BHPian | need new altenator of 100 amp. will have to go do some mods for it. or buy a battery charger at home which comes for around 1k and charge whenever needed. get rid of the system u have and it will work properly. i guess ure not going to so charger is the way to go.
__________________ Јєşåł Åŕỳā Modifying Gone Mental |
| | #12 (permalink) | |
| Senior - BHPian | Quote:
__________________ Јєşåł Åŕỳā Modifying Gone Mental | |
| | #13 (permalink) |
| BHPian Join Date: Nov 2004 Location: New Delhi
| its kinda strange and scary. u shd be extra-cautious while driving... anyways. i think psycho's 1st point. there may be a short wire near the clutch assembly. since u just changed the battery, u definately shd check it to be on the safer side. definitely, the electricals are at fault here. the heavy sound setup may also be eating up your battery. since jesal has already experienced it, might be worth leaving the car started up for a while with all the electricals off. |
| | #15 (permalink) | |
Cheers Steer
__________________ Cheers Steer Petrols Suck. Diesels Torque. Q.E.D | |
| Thread Tools | |
Similar Threads | ||||
| Whats wrong with my Corolla's Clutch and Engine? | novice | Technical Stuff | 10 | 7th March 2008 12:04 |
| Whats wrong with the suspension? | tsk1979 | Technical Stuff | 9 | 18th September 2007 13:27 |
| Whats wrong with this K&N conical filter assembly | rishibravo | Modifications & Accessories | 25 | 18th April 2007 18:48 |
| Any idea about FIAT Idea? | Minardi | The Indian Car Scene!! | 13 | 28th May 2005 12:38 |
| whats wrong with the emoticons?? | _Crazi4Speed_ | Shifting gears | 2 | 23rd June 2004 12:29 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459
